Thread: Turbo, injector and Under boost faults
  1. Turbo, injector and Under boost faults
    Mar 2024
    portland, uk
    Been having problems with my 2007 BKP 133k Passat B6 Estate.
    Bit of background, had it since early 2018, oil pump went end of 2022 but managed to pull over straight away so didn't cause any damage to the engine.
    Started in January when it died on the way to work, loads of white smoke out of the back and noisy engine.
    Here is the scan that was pulled straight after...
    Code:
    Code:
    Saturday,13,January,2024,10:43:57:00009VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 23.3.1.0
    Data version: 20230421 DS346.2
    www.Ross-Tech.com
    VIN: WVWZZZ3CZ8E101761   License Plate: WG57 KBJ
    Mileage: 215160km-133694mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8E101761   Mileage: 215160km-133694miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
       Component: R4 2.0l PPD1.5      0907
       Revision: --H45---    Serial number: VWZCZ000000000
       Coding: 0000172
       Shop #: WSC 05314 000 00000
       VCID: 6FED66BB7E9D05EB22-803A
       VINID: 9E69EAAAA0D3A885410011C60450DBC9B9
    4 Faults Found:
    004705 - PD Unit Injector: Cylinder 1 (N240)
                   P1261 - 006 - Regulation Range Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 0
                        Fault Frequency: 14
                        Reset counter: 37
                        Mileage: 214970 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:47:39
                 Freeze Frame:
                        RPM: 1568 /min
                        Torque: 104.0 Nm
                        Speed: 0.0 km/h
                            86.97 %
                        Text:  4.125    uF
                        Text: 11.75    mJ
                        Text:      3    mJ
                        Raw, Form. N/A: 000 000 000
    004711 - PD Unit Injector: Cylinder 3 (N242)
                   P1267 - 006 - Regulation Range Exceeded - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 10
                        Reset counter: 36
                        Mileage: 214972 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:49:58
                 Freeze Frame:
                        RPM: 1536 /min
                        Torque: 120.0 Nm
                        Speed: 43.0 km/h
                            81.51 %
                        Text:  4.875    uF
                        Text: 14.25    mJ
                        Text:     10    mJ
    004720 - PD Unit Injector: Cylinder 4 (N243)
                   P1270 - 006 - Regulation Range Exceeded - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 5
                        Reset counter: 32
                        Mileage: 215004 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 07:58:47
                 Freeze Frame:
                        RPM: 1408 /min
                        Torque: 96.0 Nm
                        Speed: 62.0 km/h
                            81.90 %
                        Text:  4.875    uF
                        Text: 14.50    mJ
                        Text:      7    mJ
    000665 - Boost Pressure Regulation
                   P0299 - 006 - Control Range Not Reached - Intermittent
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 215161 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 09:51:47
                 Freeze Frame:
                        RPM: 3008 /min
                        Torque: 160.0 Nm
                        Speed: 44.0 km/h
                            64.74 %
                        Voltage: 14.46 V
                        Pressure: 1874.4 mbar
                        Pressure: 639.0 mbar
    Readiness: N/A
    Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
       Component: J104    C4 440 V2   0003
       Revision: --020---    Serial number: 00000776299934
       Coding: 0001297
       Shop #: WSC 05311 000 00000
       VCID: 1F4D567BCEBDD56BD2-804A
    No fault code found.
