Thread: 2007 Crafter Suspected Injector Issue Diagnosis
Results 1 to 9 of 9
  1. My New 2007 Crafter Project
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Howdy All,
    Ive just bought what Ill call, a fixer-upper for what I think is a bargain, though theres a fair list of bits to sort out. Main one being the engine not quite running properly.
    2007 MWB Crafter 134bhp 2.5 R5 TDi BJL Engine.
    Intention is to fix it, tidy it up and kit out out for my business, In my spare time Im a Mobile Mech mainly working on older VAG vehicles. Ive been using a 2011 Kuga for the last 6 months but Ive outgrown it and needed something more suitable and with more space etc.
    Ive had a quick look through it after it was delivered today, re-plugged the side door wiring as it was disconnected and both factory plugs ruined beyond repair. The side door does now work but its missing the plastic chain for the cable to run in.
    The interior lights also dont work, and the radio powers up but the screen wont come on so probably gonna replace it with a cheap android CarPlay one.
    Does anybody know where I can get the track and its fittings without buying the full harness as Ive cut the factory plug off the van side now and put my own on.
    I also need to figure the engine out. Im used to PDs and old petrols . Seller said he had it diagnosed as two bad injectors, it does run but is lumpy.
    VCDS doesnt pick up any faults on the ecu, Ill attach a picture of the injector readings at idle. Its not overly noisy. Just sounds like its missing, though iirc they are known to wear big end bearings out when injectors fail?
    How do I interpret the injector readings on this? (Picture at idle below)
    Any insight from people who have spent more time on them welcome. Itll be getting fixed regardless even if I have to pull the engine out and rebuild it.
    I also need to replace the key, I usually do this on Passat B5.5s etc with vagtacho and VCDS. Can anyone advise me on the procedure for this with the crafter as Im not sure vagtacho will retrieve the SKC.
    All the best,
    Aidan.
  2. Re: 2007 Crafter Suspected Injector Issue Diagnosis
    133 Post(s)
    1986 Post(s)
    That looks like 4 out of five have a problem but I would do 1 and 4 first. VAG doesn’t sell recon injectors for these and new ones at 874 each is daft but can get the Bosch exchange 0 986 435 352 for 150 although bear in mind the cost of shipping the old units back to Germany from certain suppliers.
  3. Re: 2007 Crafter Suspected Injector Issue Diagnosis
    Dec 2013
    11 Post(s)
    That looks like 4 out of five have a problem but I would do 1 and 4 first. VAG doesnt sell recon injectors for these and new ones at 874 each is daft but can get the Bosch exchange 0 986 435 352 for 150 although bear in mind the cost of shipping the old units back to Germany from certain suppliers.
    Thanks mate. Much appreciated. Ive found a company in the UK that seem to sell remanufactured Bosch injectors for the BJL at 99ea if I return the replaced unit to them.
    WTDiesel.com
    It does start and run. Had a quick look this afternoon before work and as follows. Injectors 1/2/3/5 if I pull the plug off, it nearly stalls.
    Injector 4, no change if I pull the plug off it.
    This is a cold start.
    Diagnosing an apparent injector issue on our “new” Crafter project. Inj #4 Not working.. - YouTube
  4. Re: 2007 Crafter Suspected Injector Issue Diagnosis
    133 Post(s)
    1986 Post(s)
    That is less than factor price never mind trade, tread carefully.
  5. Re: 2007 Crafter Suspected Injector Issue Diagnosis
    Dec 2013
    11 Post(s)
    Well,
    This is the list Ive come up with thus far. Big list. But nothing catastrophic this far I think.
