Thread: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
  1. 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    Oct 2009
    Essex
    I've temporally come out of retirement to help out a very close friend, who's having issues with the coolant fan starting up with just the ignition being switched on! I've pretty much checked everything I can think of (connections etc), and yes it does point to the the fan unit J293. I was loaned another fan unit off another galaxy (same year) and connected that to the car and exactly the same thing happens. Which makes me think, what are the chances that BOTH could be US!
    So anyway here's a complete scan using VCDS:
    Code:
    Monday,19,February,2024,17:26:49:55488
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 23.3.1.0
    Data version: 20230421 DS346.2
    Ross-Tech: Home
    Dealer/Shop Name: Airmec Engineering
    Workshop Code: 444 12345 012345
    Chassis Type: 7M - VW Sharan (1996 > 2010)
    Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 35 36 37 39 45 55 56
              76
       Mileage: 211870km-131649miles
    Address 01: Engine        Labels: 038-906-019-AJM.lbl
       Part No: 038 906 019 LD
       Component: 1,9l R4 EDC G000SG  1595
       Coding: 00002
       Shop #: WSC 00020
       VCID: 64CCB68CF4837FB34F-4A6A
    1 Fault Found:
    18080 - Coolant Fan Control 1
                P1672 - 35-10 - Open or Short to Ground - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7M3-907-37x-ABS.clb
       Part No: 7M3 907 379 D
       Component: ABS FRONT MK25      0102
       Coding: 0007689
       Shop #: WSC 00020 000 00000
       VCID: 3E7824E46AAF7563F9-50AC
    No fault code found.
    Address 08: Auto HVAC        Labels: 7M3-907-040.clb
       Part No: 7M5 907 040 L
       Component: CLIMATRONIC MPV GP  0005
       Coding: 00011
       Shop #: WSC 00020
       VCID: 397237F82381525BCC-254E
    Address 09: Cent. Elect.        Labels: 7M3-962-258.lbl
       Part No: 7M3 962 258 AD
       Component:    Multifunkt.Einh  0001
       Coding: 04113
       Shop #: WSC 00020
       VCID: 7CFCEEEC6C33A77397-5038
    2 Faults Found:
    00955 - Key 1
                09-10 - Adaptation Limit Surpassed - Intermittent
    00973 - Switch for Heated Rear Window (E15)
                28-00 - Short to Plus
    Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
       Part No: 1C0 909 605 F
       Component: 0E AIRBAG VW61 0Q0M 0003
       Coding: 12357
       Shop #: WSC 00020
       VCID: 2756E180C535D4ABAA-5072
    1 Fault Found:
    00532 - Supply Voltage B+
                07-10 - Signal too Low - Intermittent
    Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
       Part No: 7M5 920 920 S
       Component: KOMBIINSTRUMENT VDO V59
       Coding: 13401
       Shop #: WSC 00001
       VCID: 428050144E5711839D-508E
    Address 18: Aux. Heat        Labels: 7M3-815-071.clb
       Part No: 7M3 815 071 A
       Component: HEIZG. B/D5W       0001
       VCID: 2E5814A4EACF85E369-50E6
    5 Faults Found:
    01492 - Function Lock-Out
                35-00 - -
    01409 - Repeated Flame-Out
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    0001
       Coding: 00006
       Shop #: WSC 00020
       VCID: 70E4CADC307BD3133B-508E
    Address 76: Park Assist        Labels: 7M3-919-283.clb
       Part No: 7M3 919 283
       Component: Parkingsyst. SH RDW D02
       Coding: 00117
       Shop #: WSC 00020
       VCID: 77F6F1C05515842BFA-50AC
    1 Fault Found:
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                37-00 - Faulty
    End-------------------------(Elapsed Time: 05:25)--------------------------
    There's a fine line between genius and insanity!
  2. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    131 Post(s)
    1973 Post(s)
    From what I can see it is different to the VW system but possibly the fan controller YM21-8C616-AA
  3. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    Oct 2009
    Essex
    Thanks Crasher
    Been going through all the wiring tracks for a 2003 Sharran TDi with the same Engine code, but I cant help but think Fords have 'personalised' VW's fine work just to make the vehicle slightly different!
  4. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    Mar 2010
    Derry ireland
    63 Post(s)
    theres a reasion for this. The cooling fan/fans has to be contr0lled s0 that allows the engine to maintain a constant running temperature
  5. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    Oct 2009
    Essex
    So here's the latest, I've still got this damned motor stuck up my ****!
    So after buying a 20 quid multimeter off Amazon that reads PWM & Hertz I was then able to read of the signal from the ECM, which was giving around 0.25 volts & 5% Hz. When the engine runs, this signal doesn't move which then makes the fan run flat out. Next move was to buy a PWM generator module off Amazon, (only 8 quid) and after wiring this up to the fan module set at 100 Hz and adjusting the output from 5-90% still no joy, fan ran flat out.
    So as these Bosch fan modules (similar to BM's and Volvo's) suffer from problems, I then decided after looking at other VAG models and their wiring tracks, I could possibly convert to a different fan and module. So a trip to Stevens VW breakers I sourced and tested with the PWM generator a Tiguan fan with a external control unit. This fan also had an identical wire code to the Galaxy.
    Got this home and laid the unit across the top of the engine and connect the fan plug to it, guess what? Fan when the ignition was turned on did exactly the same as before, it started up and ran flat out! Carried a re-scan with VCDS only to find the original fault code was still there and wouldn't clear. 1 Fault Found:18080 - Coolant Fan Control 1 P1672 - 35-10 - Open or Short to Ground - Intermittent Readiness: 0 0 X X X!
    So it seems there is a short or an open circuit somewhere that I'm having trouble finding somewhere, which is possibly a broken wire. Had another look at advanced measuring values on VCDS, all looks okay
    except for G8, which I think is from the sump sensor, but I can't see that affecting the fan issue, or could it?
  6. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    131 Post(s)
    1973 Post(s)
    Run a new “overlay” AKA bodge wire from ECU to fan module.
  7. Re: 2003 Ford Galaxy (Sharan) 1.9 ASZ TDi Fan Control Module Issues.
    Mar 2010
    Derry ireland
    63 Post(s)
    First check on this has to be the coolant temp sensor resistance taken at cold should read approx 2-3 k the very most likely cause of your problem with the high speed fan
  1. Please Help audi a6 c5 2003 comfort/convenience control module problem. help needed.
    By rokis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2015, 01:50 PM
  2. Please Help Issues after fuel pump control module replacement
    By EdB80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2015, 11:54 PM
  3. 06 Sharan Comfort COntrol Module
    By Safetyman67 in forum Chat - Anything with wheels
    Last Post: 25-04-2014, 11:43 AM
  4. ABS control module location in Sharan 2000?
    By alay111 in forum Touran - Sharan - Caravelle
    Last Post: 19-05-2012, 02:50 PM
  5. A Ford Galaxy with a VW engine - help please
    By fat controller in forum Chat - Anything with wheels
    Last Post: 04-08-2010, 09:25 PM
