Thread: Electrical ISSUEs
  1. Unhappy Electrical ISSUEs
    Ok, so this is my first post... I have poked around a bit to see if i could find simalr problems, but alas, i have not...
    I have an 02 A6 4.2q... ok here are the issues... my elctrical system seems to be flaking out...
    first it was the back up sensors.... just stopped working, fuses good...(not fixed)
    followed by intermitant brake waring light, (disappeared recently)
    all of these i are liveable with out.
    however i have noticed the the ac fan is constantly running, even when the Ac is not running... poking around abit i noticed the the internal radiator fan is not working at all...
    i traced the cabling (roughly) to a box with other similar cables unsure which one to disconnect to ohm out the fan... kinda reluctant to just start disconnecting cables, in the engine bay, ya know?
    I tried to find the relay panel that controls it but can seem to.
    all fuses in main box check out ok, with voltmeter...
    I am reluctant to jump out and spend a fortune at the dealership, just yet... so i was wondering if anyone here might share some insight, before i plop down hundreds of dollars for troubleshotting....
  2. Re: Electrical ISSUEs
    May 2007
    I suffered warning light issue, was down to water ingress, due to the drain plug under the battery clogging filling up the pelumn chamber below the windscreen.
    Is yours dry or wet ?
  3. Re: Electrical ISSUEs
    Jul 2007
    Cheshire, or my A6
    Yes, the Plenum chamber is a common fault. Check your passenger footwell for the electrics box, if everything round there is soaked then that will be the problem. Easiest way to check is pull up the carpets and check they are not wet underneath. There was a recall about it.
    Paul
  4. Lightbulb Re: Electrical ISSUEs
    it is dry...
    but will check more thoughly around the battery area when i have better daylight...
  1. electrical faults
    By revres in forum New Member Introductions
    Last Post: 12-11-2007, 01:08 AM
  2. Weird electrical issues?
    By 72beetle2audiA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-04-2007, 05:00 PM
  3. VW Golf 2004 New model electrical issues
    By barticas in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 05:16 PM
  4. Electrical Problem
    By kevybhoy in forum Audi A4 - Archive Topics
    Last Post: 01-03-2007, 04:43 PM
  5. Passat 2002 electrical 'issues'
    By deadnapster in forum Passat - Archive Topics
    Last Post: 01-02-2007, 09:22 AM
