Thread: Audi shutting off while driving
Results 1 to 10 of 15
  1. Audi shutting off while driving
    Feb 2024
    Ireland
    Hey, i have 2007 2.0Tdi avant,So this problem started last year, car can be warm or cold it doesnt matter, so when i drive or sitting on the lights car can suddenly just shut off, theres no problem starting it up and its going to be okay for the rest of the day, it stopped doing this for 2-3weeks and it started to do this again, almost every day, i scanned for codes using OBD11. Car got new battery and alternator last year, got stuck so had to get guy to come to my home to swap batteries, he got some cheap battery and never codded so not sure if that can be problem.Car doesnt go into limp mode and has full power.
    OBDeleven vehicle history log
    Date: 2024-02-06 11:57:16
    VIN:
    Car: Audi
    Year: 2007
    Body type: UNKNOW
    16 Steering Column
    System description: Lenksäulenmodul H08
    Software number: 4F0910549
    Software version: 0230
    Hardware number: 4F0953549A
    Faults:
    02072 - Invalid Data Received From Battery Energy CM -A-
    Intermittent
    priority - 4
    frequencyCounter - 1
    drivingCycle - 84
    km-Mileage - 312808 km
    date - 2024-01-05 16:47:36
    Date: 2024-02-06 11:59:14
    Car: Audi
    Year: 2007
    Body type: UNKNOWN
    4F Central Electrics 2
    System description: ILM Beifahrer H10
    Software number: 4F0910280
    Software version: 0080
    Hardware number: 4F0907280A
    Hardware version: ---
    Faults:
    Intermittent
    priority - 3
    drivingCycle - 71
    km-Mileage - 262136 km
    Date: 2024-02-06 11:59:57
    Car: Audi
    Year: 2007
    Body type: UNKNOWN
    Engine: kW ( hp) l
    Mileage: 313370 km
    53 Parking Brake
    System description: EPB CDEC0080 H04
    Software number: 4F0910801C
    Hardware number: 4F0907801A
    Faults:
    00446 - Function limitation due to insufficient voltage
    static
    priority - 6
    drivingCycle - 44
    Date: 2024-02-06 12:07:40
    VIN: WAUZZZ4F67N147370
    Car: Audi
    Year: 2007
    Body type: UNKNOWN
    Engine: kW ( hp) l
    Mileage: 313370 km
    03 Brakes
    System description: ESP8 front H01
    Software number: 4F0910517AC
    Software version: 0070
    Hardware number: 4F0614517T
    Hardware version:
    Faults:
    01314 - Engine control module (ECM)
    Intermittent
    priority - 3
    frequencyCounter - 4
    drivingCycle - 85
    km-Mileage - 313310 km
    date - 2024-01-30 05:39:43
    P185700 - Load Signal
    Error Message from Engine Contr.
    Intermittent
    priority - 3
    drivingCycle - 85
  2. Re: Audi shutting off while driving
    Jul 2008
    Lisburn
    15 Post(s)
    looks like a bad read from the battery control module - attached to the body at the back of the car beside the battery. My A6 had a small leak in the boot, bad seal on a bumper bolt, which let small amounts of water in. It never bothered me but it did take out my battery control module. remove the plug and see if there is any green in there. My symptoms were always getting a low battery warning. some of these don't need programed and i got a recon one off the bay of thieves from ECU-2-you came with a warranty and had his sticker on, so not afraid to stand by what he sells.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Audi shutting off while driving
    105 Post(s)
    1791 Post(s)
    Can you post a full car scan. What is the spec/make of the battery?
  4. Re: Audi shutting off while driving
    Feb 2024
    Ireland
    Thats the full log. Battery is ducellier 95ah,CCA 850. Checked BCM and its completely dry, cable looks fine. P.S accidently left obd11 and it drained battery fully so had to get jump started couple times wondering if it could damaged the BCM unit itself.
