Thread: Fault Code on dash
  1. Fault Code on dash
    Feb 2024
    Esk Qld Australia
    2007 3.0 Tdi Fault code. Dash comes up with rear park brake fault Cheap OBD2 reader says rear park brake sensor. Car won't start so living 100 K's from nearest Audi service station.Any advice how to proceed. Looks like a Tilt tray job atm.
  2. Re: Fault Code on dash
    Jul 2008
    Lisburn
    15 Post(s)
    Cheap scanners tend to use a general data base of codes - not so bad for engine codes, gets a bit more random with specific control modules. I would get a licensed VAG scanner and get a full scan to see whats going on.
    VCDS or OBDeleven are the 2 I know. OBDeleven starts off cheap if its only a glove box hero you are after. If you intend on doing a lot to a lot of cars VCDS would pay for itself.
    Also post in your model specific section and you might get more feedback.
    good luck
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Fault Code on dash
    Mar 2010
    Derry ireland
    63 Post(s)
    Engine code would be most helpfull
  1. Replies: 7
    Last Post: 19-08-2024, 08:57 AM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. Please Help 2003 A4 2.5 TDI PRND flashing on dash fault code 18201????
    By bigtoe22782 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-02-2011, 10:09 PM
  4. dash board data fault code 473
    By brian harrison in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2010, 11:57 AM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
