Thread: Electric Steering Rack Issue
Results 1 to 10 of 19
  1. Electric Steering Rack Issue
    Feb 2024
    Durham
    Hello All,
    Few weeks ago I had a steering rack fault and the amber warning light saying steering assist fault, I can continue to drive intermittently while driving. I decided to get the steering rack refurbished at western power steering. When I gone to pull my car into the garage to take the rack off the car the red amber light shown with something along with the lines of do not drive warning message.
    So i thought yeah the rack has defiantly gone, so I took the rack off and sent it away to get refurbed. I have fitted the rack this weekend and all seems well until today where the amber warning light has reappeared after just having the rack refurbed
    I have scanned the car with vagcom and here is the findings.. anyone able to help me with this issue as I'm getting a bit annoyed with it.
    Thank you in advance.
    Code:
    Monday,19,February,2024,18:45:59:37351
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.2.0
    Data version: 20150311
    Ross-Tech: Home
    VIN: WAUZZZ8K5DA026355   License Plate:
    Mileage: 239950km-149098mi   Repair Order:
    Chassis Type: 8K (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 6D 72 77
    VIN: WAUZZZ8K5DA026355   Mileage: 239950km-149098miles
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CGLC)       Labels: 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JH    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9977
       Revision: 45H25---
       Coding: 12194012242601080000
       Shop #: WSC 26446 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018JH 003004
       ROD: EV_ECM20TDI01103L906018JH.rod
       VCID: 79F23D93F848B5E9291-802C
    4 Faults Found:
    5380 - Valve for Air Filter Bypass Flap (N275)
              P1016 00 [040] - Open Circuit
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 29
                        Mileage: 239916 km
                        Date: 2024.02.18
                        Time: 14:24:50
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [101] - Electrical Fault
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 239925 km
                        Date: 2024.02.19
                        Time: 13:11:31
    4987 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [101] - Electrical Fault
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 239925 km
                        Date: 2024.02.19
                        Time: 13:11:31
    17403 - Implausible Data Received from Parking Brake Control Module
              U0417 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 239925 km
                        Date: 2024.02.19
                        Time: 13:12:26
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Component: ESP8 quattro  H09 0100
       Revision: --------    Serial number: --------------
       Coding: 18554C
       Shop #: WSC 06334 000 00000
       VCID: 040C5C67878AF8014A7-8051
    2 Faults Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 199
                        Mileage: 239925 km
                        Time Indication: 0
                        Date: 2024.02.19
                        Time: 13:12:25
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x4082
                        Hex Value: 0x001A
                        Hex Value: 0x02AF
                        Hex Value: 0x0000
    01044 - Control Module Incorrectly Coded
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 199
                        Mileage: 239935 km
                        Time Indication: 0
                        Date: 2024.02.19
                        Time: 14:13:11
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0015
                        Hex Value: 0x1096
                        Hex Value: 0x0000
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 FG    HW: 8K0 907 064 FG
       Component: BCM2 2.0      H10 0602
       Revision: 00002001
       Coding: 03B20000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 7AF0229FF54EBEF120B-802F
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Component: J764 ELV MLB  H40 0046
    No fault code found.
    Address 08: Auto HVAC (J255)       Labels: None
       Part No SW: 8K2 820 043 AD    HW: 8K2 820 043 AD
       Component: KLIMA 3 ZONEN H04 0123
       Revision: D1000000    Serial number: 01230220120773
       Coding: 342402E000
       VCID: 6BDE17DB8A141779ABD-803E
    2 Faults Found:
    00457 - Control Module for Network (J519)
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 158
                        Mileage: 239916 km
                        Time Indication: 0
                        Date: 2024.02.18
                        Time: 14:23:40
    00256 - A/C Pressure/Temperature Sensor (G395)
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 158
                        Mileage: 239916 km
                        Time Indication: 0
                        Date: 2024.02.18
                        Time: 14:23:41
                 Freeze Frame:
                        Temperature: 15.0∞C
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000379744102
       Coding: 260000108034AFC00081400300001D0D0F1D070827090201000008000400030100000024000000
       Shop #: WSC 00762 210 89838
       VCID: 78F43897CB42ACE156F-802D
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 180212  H06 0070
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Component: G397_RLFS  H06 0002
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
       Component: E1 - LDS  H03 0031
       Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H02 0002
    1 Fault Found:
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 158
                        Mileage: 239916 km
                        Time Indication: 0
                        Date: 2024.02.18
                        Time: 14:23:40
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
       Component: AirbagVW-AU10 H45 0610
       Serial number: 003KFD917FSP
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 39620 001 1048576
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 48948857F3221C61E6F-801D
       Crash sensor for side airbag; driver side:
       Serial number: 6334MSME6516067FJ
       Crash sensor for side airbag; front passenger side:
       Serial number: 6344MSME6B456C67V
       Crash sensor for side airbag; rear; driver side:
       Serial number: 6352QSME740D1376I
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 6362QSME6F0B2360L
       Crash sensor for front airbag; driver side:
       Serial number: 63732SME3E0D14641
       Crash sensor for front airbag; front passenger side:
       Serial number: 63832SME076D1A789
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120223000773
       Coding: 000017
       VCID: 4FA6A34B1E4CCB59A75-801A
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 B    HW: 8K0 920 982 B
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTE5A882D
       Coding: 3305110002012600010000
       VCID: 336ECFBB92A48FB9A3D-8066
