Thread: Radio Fault
Results 1 to 8 of 8
  1. Radio Fault
    Jan 2024
    Corsham
    ran an autoscan with my new vcds and this popped up:
    so i clicked on the can And this popped up:
    Any ideas? THank you
  2. Re: Radio Fault
    134 Post(s)
    2020 Post(s)
    Could you post a full car scan saved as a text scan inside code tabs and please include the VIN which is not GDPR data.
  3. Re: Radio Fault
    Jan 2024
    Corsham
    will do, QUOTE=Crasher;1149981]Could you post a full car scan saved as a text scan inside code tabs and please include the VIN which is not GDPR data.[/QUOTE]
  4. Re: Radio Fault
    Jan 2024
    Corsham
    Code:
    Sunday,04,February,2024,09:21:48:06808
    VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
    Data version: 20231027 DS351.0
    Ross-Tech: Home
    VIN: WAUZZZ4F78N040846   License Plate:
    Chassis Type: 4F (4L0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62 72
    01-Engine -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: Malfunction 0010
    Address 01: Engine        Labels: 059-907-401-BPP.clb
       Part No SW: 4F5 910 401 K    HW: 4F0 907 401 C
       Component: 2.7L V6TDI  G000SG  0010
       Revision: --H04---    Serial number:
       Coding: 0011322
       Shop #: WSC 02335 758 00200
       VCID: 290EFA5265F88BC258D-807C
       VINID: 9D196AAAA1161C87801002041818133C51
    2 Faults Found:
    053255 - Please check Fault Memory in Battery Monitoring Module
                   U1007 - 001 -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00110001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 185211 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 14:32:42
                 Freeze Frame:
                        RPM: 756 /min
                        Torque: 31.2 Nm
                        Speed: 0.0 km/h
                        (no units): 1224.0
                        Voltage: 14.14 V
                        Temperature: 9.0C
                        (no units): 4.0
    008200 - Intake Manifold Flap; Bank 1
                   P2008 - 002 - Electrical Malfunction - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 185214 km
                        Time Indication: 0
                        Date: 2024.02.01
                        Time: 09:47:52
                 Freeze Frame:
                        RPM: 126 /min
                        Torque: 261.3 Nm
                        Speed: 0.0 km/h
                        Voltage: 10.03 V
                        Duty Cycle: 7.9 %
                        Duty Cycle: 41.0 %
                        Duty Cycle: 80.9 %
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020871
       VCID: 6596B66249606FA2BC5-8030
    No fault code found.
    Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500854927
       Coding: 0000145
       Shop #: WSC 00116 210 91014
       VCID: 6392A87A47541192521-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head
    Cannot be reached
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000030272523
       Coding: 0001302
       VCID: 1C60D3863AAA6E6AD3B-8048
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H18 0250
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0000101
       VCID: 313E12324D28F30290D-8064
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1
    Cannot be reached
    Address 15: Airbags        Labels: 4F0-910-655-8R.clb
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0TKUPJ
       Coding: 0013381
       Shop #: WSC 02325 758 00200
       Subsystem 1 - Serial number: 6332CSME16222132N
       Subsystem 2 - Serial number: 6342CSME19273B465
       Subsystem 3 - Serial number: 6352QSME36770F2DU
       Subsystem 4 - Serial number: 6362QSME385A4A05N
       Subsystem 5 - Serial number: 63734SME36064849+
       Subsystem 6 - Serial number: 63834SME35521313P
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0410
       Revision: 00H02000    Serial number: 90054072060202
       Coding: 0102042
       VCID: 270AFC6A73ECBDB24E9-8072
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B0750483EE
       Coding: E5519E5330020600
       VCID: 2D060E42511097E2B45-8078
    1 Fault Found:
    00384 - Optical Databus
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 236
                        Mileage: 185248 km
                        Time Indication: 0
                        Date: 2024.02.03
                        Time: 13:33:31
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0210
       Revision: 00000000    Serial number: Vt˜
       Coding: 0003610
       Shop #: WSC 02327 758 00200
       VCID: 2C0003466A0A9EEAA3B-8078
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H25 0200
       Revision: 02000025    Serial number: 01059725790000
       Coding: 0000763
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System
    Cannot be reached
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000344306
       Coding: 0001103
       VCID: 5EE4998E6C363C7A7DF-800A
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0210
       Revision: 00000000    Serial number: •˜
       Coding: 0003610
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000511
       Shop #: WSC 02324 758 00200
       VCID: 2018E77616C24A8A0F3-8074
    Address 56: Radio
    Cannot be reached
    Address 61: Battery Regul.        Labels: 4F0-910-181.clb
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000125016
       Shop #: WSC 00763 210 80270
       VCID: 2312E87A07D45192121-8076
       Subsystem 1 - Part No: 4F0 915 105 D
       Component: von VA0  2708010899
       Coding: 344630393135313035442056413032373038303130383939
       Shop #: WSC 00000 512 00290
    2 Faults Found:
    02254 - Interface to Generator
                 Freeze Frame:
                        Fault Status: 00110100
                        Fault Priority: 4
                        Fault Frequency: 16
                        Reset counter: 235
                        Mileage: 185211 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 14:35:09
    02479 - Partial Consumer Shut-Off Active
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 7
                        Fault Frequency: 10
                        Reset counter: 255
                        Mileage: 185214 km
                        Time Indication: 0
                        Date: 2024.01.31
                        Time: 16:05:27
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0210
       Coding: 0003074
       VCID: 2E04094E5C16ECFA8DF-807A
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0003074
    End----(Elapsed Time: 01:20, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
  5. Re: Radio Fault
    Jan 2024
    Corsham
    so, ive just read ross-tech wiki page and it said to go into Applications/ optical bus Diagnostics which ive done and i see this:
    Sunday,04,February,2024,11:46:59:06808
    Ross-Tech: Home
    Mileage: 185250km-115109mi Repair Order:
    Control Module Part Number: 4L0 910 468 A
    Component and/or Version: J533__Gateway H06 0060
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK ERROR
    07-Control Head(Std Plus) OK ERROR
    0E-Media Player 1 ERROR ERROR
    47-Sound System ERROR ERROR
    56-Radio ERROR ERROR
  6. Re: Radio Fault
    Jan 2024
    Corsham
    Quote Originally Posted by simonthepost View Post
    Ross-Tech: Home
    only thing i can think of is that i removed a hardwired telephone setup on thursday. all was working fine until saturday afternoon. could this have something to do with it?
  7. Re: Radio Fault
    134 Post(s)
    2020 Post(s)
    It looks like the CAN BUS line is broken, was the phone kit an aftermarket fit? As you have genuine VCDS, join the Ross Tech forum, get verified and post on there as there are some very clever and helpful types on there.
  8. Re: Radio Fault
    Jan 2024
    Corsham
    Cheers crasher, will do
  1. Radio fault question
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-10-2019, 06:53 AM
  2. Radio fault
    By Northern one in forum In Car Entertainment
    Last Post: 01-02-2015, 09:23 PM
  3. RCD 300 mp3 Radio Fault?
    By reeseyboy in forum Golf MK5 - 2004 - 2009
    Last Post: 25-01-2011, 07:43 PM
  4. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  5. Radio power fault
    By thegroovyfox in forum In Car Entertainment
    Last Post: 05-05-2009, 12:13 PM
