Thread: High Beam assist for C7.5 Allroad Facelift with MATRIX
  1. High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2024
    Timisoara, Romania
    I am looking for the steps on how to change the high beam activation speed threshold on my facelift with Matrix. While working out with OBD11 team they told me my facelift doesn't have the control unit 20, does anybody know how can I modify this on my car? I have a VAG COM and OBD11 so any of them will do.
  2. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2024
    Timisoara, Romania
    Quote Originally Posted by HannibalM-2008 View Post
    Enter Module 20 (High Beam Assistance)
    Adaptation, select Channel 2 and set the new value.
    Default value should be 70, decrease it a little to reduce the activation speed threshold
    Him thanks for your reply but unfortunately on the facelift with Matrix at least I do not have the module 20.. that s my issue the rest of the headlight settings seem to be on module 55 but nothing regarding the high beam assist. any clue?
  3. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2024
    Timisoara, Romania
    Post a photo of the headlight!
    I can edit in a picture of it later but I think this should be even bettermodule 55 for me)
  4. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2024
    Timisoara, Romania
    You should try to activate address 20 in Gateway (19) via Vag-Com
    That's actually my first lead on this topic) how to do that ? i ll soon visit my coder friend for some engine updates and i can ask but there also something new i got, another friend of mine has one more camera under the mirror inside, not sticked to the windshield and he has the module 20. please just elaborate a bit what does activating it means and if it would be possible without that extra camera. also, can i do it now with my obd 11?
  5. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2013
    Reading
    31 Post(s)
    You cannot have adaptive/matrix headlights without a camera.
    So, what do you have? Post a pic.
    Sent from my KB2003 using Tapatalk
  6. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    My 2016 A6 Facelift had Matrix headlights, and AutoScan in VCDS didn't detect a Module 20 on mine. If it helps, this is a scan of the car from while I had it.
    Code:
    Monday,16,October,2017,15:30:30:07948
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    www.Ross-Tech.com
    VIN: WAUZZZ4G2GN139260   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 52
              53 55 5F 62 6C 72 85 8B 8E 8F 90 AC
    VIN: WAUZZZ4G2GN139260   Mileage: 29560km-18367miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 1649
       Revision: 85H23---
       Coding: 0A254012244401080000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: 79F2E728F8C65E8ECD-802C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
       Component: 0CK 20TDI RdW H04 0002
       Revision: --H04---    Serial number: 0000000421
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002020
       ROD: EV_TCMDL382021_AU57.rod
       VCID: 2952F76848E62E0EFD-807C
       Manual Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  HB1 0572
       Serial number: 75117051150260000373
    Address 03: ABS Brakes (J104)       Labels: Redir Fail!
       Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
       Component: ESP9 Premium  H01 0530
       Revision: --------    Serial number: --------------
       Coding: 06A29E49604579929B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 004018
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41824FC8D096C64EC5-8014
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
       Component: BCM2 2.0      H37 0572
       Revision: 00002001
       Coding: 01B8704E000000000000
       VCID: 7BFEFD20FAFA6C9EDF-802E
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 3215000194905008
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 20011600041500
       Coding: 34A109B8250000
       ASAM Dataset: EV_AirCondiComfoUDS 003008
       ROD: EV_AirCondiComfoUDS_003.rod
       VCID: 63CEA5406A4AB45EF7-8036
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
       Component: BCM1 2.0      H20 0311
       Revision: 14020001    Serial number: 00001249424202
       Coding: 0105001540349FE2C1014083A0001800CF9DC3082F08020100000894E100120200400009090000
       VCID: 70E4DA0CA3BC1FC67A-8024
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 151116  H38 0080
       Serial number:         151128193358
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 61226144
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 16 01 2016  00000718
       Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 4D190B08000000000001
    Address 10: Park/Steer Assist (J791)       Labels:* None
       Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0080
       Revision: --------    Serial number: 56261601401031
       Coding: B83B14
       ASAM Dataset: EV_EPHVA2CAU64X0000 001014
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 36682C14895871F660-8062
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Serial number: 00000000000000
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P10082051
       Coding: 30333130313630323533554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_AU57.rod
       VCID: 3B7E3D20B27AAC9E9F-806E
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB401A55AB6F0HU
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB401855AB699Q+
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB400U5558E61J$
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB400Q5558ESPCW
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB405T3K3IE8HQI
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB400A557QGG9ER
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Component: Lenks.Modul   H04 0005
       Revision: --------    Serial number: 90372OLI000CC
       Coding: 0004FC
       VCID: 3874222C8B4C878672-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Component: E221 - MFL  H08 0010
       Serial number: 17 11 2015  E0045264
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 987     HW: 4G8 920 987
       Component: TDieGb Acc    H11 0106
       Revision: 08001098    Serial number: 658140116596009
