Thread: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
Results 1 to 10 of 11
  1. S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    I've had this light come on and diagnosed via Carista as P0132 - 02 Sensor Circuit High Voltage Bank 1 Sensor 1. It also comes up with 18115 - O2 Sensor Circ.,Bank1-Sensor1: High Voltage which I assume means the same thing but within the basic OBD functionality.
    As such I have procured two new sensors for Banks 1 & 2 as the car is at just over 95K miles so though it best te replace them both.
    My queriy is - I believe the Sensors are located before the Catalytic converter. If so exactly where are they located within the engine bay. I can see what I think is one, just behind the aluminium cover that sits under the plastic engine cover approximately where the arrow is, but cannot see the other one. Is it likely to be under the aluminium cover?
    Any assistance or images most ghratefully appreciated as I think I am capable of changing them myself. I have recently changed the Oil Separator and PCV hose fitting as a result of other issues
    Thanks in advance
  2. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    133 Post(s)
    1988 Post(s)
    Yes S1 is pre cat and bank 1 is the right, what is the VIN?
  3. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    Hey Crasher, thanks for the prompt reply
    The VIN is WAUZZZF51JA038723. Am I right in thinking the arrow indicates one of the sensors, but I cannot obviously see the other?
    Thanks again for your assistance
  4. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    133 Post(s)
    1988 Post(s)
    That looks like sensor 1, new part number 06M 906 265 and £277.07
  5. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    Any guidance on where the bank 2 sensor 1 is located as I'd like to replace them both at the same time given the miles I've done?
    I've sourced Ridex Lambda Sensor part no 3922L0988 as an OEM replacement that matches that part number
    Is the bank 1 sensor 1 location the one I arrowed on the image that is very easy to see?
  6. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    133 Post(s)
    1988 Post(s)
    NO! Only use genuine or Bosch and the OE numbers 8W0 906 265 K (original) and 06M 906 265 (supersession) do not cross reference Ridex 3922L0988 using the trade system TecDoc, that number replaces OE numbers.
    04E 906 262 CS
    05E 906 262 A
    06K 906 262 DB
    4N4 906 265 L
    8W0 906 265 AC
    8W0 906 265 M
    8W0 906 265 N
    Ridex do state that 3922L0988 is for your car but they don't cross reference it. There is no decent aftermarket alternative, not even Bosch or NTK.
  7. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    Thanks Crasher
    I've spoken to a numbner of Audi dealers who are telling me there is no stock in the UK or indeed in Germany
    ANy ideas how I can get around the issue.
    When you say Bank 1 is on the right, I assume that means drivers side (off side). Also where is the Bank 2 sensor located?
  8. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    133 Post(s)
    1988 Post(s)
    The handing of cars parts is always observed as sitting in the car looking forwards. As it is a single turbo and cat (actually an odd design) it only has one pre and one post cat lambda sensors unlike most V engines which would have two. I have checked stock with my TPS and the Dorden VAG UK main parts warehouse has three 06M 906 265 in stock so someone is being incompetent.
  9. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    Again, thank you for your guidance and insight. I have called my local TPA who depsite supplying me directly with an OIL Separator and PCV Hose recenlty now say they cannot supply direct to the public so I have to go through a local garage. They have confrimed there are three in stock as you say so yes I was misinformed by my local Audi main dealer althioiught that was last week!
    Just got to find a friendly dealer who will allow me to buy as I am happy to fit myself. I may try and locate one through a breaker as I am planning to part ex it in three or four weeks for a newer one if I can find one I like the look of as I absolutely love it. Currently Navarra Blue so may go Daytona Grey or Red
    Thanks again
  10. Re: S5 ECS Light & Lambda (02) sensors (MY 09/2017)
    May 2017
    Worcester
    UPDATE
    So, after replacing the Lambda sensor I still had the ECL warning light on, so gave in a n and booked it in with a local Audi specialist. The sensor was probably fine as the issue was rodent damage to the cable resulting in a voltage drop between the fuse and the sensor.
    Now all sorted and back to normal - Loving it again
    On a separate note I am just about to flip over 100k miles, have had oil service recently, new pads & discs all round, rear coil springs plus upper and lower mounts replaced (OSR corroded & NSR broken), NS & OS rear spring seats replaced (split), NS & OS rear arm bushes and arms replaced at 62k miles, brake fluid replaced at 67k miles with an MOT due at thge end of June.
    I am thinking I'm going to keep the car as really enjoy it, however it would be good t know if there's anything I need to be thinking about checking / replacing etc or any known issues to be aware of in a car at this level of mileage
    Any guidance is most gratefully received
  1. lambda sensors
    By Gordy180 in forum Chat - Anything with wheels
    Last Post: 02-12-2008, 01:08 PM
  2. Lambda Sensors
    By Rhysj44 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-05-2008, 10:03 PM
  3. Is it my lambda sensors?
    By kurtis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-01-2008, 06:31 PM
  4. mk3 Lambda sensors?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-01-2008, 12:40 AM
  5. a4 engine management light new cat converter? Lamber / Lambda sensors?
    By TimBowling in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2007, 03:51 PM