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8R0 907 468 A    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H10 0025
       Revision: 1V040013    Serial number: 1341V12215825A
       Coding: 00CF07FF00
       VCID: 3D7AE983A4E049C9459-8068
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
       Component: J532_DCDCStab  H05 0006
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000023868823
       Coding: 011C02205001410001
       VCID: 4D9AB9431440F949D59-8018
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 8K0 909 144 R    HW: 8K0 909 144 B
       Component: RCEPS         H43 0511
       Revision: 00001000    Serial number: 0028763534
       Coding: 100000000001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X.rod
       VCID: 40849077DB1224212EF-8015
    2 Faults Found:
    18689 - Terminal 30
              U140A 00 [008] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 199
                        Mileage: 239935 km
                        Date: 2024.02.19
                        Time: 14:13:12
    19714 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 199
                        Mileage: 239935 km
                        Date: 2024.02.19
                        Time: 14:13:35
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0170278692
       Coding: 013B062220B930C08020023680000000
       Subsystem 1 - Part No: 8K0 951 177
       Component: DWA-Sensor  H02 0040
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOC.clb
       Part No SW: 8T1 035 223     HW: 8T1 035 223
       Component: DSP Prem      H04 0040
       Revision: 00004001    Serial number: 94804001582601
       Coding: 0203010302
       VCID: 6CDC14C78F1A1041A27-8039
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000024447550
       VCID: 4C9CB447EF5AF041C27-8019
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 3
                        Fault Frequency: 9
                        Reset counter: 159
                        Mileage: 239916 km
                        Time Indication: 0
                        Date: 2024.02.18
                        Time: 14:24:22
    Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 00000000024430
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3668F6AF89D69A91843-8063
    1 Fault Found:
    71424 - Left Parking Brake Motor voltage supply
              C100D 12 [008] - Short to Plus
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 199
                        Mileage: 239925 km
                        Date: 2024.02.19
                        Time: 13:12:25
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8R2 035 186 A    HW: 8R2 035 186 A
       Component: Concert3 DAB  H05 0440
       Revision: 00000005    Serial number: AUZ5Z6L1708547
       Coding: 0503008201028D00035B070000
       VCID: 346CCCA797AA8881BA7-8061
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
    Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Component: TSG HL        H01 0506
       Revision:             Serial number: 0000024722229
       Coding: 010C02204001210001
       VCID: 438E9F7BC2043F3933D-8016
    Address 6D: Trunk Elect. (J605)       Labels: Redir Fail!
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H52 0330
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C7CE487BFFA40C1727-8069
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H52 0330
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H01 0506
       Revision:             Serial number: 0000024722222
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005475760
       Coding: 0010320
       VCID: 3D7AE98364E049C9459-8068
    End-------------------------(Elapsed Time: 03:04)--------------------------
  2. Re: Electric Steering Rack Issue
    120 Post(s)
    1886 Post(s)
    Western are a very good company. You have a power supply problem.
  3. Re: Electric Steering Rack Issue
    Feb 2024
    Durham
    Any suggestions where to start first mate? It was ok when I was driving it today but once I slowed the car down and went to turn right to do a three point turn the warning light appeared and power steering went dead. Turn the car on and off and still the same, took a few seconds after then the warning light disappeared then started working again
  4. Re: Electric Steering Rack Issue
    120 Post(s)
    1886 Post(s)
    I would expect the problem to be corrosion at the motor two pin power plug
  5. Re: Electric Steering Rack Issue
    Feb 2024
    Durham
    Do you mean the two connectors on the end of this plug Crasher? If so I'll have to try and find where they go as only seen the end plug where it goes into the steering rack
  6. Re: Electric Steering Rack Issue
    120 Post(s)
    1886 Post(s)
    They are under the gearbox and the gear is tight against the plate, I have seen the area completely packed with rotten sodden compost, it is a stupid design.
  7. Re: Electric Steering Rack Issue
    Feb 2024
    Durham
    I've had a look at both connections on the other side of that connector. One was bolted to the body near the passenger wheel behind a piece of trim and the other was connected to the power board behind the scuttle panel at the top of the engine bay. I've checked the bolts to see if they were tight and they seemed fine.
    I pulled the car out the garage and when I turn the steering wheel standing still it will lock the steering and give some feedback and it will force the steering wheel the opposite way.
    Not safe to drive what so ever.
    Someone did check the battery health for me with a device and it said it had 50% battery health.
    Any other suggestions?
  8. Re: Electric Steering Rack Issue
    120 Post(s)
    1886 Post(s)
    EPAS needs a bloody good power supply.
  9. Re: Electric Steering Rack Issue
    Feb 2024
    Durham
    Hello Crasher,
    I've been looking at some measurement values on VCDS for steering assist, turning the steering wheel when car is on and stood still.
    Video of the findings here - Audi VCDS - YouTube
    Guessing new battery would be the next port of call.
    Thanks,
    MDOG
  10. Re: Electric Steering Rack Issue
    Feb 2024
    Durham
    New battery no good, but I'm thinking I might need a different one with better Amp's
    This is the one I purchased https://www.eurocarparts.com/p/bosch...ntee-444779038 80Ah
    The old Varta AGM which was in the car is 92Ah
    Going to try this one with 95Ah - https://www.eurocarparts.com/p/bosch...ntee-444777008
    Good logic or just madness?
  1. Electric steering rack replacement
    By eddie_fb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-11-2019, 05:52 PM
  2. electric power steering rack
    By antas in forum Touran - Sharan - Caravelle
    Last Post: 03-07-2015, 09:53 PM
  3. Steering rack issue
    By steviestdi in forum Bora - 1998 - 2005
    Last Post: 26-06-2015, 08:33 PM
  4. Help Needed on Electric Steering rack Removal
    By Eggsandbacon in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-11-2012, 06:09 PM
  5. Touran Electric Steering Rack & ESP Problem
    By robertx2008 in forum Touran - Sharan - Caravelle
    Last Post: 18-10-2010, 08:57 AM