       Coding: 33860A000F552600010000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K.rod
       VCID: 76E8EC14C9D831F6A0-8022
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000002111233
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001028
       ROD: EV_GatewPkoUDS_001.rod
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 0364278803
       Voltage stabilizer:
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 19011600041254
       Coding: 22
       ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
       ROD: EV_ClimaContrUnitRearUDS_003.rod
       VCID: 3E783434A168B9B6B8-806A
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0157
       Revision: AA000000    Serial number: 00000181416385
       Coding: 0078130000006001000001010101102030303232203232
       VCID: 77F6E110C6D248FEBB-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820AUH9R
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
    Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0060
       Serial number: 0392857619
       Coding: 040312
       ASAM Dataset: EV_LaneChangAssis 001028
       ROD: EV_LaneChangAssis_AU21.rod
       VCID: 39722728B8469E8E8D-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0060
       Serial number: 0393010362
       Coding: 040312
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F16015E01628002080013
       VCID: 458A5BD8CCBEEA6EF9-8010
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H53 0202
       Revision: 00000003    Serial number: 0000568092
       Coding: 101101010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106_AU57.rod
       VCID: 3A703824BD40959684-806E
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0392248694
       Coding: 011B062280B90080C32008840C010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 A
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Component: Dachelektroni  H10 0100
       Serial number: 0000000AP00017911223
       Coding: 010000
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0511
       Coding: 011F16015E01628002080002
       VCID: 46885CD4F1B8E176F0-8012
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
       Component: EPB-4         H05 0017
       Revision: --------    Serial number: 00000001707817
       ASAM Dataset: EV_ParkiBrake 001029
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 31621F08603656CE35-8064
    Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
       Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0100
       Coding: 04FE02202A170200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
       ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
       VCID: 346C161C9F2463E65E-8060
       Led Headlamp Powermodule Left:
       Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7560
       Coding: E01F00
       Led Headlamp Powermodule Right:
       Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7560
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 021 D    HW: 4G1 035 021 D
       Component: MU-H-LND-EU   051 0389
       Serial number: A733A0GB004822
       Coding: 017501010000000013111102000A00132F0006E7F17001009F
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
       VCID: 1B3EDDA012BACC9E7F-804E
       Data medium:
       Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
       Component: ECE 2016  --- 0134
       Serial number: --------------------
       Display unit 1 for multimedia system:
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Component: DU8 C7 SV  H63 0007
       Serial number: AUZ8Z9FY803UXN
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
       Component: E380 BDT C7  H20 0250
       Serial number: 90349PAJ00038
       Compact Disc Database:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1012
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0511
       Coding: 010F14004001628002080002
       VCID: 499257E8E0A60E0E1D-801C
    Address 6C: Back-up Cam. (J928)       Labels:* None
       Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
       Component: TopView       H09 0361
       Revision: 11001001    Serial number: 82330JG0138702
       Coding: 0211000001000000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2F6619707602403E23-807A
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H03 0511
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Revision: --------    Serial number: 262130025421000
       Coding: 6A160000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C5C0E7C47143B2606-8078
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 2756F1505EF2187EEB-8072
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000621401167
       Coding: 04C239181111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
       Component: RGS-VL        H14 0080
       Coding: 0066E608031F0376070308004240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
       Component: RGS-VR        H14 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 3260100465306DD64C-8066
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 153311103
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100_008.rod
    End-------------------------(Elapsed Time: 05:59)--------------------------
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: High Beam assist for C7.5 Allroad Facelift with MATRIX
    Mar 2024
    Timisoara, Romania
    Quote Originally Posted by Johnny31 View Post
    I do have the camera above the rain sensor but not the one below the mirror as in this attached pic. However, I for sure do have matrix as I have seen them work, not only auto on off high beam. so yea, weird but not sure what s going on..camera.jpg
    And this is what I have: far.jpgmycam.jpg
  1. Matrix LED head lights set auto high beam assist to always on?
    By sanstorm999 in forum Audi A5 - B9 Forum - 2016-
    Last Post: 13-01-2023, 06:17 PM
  2. B9 High Beam Assist
    By Simon12001 in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 26-04-2021, 06:41 PM
  3. High Beam Assist Help Please
    By dt-tdi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-02-2019, 10:36 AM
  4. How to use high beam assist?
    By Rauf786 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-10-2016, 01:38 PM
  5. High Beam assist
    By sabingli in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-06-2011, 05:49 PM
