Thread: A6 C6 CAHA oil pump shaft
  1. A6 C6 CAGB oil pump shaft
    Mar 2024
    Lithuania
    Hello,
    Do 2009-02 registration A6 C6 2.0tdi CAGB 100kw have 77mm or 100mm oil pump shaft?
    Is it recommended to replace it even if it has 100mm one?
    WAUZZZ 4F99N041837
  2. Re: A6 C6 CAGB oil pump shaft
    2007 Post(s)
    Up to 19-10.2009 77mm, yours was built 11-02-2009
  3. Re: A6 C6 CAGB oil pump shaft
    Mar 2024
    Lithuania
    Oh no. Still had hopes that the e version may get it sooner. :|
    Any chance to inspect whether it was rebuilt with 100mm from outside without removing sump?
    It has 470k km on the clock, I highly doubt that it has original 77mm
    I guess if it was rebuilt with 100mm by audi I may find records on that.
  4. Re: A6 C6 CAGB oil pump shaft
    2007 Post(s)
    Quote Originally Posted by citizen View Post
    No way possible.
  1. CAHA engine 2.0 tdi have oil pump 77mm key issue??
    By lmcc877 in forum Buying a used VAG Group vehicle
    Last Post: 22-06-2025, 12:34 PM
  2. B7 oil pump balance shaft?
    By Imran in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 11-05-2016, 06:16 PM
  3. oil pump balance shaft hex key
    By waynetdi130 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-08-2015, 10:39 PM
  4. Oil pump balancer shaft
    By mission66 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2010, 08:10 AM
  5. 2.0 TDI Oil Pump Balance Shaft Problems
    By Jack Ford in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-01-2010, 07:01 PM
