Thread: 3.0TDI injector nozzle taper
Results 1 to 10 of 11
  1. 3.0TDI injector nozzle taper
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Bit of an odd one, I've just changed the copper seals on my injectors (3.0TDI CDUD) as one was leaking badly, and stinking the car out. That seal had eroded away and was a C profile, the others were still O's but badly eroded, and one other injector had started to blow by.
    The odd bit is, all 6 injector nozzles are reverse tapered, ie fatter at the tip. The taper looks almost too perfect for it to be overheating and swelling, as the tapers have straight sides, and are identical on all 6 injectors. The internet says they have had something really bad happen to them, and are knackered, but they work perfectly! The car starts, idles, and drives like a dream, no smoking, no mis-fires or no frequent DPF regenerations.
    Having watched on Youtube others changing their injectors, they all seem to be tapered, so are these really odd injectors with tapered nozzles, or is there something inherently wrong with this engine which causes them all to swell at the tip, but still work perfectly?
  2. Re: 3.0TDI injector nozzle taper
    1836 Post(s)
    Pictures please.
  3. Re: 3.0TDI injector nozzle taper
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Stupidly I didn't take any, but I'll find some off tinternet
  4. Re: 3.0TDI injector nozzle taper
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    I screen shotted a video and tried to post a .png or .jpg picture, but this site won't upload them, so -
    Audi VW 3.0 TDI Hissing Ticking Noise Injector Seals Leaking (youtube.com) Go to 9.55, and watch until 12.10 These injectors are exactly the same tapers as mine.
  5. Re: 3.0TDI injector nozzle taper
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    I managed to get the jpg to load, but well worth watching the video anyway. As a side note, very odd how one injector is badly eroded right up in the threaded area? I can't see how heat capable of doing that could travel that far up there without the rest of the injector and cylinder head being destroyed, could it be a high pressure fuel leak has cut the metal away?
  6. Re: 3.0TDI injector nozzle taper
    1836 Post(s)
    The is gas erosion due to blowby of the seal.
  7. Re: 3.0TDI injector nozzle taper
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Can you elaborate please? What is eroded - is this the cause of tapered nozzles, or just the eroded injector body?
    If not the nozzles, any idea what's caused them to be tapered? have you seen tapered nozzles before?
  8. Re: 3.0TDI injector nozzle taper
    1836 Post(s)
    They are quite soft metal, the hot combustion gases being forced past the seals dissolve the metal.
  9. Re: 3.0TDI injector nozzle taper
    Oct 2018
    London
    29 Post(s)
    Did u fit them injectors back in?
  10. Re: 3.0TDI injector nozzle taper
    1836 Post(s)
    I am just servicing a 2014 4L V6 and the customer reported "smoke on the horizon", opened the bonnet, oil blown all over the left strut and onto the exhaust manifold.
  1. 3.0tdi no power to injectors, no fault code then injector disconnected A6/C6 3.0TDI
    By Martynas26 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-08-2018, 09:53 PM
  2. Attention 3.0tdi injector issue?
    By slice636 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2017, 06:18 PM
  3. Question 3.0TDI injector issues? looking to buy
    By andy198712 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-12-2016, 05:41 PM
  4. Question 3.0TDi Injector Issue??
    By BigAde in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-12-2014, 01:03 PM
  5. Please Help TDI Injector Nozzle Change
    By DazJ32 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2008, 08:32 PM
