Thread: Yaw Control Wiring Location
Results 1 to 10 of 14
  1. Yaw Control Wiring Location
    Mar 2024
    Worthing
    Does anybody know where the wiring from the yaw control (under back seat ) goes ? It goes back to the bottom of the rear seats but unsure where it goes after that ?
    I have an error message 01425 Rotation Rate Sensor, Reference Wire.
    It appears to be keeping my TC light on, other errors have slowing disappeared including brake sensor and steering angle sensor, I had my abs ECU rebuilt as well.
    I believe it is trying to tell me there is a fault in the wiring somewhere ?
  2. Re: Yaw Control Wiring Location
    134 Post(s)
    2019 Post(s)
    It goes back to the ABS and engine management, remind me Monday and post the VIN.
  3. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    OK thank you
    Do you know if this is a common fault ?
  4. Re: Yaw Control Wiring Location
    134 Post(s)
    2019 Post(s)
    I have seen a few fail in the very late 3B Passat and a couple on the A4 and with a New Beetle they are a joke. One made me laugh, the customer stated that every time someone sat in the back seat the ESP light would flicker and the car start twitching and behaving oddly. When I lifted up the seat base I found a mouldy banana skin on top of the sensor.
  5. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    Well you probably can't get them new (and I don't think I'd like to pay the price !), so am I just going to have to buy second hand ones until I find one that works ?! 😄
  6. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    VIN number is WAUZZZ8H35K022949
  7. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    I'm now getting messages that the main ECU can't communicate with the and pump ?!
    Get message P1649 can't communicate with abs module - intermittent.
  8. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    Just found something, not sure it's relevant. When checking the codes, Section 3 for Brakes,
    CAN Data Bus Communication 125
    Steering angle sensor (G85)
    Steering angle 1
    Transmission
    Engine 1
    Engine
    Transmission 0
    Instrument cluster
    Combi 1
    These should all be '1' shouldn't they to say they are all communicating ?
    Mine is a manual car if it makes any difference?
  9. Re: Yaw Control Wiring Location
    134 Post(s)
    2019 Post(s)
    It won't show the trans on manual as it has nothing to talk to.
  10. Re: Yaw Control Wiring Location
    Mar 2024
    Worthing
    ECU has been sent back
  1. Radiator Fan Wiring and Relay Location?
    By adzyp in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 07-07-2023, 05:04 PM
  2. Amplifier location and wiring diagram?
    By Alex jb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-10-2016, 06:50 PM
  3. Wiring location help
    By Chappers in forum Golf MK4 - 1999 - 2004
    Last Post: 07-06-2013, 03:35 PM
  4. Question air bag light/control module location
    By bilbo136 in forum 80 - 90
    Last Post: 30-03-2010, 10:08 PM
  5. TT Airbag ECU / SRS Control Unit Location
    By gilesbennet in forum TT - 8N Forum - 1998 - 2006
    Last Post: 14-02-2008, 10:01 PM
yaw
