Thread: Rear Camber adjustment
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Rear Camber adjustment
    #11
    Sep 2019
    Glasgow
    I got 4 wheel alignment done on a previous 2018 Passat I had and there is little to adjust with the rears.. When I got the print out the rears hardly adjust so basically a waste of money with really only the fronts done properly.. Like the Mk6 & 7 it’s a poor setup wasting thousands of miles with the inside of rear tyres wearing a lot.. A humming sound (similar to a bad bearing) is noticeable at a higher speed when insides wear.
  2. Re: Rear Camber adjustment
    #12
    2007 Post(s)
    There is a lot of camber adjustment and enough toe to deal with anything (at least +/- 2°) IF the toe bolts are not seized inside their bushings, the camber bolts never seize. If adjustment is made with the toe bolts seized, the bushes rapidly fail.
  1. 2004 B6 S4 rear camber adjustment
    By charlie wade in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-05-2015, 11:01 PM
  2. Rear camber adjustment?
    By G60JONNY in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-05-2015, 10:42 PM
  3. Question Dangerous lateral movement Ctnd.....Serious wear rear tyres/Rear Camber adjustment Quattro
    By germaniaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-11-2014, 08:12 PM
  4. Rear camber at limit of adjustment
    By UVB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-08-2013, 12:23 PM
  5. Question V6 rear wheel camber adjustment ?
    By MediaAssassin in forum Golf MK4 - 1999 - 2004
    Last Post: 22-06-2009, 04:59 PM
