Thread: 04 1.9 auy size of turbo/ egr vacuum pipes
  1. 04 1.9 auy size of turbo/ egr vacuum pipes
    May 2010
    edinburgh
    Hi there,
    As above! I have a leak in vacuum pipes somewhere, want to buy a 5 m roll and replace it all. Can someone tell me what guage I am looking for? Many thanks in advance.
  2. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    2012 Post(s)
    Going by the measurements on ETKA, you need 1110mm (360, 50, 320, 80, 300) of what they spec as 5x3 N 0202 282 1 and 3165mm (1000, 45, 70, 880, 300, 440, 350, 80) of 3.5x2 N 020 353 27.
  3. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    May 2010
    edinburgh
    Thanks for that. Am struggling to work out the size...is that 5mm and 3.2mm guage? Any suggestions where I can buy lengths to cut? Any would you by any chance have a vacuum pipe diagram! Appreciated.
  4. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    Mar 2010
    Derry ireland
    67 Post(s)
    THe inside dia on vac pipes must/has to be a 3.2mm to be a very snug fault
  5. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    May 2010
    edinburgh
    Thank you. I have bought 3 mm silicon piping, which apparently has a bit of stretch to it. If you think I have done the wrong thing please let me know! Cheers
  6. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    2012 Post(s)
    VAG call it 3.5 but as Mike says it really measures 3.2mm and certain applications it is 2.8.
  7. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    May 2010
    edinburgh
    Thanks. So will 3mm silicon pipe fit ok?
  8. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    2012 Post(s)
    You can make anything fit with some lubricant and if you push hard enough
  9. Re: 04 1.9 auy size of turbo/ egr vacuum pipes
    May 2010
    edinburgh
    Plenty lube...its going on!
  1. Audi 80 TDi vacuum pipes
    By Doctle Odd in forum 80 - 90
    Last Post: 04-03-2013, 11:19 PM
  2. vacuum pipes
    By crunchynutter in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2010, 08:15 PM
  3. 2002 a4 Tdi awx vacuum Pipes and hoses
    By maui_matt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-02-2010, 10:36 PM
  4. Golf V5 Breather, Vacuum Pipes Trouble
    By stinger in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2010, 01:19 AM
  5. Please Help 2002 a4 Tdi awx vacuum Pipes and hoses
    By maui_matt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2009, 11:49 AM