    Address 08: Auto HVAC        Labels: 3C0-907-044.clb
       Part No SW: 3C0 907 044 CB    HW: 3C0 907 044 CB
       Component: ClimatronicPQ46 122 0707
       Revision: 00122021    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 63C51A8BA255B18BB6-8036
    1 Fault Found:
    01592 - Air Quality Sensor (G238)
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 236
                        Mileage: 212603 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 11:06:30
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Component: Bordnetz-SG     H54 2202
       Revision: 00H54000    Serial number: 01000007680584
       Coding: E1888F0700041A00470A00000F00000000085D435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 71E960C368A9131B34-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 270907 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     121007 046  0204
       Coding: 00208933
       Shop #: WSC 05124
    3 Faults Found:
    00987 - Lamp for Brake Light; Left (M9)
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 1
                        Fault Frequency: 46
                        Reset counter: 14
                        Mileage: 213128 km
                        Time Indication: 0
                        Date: 2005.09.13
                        Time: 31:63:63
                 Freeze Frame:
                            ON
                        Voltage: 11.45 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    02395 - Parking Light Front Right (M3)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 36
                        Reset counter: 21
                        Mileage: 214085 km
                        Time Indication: 0
                        Date: 2005.09.13
                        Time: 31:63:63
                 Freeze Frame:
                            ON
                        Voltage: 14.05 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00985 - Right Tail Light (M2)
                 Freeze Frame:
                        Fault Status: 00111100
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 5
                        Mileage: 214654 km
                        Time Indication: 0
                        Date: 2005.09.13
                        Time: 31:63:63
                 Freeze Frame:
                            ON
                        Voltage: 14.00 V
                            ON
                            ON
                            OFF
                            OFF
                            ON
    Address 15: Airbags        Labels: 3C0-909-605.lbl
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0C AIRBAG VW8   032 2522
       Revision: 12032000    Serial number: 003B1PLMFS30
       Coding: 0012355
       VCID: 306FA5C7A3235A137B-8064
       Subsystem 1 - Serial number: 6332MSME176B341E
       Subsystem 2 - Serial number: 6342MSME172C7715
       Subsystem 3 - Serial number: 6351HTS6L4ICA337
       Subsystem 4 - Serial number: 6361HTS6OFJCD556
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    1 Fault Found:
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 J    HW: 3C0 953 549 J
       Component: Lenks ulenmodul 006 0010
       Revision: 00006000    Serial number: 3C9953507BC
       Coding: 0000004
       VCID: 3365AACB5235610B06-8066
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 12345 067 57207
       VCID: 2E53BBBFB9174CE369-807A
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P07A1702B5
       Coding: F982FF060002022003
       VCID: 23455A8BE2D5F18BF6-8076
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 K
       Component: Haldex 4Motion      1118
       Coding: 0000001
       VCID: 356194D35C417F3B28-8060
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 397998E370599B5BCC-806C
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1101
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F6DA6BBBE1D45EB62-807A
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000048778922
       Coding: 0000951
       VCID: 3C7781F77F6BAE73D7-8068
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.136 H08 1901
       Shop #: WSC 02069 000 90108
       VCID: 366393DF4147742321-8062
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 0191020051030E76300494157008DFCE107CA0
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H07 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    1 Fault Found:
    01038 - Central Locking Thermal Protection
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 4
                        Reset counter: 19
                        Mileage: 212678 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 15:08:16
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1132
       Revision: 31008001    Serial number: 00000500078809
       Coding: 0000950
       VCID: 3D718CF36471A77BE0-8068
    1 Fault Found:
    00940 - Mirror Adjust Motor; Passenger Side (V150)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 48
                        Reset counter: 7
                        Mileage: 212633 km
                        Time Indication: 0
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-09393 0009
       Revision:   008       Serial number: 00000000209610
       Coding: 0000057
       VCID: 295948A380F92BDBBC-807C
    5 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 5
                        Reset counter: 252
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 12.40 V
                        Count: 10
                        Hex Value: 0x0171
                        Hex Value: 0x0082
                        Hex Value: 0x1001
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                011 - Open Circuit - MIL ON
                 Freeze Frame:
                        Fault Status: 11101011
                        Fault Priority: 2
                        Fault Frequency: 102
                        Reset counter: 236
                        Mileage: 214909 km
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 14.00 V
                        Count: 30
                        Speed: 0.0 km/h
                        Hex Value: 0x1271
                        Hex Value: 0x0001
                        Hex Value: 0x1002
    00446 - Function Limitation due to Under-Voltage
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 1
                        Fault Frequency: 8
                        Reset counter: 253
                        Mileage: 214909 km
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 11.60 V
                        Count: 52
                        Speed: 0.0 km/h
                        Hex Value: 0x12F1
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    02845 - Function Display in Instrument Cluster (!)
