Thread: What gearbox oil?
Results 1 to 9 of 9
  1. What gearbox oil?
    Mar 2012
    Birmingham
    Hi all
    Im hoping someone can answer my question
    my car is a 2009 A3 1.4 TFSI 6 speed gearbox (LNY) 102,000 miles on the clock
    im looking at changing my gearbox oil and struggling to find the right type (I'm aware its supposed to last the lifetime of the car) but as an engineer it goes against everything ive ever learnt and i changed the oil on my old golf and it transformed the gearbox
    so can any of you cleaver people help me out
    many thanks in advance
  2. Re: What gearbox oil?
    134 Post(s)
    2003 Post(s)
    Filled for life means a reduced life, just wrong for anyone who suffers from mechanical sympathy. The VAG number is G 052 527 A2 but is daft money at £50.98 per litre, the A2 at the end of the part number signifies a 1 litre bottle and the capacity is listed at 2.2 litres dry. In generic terms it is an SAE75W or GL-4.
  3. Re: What gearbox oil?
    Mar 2012
    Birmingham
    Hi Crasher
    thanks so much for the info and ouch @£50.98 per litre silly money
    indeed
    i did a gearbox oil change on old golf and used Febi Belstein this came up
    Its much cheaper at 15 quid a litre
    do you know if the specs are right for my cars gearbox (LNY 6 Speed)
    thanks again Crasher
    FEBI BILSTEIN Manual Transmission Oil G 052 527 A2Capacity: 1l, 75WArticle number: 21829
    Reviews - 58
    • Colour: Yellow
    • Capacity [litre]: 1
    • Recommendations: VW TL 521 71, VW TL 521 78, VW TL 525 12, VW TL 726 Y, MB 235.10, Ford WSS-M2C200-D2
    • Oil Viscosity Classification SAE: 75
  4. Re: What gearbox oil?
    134 Post(s)
    2003 Post(s)
    Yes Febi 21829. The box fluids we stock are almost exclusively Febi as we have a direct factor account plus a number of genuine fluids and Ravenol who do some of the more unusual types Febi don’t offer and are insane money genuine. One Audi DSG fluid they do for £24 a litre is £130 from VW and you need 7.5 litres!
  5. Re: What gearbox oil?
    Mar 2012
    Birmingham
    That’s good to know and after a bit of research I discovered the Fuchs produce oil for the VW Group and have all the accreditations etc
    so may i ask you to have a look at the link
    Fuchs TITAN SINTOFLUID FE SAE 75W Synthetic Manual Transmission Oil
    (On the back of the bottle it states G 052 527 A2)
    Thanks again Crasher
  6. Re: What gearbox oil?
    134 Post(s)
    2003 Post(s)
    Fuchs is an excellent product as are OPIE oils an excellent company. I don’t know if Fuchs make VAG Germanys fluids but they do make fluids for VAG UK under the Quantum brand.
  7. Re: What gearbox oil?
    Mar 2012
    Birmingham
    Hi Crasher
    i was hoping you’d say that about Fuchs and Opie Oils i think im going to go for the Fuchs from Opie Oils thanks so much again for your input and great info Crasher
  8. Re: What gearbox oil?
    Mar 2012
    Birmingham
    Hi Crasher
    i now have in my possession 3 bottle of Fuchs gearbox oil thx again for your help
    May i be really cheeky and ask you a couple of questions about my car in particular my tyre pressures my car runs on 225 40 ZR18 92Y tyres and I’m really struggling to find the correct pressures as the sticker on the door jam label doesn’t even mention 18”
    the other question is i found an electrical plug (see pic) under the end cap at the end of the dash (same bit of trim as the fuse box cover) do you have ant idea what it its for?1559242A-C2EA-4FC1-9A11-07946EBD1FCE.jpg
    again many thx
  9. Re: What gearbox oil?
    134 Post(s)
    2003 Post(s)
    Sane problem I had with mine, used the 17's pressures plus a bit.
  1. Question Looking for multitronic gearbox will only one code gearbox work
    By yaza01 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2017, 03:39 PM
  2. Gearbox - No reverse, rattle in neutral- leaking gearbox oil. HELP!!!!!
    By robert1z in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2017, 07:00 PM
  3. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  4. Replies: 1
    Last Post: 15-02-2015, 05:39 PM
  5. Gearbox DFH, will it fit replace my gearbox DFK?
    By red_avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2008, 05:32 PM