    Code:
    Date: 2024-02-06 16:37:29
        Car: Audi
        Year: 2007
        Body type: UNKNOWN
        Engine:   kW ( hp) l
        Mileage: 313370 km
    Full scan
        Control Units: 18
        Fault count: 12
        Control Units:
            01 Engine
            System description: R4 2,0L EDC G000SG
            Software number: 03G906016HS
            Software version: 9673
            Hardware number: 03G906016HS
            Faults:
                No trouble codes found
            05 Keyless System
            System description: FBSAUDIC6 ELV   H31
            Software number: 4F0910852
            Software version: 0220
            Hardware number: 4F0905852B
            Hardware version: 242ÿ
            Faults:
            09 Central Electrics
            System description: ILM Fahrer      H17
            Software number: 4F0910279K
            Software version: 0240
            Hardware number: 4F0907279
            Faults:
            15 Airbag
            System description: 4E AIRBAG AUDI8RH30
            Software number: 4F0910655E
            Software version: 0280
            Hardware number: 4F0959655B
            Faults:
            17 Dashboard
            System description: KOMBIINSTR. M73 H13
            Software number: 4F0910900C
            Software version: 0170
            Hardware number: 4F0920950R
            Hardware version: H13ÿ
            Faults:
            56 Radio
            System description: MMI Cockpit     H55
            Software number: 4F0910769H
            Software version: 0410
            Hardware number: 4F0035769B
            Faults:
            62 Rear Left Door
            System description: TSG HL          H21
            Software number: 4F0910795E
            Software version: 0050
            Hardware number: 4F0959795E
            Faults:
            61 Battery Regulation
            System description: J0644 BEM       H12
            Software number: 4F0910181E
            Software version: 0590
            Hardware number: 4F0915181A
            Hardware version: 000
            Faults:
            72 Rear Right Door
            System description: TSG HR          H21
            Hardware number: 4F0959794E
            Faults:
            16 Steering Column
            Faults:
                    Intermittent
                        priority -  4
                    drivingCycle - 84
            08 Air Conditioning
            System description: KLIMABETAETIGUNGH30
            Software number: 4F0910043A
            Software version: 0020
            Hardware number: 4F2820043Q
            Faults:
                    00256 - Sensor for refrigerant pressure/temperature
                    Intermittent
                        priority -  3
                    frequencyCounter - 15
                    drivingCycle - 81
                    km-Mileage - 312615 km
                    date - 2023-12-29 14:05:18
            53 Parking Brake
            Faults:
                    Intermittent
                        priority -  6
                    drivingCycle - 84
                    static
                        priority -  6
                    drivingCycle - 45
                    km-Mileage - 313328 km
                    date - 2024-02-02 17:12:19
            46 Comfort System
            System description: Komfortgeraet   H22
            Software number: 4F0910289G
            Hardware number: 4F0907289G
            Faults:
                    01699 - Rear lid ctr. lock. sys. motor
                    static
                        priority -  3
                    frequencyCounter - 254
                    drivingCycle - 45
                    km-Mileage - 230790 km
                    date - 2016-09-26 14:01:31
            03 Brakes
            Hardware version:
            Faults:
                    Intermittent
                        priority -  3
                    drivingCycle - 85
                    Intermittent
                        priority -  3
                    drivingCycle - 85
            42 Driver Door
            System description: TSG FA          H12
            Software number: 4F0910793E
            Software version: 0120
            Hardware number: 4F0959793E
            Faults:
                    02115 - Lock unit for central locking
                    Intermittent
                        priority -  3
                    frequencyCounter - 92
                    drivingCycle - 85
                    date - 2023-12-29 14:03:57
            52 Passenger Door
            System description: TSG BF          H12
            Hardware number: 4F0959792E
            Faults:
                    static
                        priority -  3
                    frequencyCounter - 10
                    drivingCycle - 44
                    date - 2023-12-28 21:00:49
            19 Gateway
            System description: Gateway         H11
            Software number: 4F0910468A
            Hardware number: 4F0907468D
            Faults:
                    02077 - Media Player, Position 2
                    static
                        priority -  3
                    drivingCycle - 27
                    date - 2023-12-28 21:01:48
                    01044 - Control module incorrectly coded
                    static
                        priority -  1
                    frequencyCounter - 28
                    drivingCycle - 45
                    date - 2023-12-28 21:00:52
            Faults:
                    Intermittent
                        priority -  3
                    drivingCycle - 71
  5. Re: Audi shutting off while driving
    Jul 2008
    Lisburn
    15 Post(s)
    Strange, my OBDeleven lives plugged in with no issue. Did you remove the connector and check the pins? mine looked 100% from the outside
    Stewart
  6. Re: Audi shutting off while driving
    105 Post(s)
    1791 Post(s)
    There are many low voltage codes, do a full clear and rescan
  7. Re: Audi shutting off while driving
    Jul 2023
    Carlisle, UK
    Since there are so many low voltage messages could it be as simple as a loose connection close to the battery in terms of distribution? Or maybe a duff high current relay? Is there a common point that supplies power to the modules reporting errors?
  8. Re: Audi shutting off while driving
    105 Post(s)
    1791 Post(s)
    Has the battery module been replaced?
  9. Re: Audi shutting off while driving
    Feb 2024
    Ireland
    Wasnt changed, going to check pins today, found little bit loose negative terminal on battery yesterday but not sure if that could cause this. Ill clear the codes and scan again
  10. Re: Audi shutting off while driving
    Feb 2024
    Ireland
    Checked everything, cable and pins are completely dry and good, no clue what to do, was cleaning car while it was running and after 3-5mins it just shut down, but it restarts easily, should i just try to change battery module? After deleting codes i only get the gateway, doors and air con codes
  1. Please Help 93Golf Mk3 1.8 keeps shutting off when hot
    By tedweb in forum Golf MK3 - 1993 - 1999
    Last Post: 26-10-2010, 08:55 AM
  2. Question Air con Flap shutting
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2010, 01:09 AM
  3. Please Help radio shutting down
    By bigscotty36 in forum Golf Plus
    Last Post: 23-11-2009, 01:40 PM
  4. Please Help A8 4.2L - MMI keeps shutting down????
    By manclad230 in forum In Car Entertainment
    Last Post: 02-06-2009, 06:33 PM
  5. Shutting down the sandwich box sub
    By Robbycroft in forum Audi A3 - Archive Topics
    Last Post: 29-03-2008, 09:52 AM