                007 - Short to Ground - MIL ON
                 Freeze Frame:
                        Fault Status: 11100111
                        Fault Priority: 2
                        Reset counter: 236
                        Mileage: 212603 km
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 11.90 V
                        Count: 78
                        Speed: 0.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    02442 - Function Lamp in Control Head
                009 - Open or Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00101001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 252
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 11.80 V
                        Count: 81
                        Speed: 0.0 km/h
                        Hex Value: 0x0871
                        Hex Value: 0x0008
                        Hex Value: 0x1001
    Pulled over straight away and got it towed to my mechanic, turbo had got so got a re-conditioned one and had it replaced.
    Afterwards I was still getting the
    PD Unit Injector: Regulation Range Exceeded - Intermittent fault on cylinders 1, 3 and 4.
    Along with the boost pressure regulation fault intermittently, mainly when driving up hill in low gears. Small amount of smoke out of exhaust.
    My mechanic checked the wiring from the ECU to the injectors, replaced seals on injectors and replaced injector wiring loom.
    Fuel filter was dirty so that was cleaned out and replaced.
    Still the same issues, he then switched injectors 2 and 3 over and the fault moved to cylinder 2.
    Probably should have given up here but decided to keep going.
    Bought 4 re-manufactured injectors, which were installed.
    Now only had the Injector fault on cylinder 2, and the intermittent boost fault.
    We figured the one of the injectors must have been faulty so we replaced it with the one of the original 4 which was not throwing up the fault code.
    Now after quite a few drives we have no injector faults at all and definitely more power than before. Sounds good on idle and when coasting but quite lumpy/juddery engine when accelerating. Kicks in at around 1500rpm.
    The only fault I am getting now is...
    Code:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 216356 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 15:56:08
                 Freeze Frame:
                        RPM: 2432 /min
                        Torque: 184.0 Nm
                        Speed: 56.0 km/h
                            99.45 %
                        Voltage: 14.35 V
                        Pressure: 2343.0 mbar
                        Pressure: 1128.9 mbar
    Does anyone have any ideas what could be causing this?
    Seems like other on the forum with this issue have vacuum leaks or swirl flap/inlet manifold issues.
  2. Re: Turbo, injector and Under boost faults
    114 Post(s)
    1872 Post(s)
    Underboost is nearly always a leak in the vacuum system.
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  3. Re: Turbo, injector and Under boost faults
    Mar 2024
    portland, uk
    Thanks for the quick reply, do you think that would cause the rough running?
    Now that I am not getting any codes for the injectors can I rule them out?
    Also were would be the best place to start looking for vacuum leak?
  4. Re: Turbo, injector and Under boost faults
    114 Post(s)
    1872 Post(s)
    It won’t cause poor running like on a petrol engine, BKP injectors are notorious for running problems even without code, study the balances and anything approaching +/-1 is a problem.
  1. Please Help Over/Under Boost, Injector & Electrical issue.
    By Gazcoyne in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-08-2019, 03:13 PM
  2. Good turbo/injector companies?
    By AaronB9006 in forum Golf MK5 - 2004 - 2009
    Last Post: 10-10-2016, 02:31 PM
  3. Did i kill my turbo with injector cleaner
    By cupidstunt in forum Golf MK4 - 1999 - 2004
    Last Post: 06-10-2013, 10:02 PM
  4. Important Injector Faults on Passat B6 tdis
    By jason_murray in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-09-2011, 09:45 PM
  5. Alhambra turbo faults again!
    By Bostrom998 in forum Alhambra
    Last Post: 28-08-2007, 07:10 AM
