Thread: gear gaiter
  1. gear gaiter
    red.2 Guest
    can someone please tell me how to fit a gear gaiter to a mk 4 golf, does it just clip in ?
  2. Re: gear gaiter
    Leicester
    Hi, I changed my gear gator a couple of days ago on my Golf MK 4 and wasn't as hard as I thought it would be!
    To remove the gear
    knob you will need to loosen the clip that clamps the gear knob to the gear shaft (which is at the top of the gear shaft, under the gator).
    Firstly, lift up the gear gator by undoing the elasticated bottom of the gator, pull this up as far as possible so you have access to the clip that is clamped onto the gear shaft. To loosen the clip use a flat head screw driver to gently force out the clip, once this has loosened the gear knob will just slide off.
    The only problem I faced was tightening the clip after the gear
    knob/gator had been replaced to prevent the gear knob from moving or coming loose. As this clip was very hard to tighten I just replaced it with a small jubilee clip.
    Hope this helps.
    Rich.
  3. Re: gear gaiter
    red.2 Guest
    thanks a bunch for the info, i will let you know how i get on,, cheers
  4. Re: gear gaiter
    red.2 Guest
    fitted new gaiter today, i see what you mean about the clip very tricky indeed managed to get it on ok, thanks for thr advise,,,
  1. leather gaiter?
    By NOGGA in forum Bora - 1998 - 2005
    Last Post: 28-07-2010, 03:21 PM
  2. Changing a MK4 Gaiter + (Gear Stick problem )
    By Dirtdiver in forum Golf MK4 - 1999 - 2004
    Last Post: 21-08-2008, 10:22 PM
  3. Gear Gaiter
    By Brekka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-07-2007, 11:05 AM
  4. Passat B5.5 Remove / Refit Gear Knob/Gaiter
    By RobBentley in forum Passat - Archive Topics
    Last Post: 12-07-2007, 02:40 PM
  5. Replace Passat Gear Lever Gaiter 52 Reg
    By PeterGittings in forum Passat - Archive Topics
    Last Post: 21-06-2007, 05:35 PM
