Thread: Puzzling symptoms. Steering fault?
  1. Puzzling symptoms. Steering fault?
    Mar 2015
    Berwick uk
    Golf Mk5 1.9TDI 2008 (high mileage)
    Posting on behalf of my daughter. I'd be grateful if anyone has any ideas about this:
    • Driving uphill accelerating.
    • Rev needle swung wildly (without change in car speed) and then, (seconds later I gather), car lurched to left a couple of times and needed corrected. These lurches were quite significant - much more than torque steer.
    • Stopped to check tyres as thought it felt like blowout, and noticed yellow warning light on dashboard - thinks it was steering fault light.
    • That light was off on restart but engine management light and battery light were on.
    • Both were off after another restart and short journey home was uneventful.
    UPDATE
    Engine is cutting out (then restarts OK)
    Smell and some fumes under bonnet, which sounds consistent with burning insulation.
    So this looks like an electrical short imho.
  2. Re: Puzzling symptoms. Steering fault?
    Jul 2008
    Lisburn
    16 Post(s)
    class a smell that sounds, can you hear colours?
    lol
    To me your description is telling me a slipping clutch, and torque steer when it bites.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Puzzling symptoms. Steering fault?
    Mar 2015
    Berwick uk
    I thought the description of the smell and fumes sounded consistent with an electrical short.
    Slipping clutch? nah. Torque steer (when it "bit") would not be too the left anyway. Also, clutch has been recently replaced & clutch wouldn't cause steering light to come on.
    It sounds as if battery is flat today - again consistent with a short I'd have thought.
  4. Re: Puzzling symptoms. Steering fault?
    134 Post(s)
    2007 Post(s)
    Sounds like something is loose post clutch such as a subframe bolt as these are one time only torque to yield stretch bolts but often are reused. If the lights were on code are stored and you need to know what these are. Clutch burning stench is quite distinctive, acrid and lingering, once inhaled, never forgotten.
  5. Re: Puzzling symptoms. Steering fault?
    Mar 2015
    Berwick uk
    For the interest of anyone who comes here with similar symptoms:
    The car was "recovered" and taken to a local garage.
    The recovery man thought the problem/burning smell was from alternator or alternator wiring harness.
    The garage said the alternator and battery had failed, (refused to fit "customer supplied" parts), so fitted expensive ones of their choice and the car then drove normally after we coughed up more than the initial cost of the car.
    I suspect it didn't need a new battery. I've got my hands on the old one. It was down to 8V so must have been below 12.4 for over two (frost free) weeks, which is bad, but it is only just over only a year old and is currently taking a charge and displays just over 13V when charger is switched off. In my experience, leaving a battery flat is bad, but doesn't ruin it instantly.
    The failed alternator was a WAI purchased from GSF just over a year ago - so I expect to be avoiding them in future.
    Why the steering fault? Could abnormal system voltage fluctuations cause the power steering to cut out without being noticed, then cut in again? Just a guess.
  6. Re: Puzzling symptoms. Steering fault?
    134 Post(s)
    2007 Post(s)
    The steering is fully electrically assisted and depends on a good power supply not only for the motor but also the ECU.
  1. Please Help Puzzling message
    By rodaire in forum Chat - Anything with wheels
    Last Post: 14-11-2021, 10:19 AM
  2. 2.0 Tdi glow plug fault symptoms and removal??
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-04-2021, 02:21 PM
  3. Allroad 2.5 tdi ake suspension puzzling problem
    By RICK2472 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-07-2013, 10:06 PM
  4. Question Yellow Steering Warning Light on Dash with no Symptoms.
    By ric4676 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-03-2012, 10:03 AM
  5. Please Help Puzzling electric window problem on Mk5 Golf
    By bogpole in forum Golf MK5 - 2004 - 2009
    Last Post: 30-01-2010, 09:23 PM
