Thread: Mk3 16 plate TDI 184 FR clutch issue.
  1. Mk3 16 plate TDI 184 FR clutch issue.
    Mar 2024
    Monmouth, UK
    Hi all, newbie mechanic question, any advice appreciated. Clutch pedal sticking down, replaced the master cylinder was okay initially and then the issue returned after a couple of hours. Can’t see any leaks or air when bleeding. Assume it’s the slave cylinder issue which I’m guessing on a 16 plate TDI 184 FR is internal so clutch out time (beyond my skills or tools)?
    Thanks,
    Dave.
  2. Re: Mk3 16 plate TDI 184 FR clutch issue.
    2005 Post(s)
    Yes the release bearing commonly called a “concentric release bearing” in this case is inside the bellhousing so box out. We have had a couple of incidences where the damper in the pressure line causes pedal drop so now the order we do the job in is master and line with damper then see what happens, it ends up being successful a small percentage of the time but the pain of replacing the clutch/DMF and still having the problem is very unpleasant.
  3. Re: Mk3 16 plate TDI 184 FR clutch issue.
    Mar 2024
    Monmouth, UK
    Hi Crasher, yes that makes sense, thanks for the great advice. Is there anything else you would do as a “while it’s out”. It’s only done 35k miles.
  4. Re: Mk3 16 plate TDI 184 FR clutch issue.
    2005 Post(s)
    That is very low milage. The usual action would be to insist on a four piece clutch DMF kit but even with my mega fussy mechanic hat on I am tempted to say just the bearing… dilemma!
  5. Re: Mk3 16 plate TDI 184 FR clutch issue.
    Mar 2024
    Monmouth, UK
    Thanks again for the advice, I’m only double checking as half the mileage is towing a transporter trailer with weight close to the limit. It’s a great towing car!
  6. Re: Mk3 16 plate TDI 184 FR clutch issue.
    2005 Post(s)
    Ahh, I would be thinking about the Sachs X-Tend kit with DMF.
  1. Clutch Pedal or Clutch and Pressure Plate Issue?
    By steamship in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 05-02-2019, 05:54 PM
  2. Question Clutch, DMF and Pressure Plate Re-Use?
    By kylelnsn in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-06-2018, 01:30 PM
  3. Question Clutch problems - '53 plate A3 2.0 FSI
    By far2tall in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-11-2014, 08:18 PM
