Thread: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #11
    Jan 2024
    USA
    Thanks. That gives me some comfort. I'm testing the injectors with voltmeter. I'm getting less than 20 ohms on all of them and i believe range should be between 160-180 ohms. Maybe doing it wrong, could it be possible all are bad? I'm going to try post some pics.
  2. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #12
    Jan 2024
    USA
    https://i.imgur.com/wf6T011.jpg
  3. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #13
    Jan 2024
    USA
  4. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #14
    Jan 2024
    USA
    So, pics show the cracked retaining nut and on one of the injectors the swollen tip. Possible that diesel getting into oil this way?
  5. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #15
    135 Post(s)
    2026 Post(s)
    That swollen injector is fubar
  6. Re: Passat 2013 TDI Fuel Rail Pressure Too Low/Particulate Filter Regen Frequency/Low oil pressure
    #16
    Jan 2024
    USA
    Yes, sir. Took it apart and it's only spraying 6 ways, I think it should be 8 or more sprays. There is one additional injector that is super stuck. Even used an engine hoist to lift and tap around the sides but it's not coming out. Any ideas, suggestions, how to extract that sucker or what it's happening down there? Don't want to damage cylinder if can avoid it. I thought about just cutting out valve cover out for more access and also a better look to see what exactly is happening; is it fused unto the cylinder, or what's the deal. Need less to say , a sliding hammer method does not work.
  1. Audi a4 p0087 low fuel rail pressure
    By Mcgchris in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 20-01-2024, 01:10 PM
  2. Replies: 1
    Last Post: 28-07-2018, 05:50 PM
  3. Fsi 1.6 fuel rail pressure
    By Dvmax in forum Touran - Sharan - Caravelle
    Last Post: 04-07-2016, 05:54 PM
  4. Please Help Fault Code P2454 - Diesel Particulate Filter Differential Pressure Sensor
    By TonyMc06 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-06-2016, 07:14 PM
  5. High Pressure Fuel Rail Sensor - Replacement Item
    By betyouaint in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-12-2014, 03:11 AM