    The Crafter
    MOT List:
    ◦Fix Engine (Injector #4 Hopefully)
    ◦Major Service
    ◦Timing Belt & WP
    ◦New Header Tank
    ◦Polish Headlamps
    ◦All 4 Shocks & Front Dust Covers
    ◦Number plates
    ◦Replace tail light units
    ◦Offside rear inner wheelarch/floor edge replacement
    ◦Both sides outer wheel arch replace
    ◦Both rear wheels bearings & seals
    ◦Rear Brake Pads
    ◦Wiper Blades
    ◦Rebuild drivers mirror
    Main Roadworthyness Jobs
    ◦Replace head unit
    ◦Get interior Light module repaired
    ◦Replace Keys
    ◦Deep Clean
    ◦Passenger door Check Strap
    ◦Side Door Cable Chain
    ◦Rebuild Aircon System and recommission
    ◦Retrofit Cruise Control
    ◦Replace Cluster if Possible (or bezel)
    ◦Fix Drivers door microswitch
    Cosmetic OCD Points
    ◦Get the wrap replaced where damaged
    ◦Replace side door (rotten inner bottom panel)
    ◦Replace rear drivers door (rotten lip)
    ◦Replace Seats
    ◦Replace Shift Boot
    ◦Replace Document Clip
    ◦Replace Window Switches
    Parts to order/Source
    ◦Timing Belt & WP Kit
    ◦Expansion Tank
    ◦Service kit
    ◦Front Shocks
    ◦Front Dust covers
    ◦Rear Shocks
    ◦Offside Rear inner Arch Panel
    ◦Both outer rear arch panels
    ◦Headunit (CarPlay)
    ◦Pressed plates & Holders
    ◦Gear Shift Boot & Frame
    ◦Offside rear door
    ◦Side door
    ◦Passenger door check strap
    ◦Air con pump/lines/condenser/exp valve etc
    ◦Nearside rear door inner trim panel
    ✓Fuel Injector
    ✓Document clip repair kit
  6. Re: My New 2007 Crafter Project
    Dec 2013
    11 Post(s)
    Well,
    Following up Ill start by saying I need to go out the lottery on
    I dont think it ever had a significant injector issue.
    I changed the injector on #4 and it was the same. So did a compression test which resulted in
    Cyl1- 23.5Bar
    Cyl2- 24Bar
    Cyl3- 24Bar
    Cyl4- Absolute Zero. Not even a needle flicker.
    Cyl5- 23.5 Bar
    On a cold engine as I couldnt exactly run it to warm it up.
    Going off the assumption that I couldnt see any debris in the cylinder on borescope through the injector port, and even with bad rings it should show some pressure. Assumed it was a valve issue.
    Blew compressed air through the compression testing adapter at TDC Comp Stroke and it blew straight out of the EGR Takeoff.
    So pulled the head today and found the exhaust valve spring had snapped on Cyl4 and wasnt letting the valve close. Its evidently been kissing the piston as shown by the incredibly clean face under said valve.
    How it never dropped the valve or snapped it off is beyond me. Lucky lucky me
    So all in all, Ill sort the head issues out and send it. Hopefully should be golden once its reassembled.
    Since Im now waiting for parts etc, figured Id do some turd-polishing and stick the new plates and surrounds on. What a difference small details make.
    Vid1 That’ll be why there’s no compression on #4 then 😅🤦*♂️ #repair #mechanic #automobile #vwcrafter - YouTube
    Vid2 The Reason my “New” Crafter wasn’t running properly. - YouTube
    Vid3 Suspected Spring issue 👀 #mechanic #repair #vwcrafter - YouTube
  7. Re: My New 2007 Crafter Project
    133 Post(s)
    1986 Post(s)
    I would start with a new AMC casting, it looks to me like it isn’t the first time the head has been off.
  8. Re: My New 2007 Crafter Project
    Dec 2013
    11 Post(s)
    I would start with a new AMC casting, it looks to me like it isnt the first time the head has been off.
    Im curious what makes you think that mate Always on a knowledge quest. Not often I dive this deep into engines.
  9. Re: My New 2007 Crafter Project
    133 Post(s)
    1986 Post(s)
    The machining on the head face looks very unoriginal, VAG explicitly state to not reface their Diesel heads.
  1. 2012 vw crafter can-bus issue
    By jakevwcrafter in forum The Commercial Range
    Last Post: 05-02-2021, 06:29 PM
  2. 2007 a4 BPW injector Hell!
    By Johnny 55 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-03-2017, 09:37 PM
  3. Question VW Crafter starter issue.
    By Jcbjeff in forum The Commercial Range
    Last Post: 12-01-2017, 10:01 PM
  4. Please Help VW Crafter 08 Reg Starting Issue
    By HelpwithCrafter in forum The Commercial Range
    Last Post: 11-06-2015, 08:56 PM
  5. Question Suspected ABS issue
    By cookie_vwpolo97 in forum Polo - Derby - Lupo - Fox
    Last Post: 01-12-2008, 09:48 PM
