Thread: VW Golf TDi Intermittant smoke
  1. VW Golf TDi Intermittant smoke
    Mar 2024
    Ireland
    Hi, I am new to this forum but looking for some help from someone who may have seen this issue before and can help.
    Car is 2012 VW Golf MK6, 1.6 TDi BlueMotion with 120k miles on the clock.
    Problem - car intermittently bellows out smoke from the exhaust every few days then stops and runs normally. There is no loss of power when this is happening but on idle, the rev counter moves up/down very slightly/flickers.
    It happens when the car has not fully warmed up and does continue sometimes for 20 minutes after reaching temperature.
    The EGR has been blocked several years ago as it was giving trouble at the time. The car has run fine since this was done.
    Attemps to clear the problem so far -
    Full service completed, oil changed etc
    No evident loss of oil or coolant
    DPF taken off and cleaned
    Thermostat changed
    Car has had several long runs 50+ miles, still the problem returns
    DPF light comes on occassionally during the problem
    Smell of fuel when the car is smoking heavily
    It will continue to happen until the car has a longish run, then returns a few days later
    I do have a video of the problem but unable to post it on here as its an MP4.
    Thanks in advance for your help and opinions on this, hoping some one has seen it before and can advise on a fix.
  2. Re: VW Golf TDi Intermittant smoke
    135 Post(s)
    2026 Post(s)
    Probably injectors failing and removing the EGR causes a sharp rise in combustion temperatures which massively increase combustion temperatures which can overheat and damage the Diesel Oxidation Catalyst in the front section of the DPF case.
  3. Re: VW Golf TDi Intermittant smoke
    Jun 2024
    England, UK
    Welcome to the forum, @Shay Flanagan!
  1. Golf Mk5 1.9 TDI (BKC Engine) Intermittant Starting
    By tdot in forum Golf MK5 - 2004 - 2009
    Last Post: 22-01-2014, 12:34 AM
  2. Question Golf Mk4 1.9 TDI Intermittant Starting
    By tdot in forum Golf MK4 - 1999 - 2004
    Last Post: 17-08-2013, 08:06 PM
  3. Please Help Golf intermittant power loss
    By john493 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-08-2009, 02:29 PM
  4. intermittant smoke 1.8T 20V
    By sined in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2008, 10:12 AM
  5. 95 Golf CL 1.6 intermittant startup dying
    By johnhenson in forum Golf MK3 - 1993 - 1999
    Last Post: 04-12-2007, 10:21 AM
