Thread: Charge glow light coming on at high revs
Results 1 to 9 of 9
  1. Charge glow light coming on at high revs
    Jan 2024
    Cambridge
    I've recently got myself a 2016 Audi A3 Sportsback. The car feels ok apart from if I give it high revs in sports mode the glow plug warning light starts flashing. It doesn't happen in economy mode. When I pull over, turn the car off and then restart it I get a warning about the start-stop function not working. Once home and the car has been left for a while the car in fine.
    Has anyone got any idea how serious this is?
  2. Re: Charge glow light coming on at high revs
    131 Post(s)
    1973 Post(s)
    You need to start with a full car code read, preferably one VAG group specific as generic code reads can confuse.
    0 2 0
  3. Re: Charge glow light coming on at high revs
    Jan 2024
    Cambridge
    Thanks, I've checked with Audi and they want the car for 2 days and £360 to diagnose the fault ��!
  4. Re: Charge glow light coming on at high revs
    Jul 2023
    uk
    Any independant VAG specialists in your area? My local one charges something like £100 to scan the codes and give an estimate of whats needed and cost.
    Or if you're thinking of getting a copy of VCDS for this and future use you can get the 3 car version for less than £200
  5. Re: Charge glow light coming on at high revs
    Mar 2009
    less than an hours work to get a local garage to run a diagnostic scan & give you a printout of the fault codes that arise.
    I have a 2015 2.0 TDI with 43k miles.
    Had both warning lights (coily symbol & engine block symbol) on for over a year.
    Because of the fault code provided to me, I replaced my cylinder 3 glow plug (which has a sensor built into the glow plug), £200 including labour. However, it could be any of 3 sensors on that system.
  6. Re: Charge glow light coming on at high revs
    Jul 2008
    Lisburn
    16 Post(s)
    OBDeleven - VAG licensed so will give correct code read, they are as cheap as £50, great glove box hero and you can go on to configure other things while you have it
    could be any number of things so a code read is a must.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  7. Re: Charge glow light coming on at high revs
    Jan 2024
    Cambridge
    I took a punt and added some Redex DPF cleaner to the tank which has fixed the light coming on at high revs issue. I will look into getting a proper clean done in the near future.
  8. Re: Charge glow light coming on at high revs
    Jan 2024
    Cambridge
    After a few weeks, the dreaded glow plug light reappeared so I finally took it to my local garage for diagnostics. Error code P164B00 - Oil pressure switch malfunction. Has anyone come across this error before and is it easy to replace?
  9. Re: Charge glow light coming on at high revs
    131 Post(s)
    1973 Post(s)
    Yes it is common, the one we did last week had to be accessed from below, and some have two so replace both.
  1. Emissions light + Glow plug light in neutral & low revs in 1st/2nd.
    By JDizzle in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-07-2013, 11:42 PM
  2. Replies: 2
    Last Post: 29-05-2013, 10:15 PM
  3. Question Erratic revs and ABS light coming on after replacing wheel bearing
    By frogboy in forum Polo - Derby - Lupo - Fox
    Last Post: 10-11-2010, 02:31 PM
  4. epc light , esp light , low power , high revs ..help...
    By b2online in forum Audi A3 - Archive Topics
    Last Post: 06-05-2008, 11:32 PM
  5. Delay in glow plug coil light coming on.
    By VW driver in forum Chat - Anything with wheels
    Last Post: 12-10-2007, 10:57 AM
