Thread: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #11
    Apr 2018
    Just checked the pins on the d plug in the bulb holder. Not sure which pin the earth is but there are about 7 pins and all clean and ok. i thought id mention as i read somewhere that the TPS problems can be linked somehow . currently the bulb failed light is on for the rear brake light, but the actual bulb is working ?!?!?!
  2. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #12
    2007 Post(s)
    Earth is the brown wire.
  3. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #13
    Apr 2018
    Cleared the faults and they haven't returned. It has been losing power still but not enough to trigger engine light it seems 🤔 yes earth terminal is fine. Safe to say glowplugs are ok and other fault nay be causing them to flag?
  4. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #14
    Mar 2017
    Hampshire UK
    If it's any help, I occasionally get the flashing glowplug light with 'visit workshop' message when braking. Soon after that the left brake light bulb will usually fail.
    1 person in 10 understands binary, the other one doesn't.
  5. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #15
    Apr 2018
    Yes this is what i get, no power problems for you though??
  6. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #16
    Apr 2018
    Actually not under braking. It says the left bulb has failed and it hasn't.
  7. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #17
    Mar 2017
    Hampshire UK
    When it happens on mine, a touch of the brakes brings the fault up, but the warning with the flashing light will stay for 10-15 minutes then go out and back to normal. The bulb may not have failed, but changing it anyway usually sorts it.
    As a curiosity, do you have a towbar fitted?
  8. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #18
    Apr 2018
    Yes it does have a towbar. The car starts up and runs fine so possible that the glow plug fault and throttle fault are completely separate issues? Have you scanned yours to see if it throws and faults?
  9. Re: Touran 1.9TDI Throttle Sensor/Glow Plug Fault
    #19
    Apr 2018
    Changed the pedal with a one from a caddy, no problems since
  1. Touran 1.9tdi intermittent no glow plug light- not starting
    By Jambory25 in forum Touran - Sharan - Caravelle
    Last Post: 18-10-2020, 12:08 PM
  2. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  3. glow plug change 1.9tdi
    By smithy602179 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2013, 03:29 PM
  4. A4 1.9tdi EML fault liknked to Glow plug
    By bigvinnie5737 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2012, 01:53 PM
  5. Please Help No glow plug power - 1.9TDi
    By DubDick in forum Golf MK3 - 1993 - 1999
    Last Post: 24-10-2010, 12:39 PM
