Thread: Audi A3 8P Drivers window not winding down and central locking issues.
Results 21 to 30 of 38
  1. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #21
    116 Post(s)
    1879 Post(s)
    Red lead to the red/green and black lead to the brown or any good earth
  2. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #22
    Sep 2023
    Hi Crasher, there isn't any space to check whilst it is plugged into the door connector as the space is too tight. Not sure if there's some sort of adapter to get into tight spots.
    In the meantime I bought a replacement window motor hoping that, that might resolve the issues that I'm having. I've replaced the window motor today and the issues are still the same. Are there any trouble shooting steps you would suggest or to check with the wiring loom.
    Maybe I could check the socket that the loom plugs into? If so, how would I go about that.
    I messaged the ebay seller to ask if they tested the loom beforehand, this was their response
    "Yes this was definitely working when we removed it off the car hence we listed it for sale. And we removed this with great care as I know how fragile these are.
    90% of these we remove are damaged hence it was on eBay for less than 3 hours and it sold. So it was definitely working when we removed it."
  3. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #23
    116 Post(s)
    1879 Post(s)
    I use needle probes that make a tiny hole in the insulation but watch your fingers
  4. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #24
    Sep 2023
    I haven't done much since the last post. I was going to remove the loom but then thought I haven't done a VCDS scan on the car since installing the new loom. Anyone know where I could get needle probes for a multimeter on the high street?
    Are there any companies or people who repair the wiring looms? as my old one is out of the car and has 4 broken wires if I recall correctly. Are there certain repair wires needed? I wouldn't mind paying someone to sort out the wires.
    Another note, previously, before this issue I was getting an error with the door lock module for the drivers door, where the drivers door wouldn't lock with the central locking, but that I could lock with the key. Anyhow, here's a scan I took today. I remove certain parts as I'm not sure if the whole data is safe to share vin / vcid?
    02-Auto Trans -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 16426012492400FB680C06EB921B00813900
    Shop #: WSC 46093 001 1048576
    1 Fault Found:
    01169 - Door Contact Switch Driver Side (F2)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 36
    Reset counter: 39
    Mileage: 144962 km
    Time Indication: 0
    Date: 2024.02.05
    Time: 08:35:32
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 147
    Count: 52270
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
    Component: KlimavollautomatH09 0100
    Revision: 000397 Serial number:
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    01331 - Door Control Module; Driver Side (J386)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 11
    Reset counter: 35
    Mileage: 144789 km
    Time Indication: 0
    Date: 2024.01.23
    Time: 17:09:14
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number:
    Coding: 11AC2F07A0141380EF00001C4F00000000084E056401000300 2000000000
    Shop #: WSC 06314 000 08192
    Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 224
    Reset counter: 39
    Mileage: 144960 km
    Time Indication: 0
    Date: 2024.02.04
    Time: 20:57:00
    Freeze Frame:
    ON
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number:
    Coding: ED801F061002020101
    Shop #: WSC 06314 000 00000
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 193
    Reset counter: 39
    Mileage: 144960 km
    Time Indication: 0
    Date: 2024.02.04
    Time: 20:59:20
    00470 - Company Comfort Databus in Single Wire
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 142
    Reset counter: 79
    Mileage: 144960 km
    Time Indication: 0
    Date: 2024.02.04
    Time: 21:08:53
    01336 - Company Data Bus for Comfort System
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 79
    Mileage: 145076 km
    Time Indication: 0
    Date: 2024.02.12
    Time: 15:34:44
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D2D8505489AC637
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Component: Tuer-SG H03 0060
    Coding: 0000564
    4 Faults Found:
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    012 - Electrical Fault in Circuit - Intermittent
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
  5. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #25
    Sep 2023
    I'm back, and still have the same problem lol
    As the weather has started to get better I decided to attempt to repair my old "door wiring loom". I ordered previously a repair kit from eBay, that had the main connector (the wiring harness end that plugs into the car) and wires with crimp terminals to plug into the main connector. The kit came with "butt connectors" that could be heated up and had glue inside.
    I replaced the wiring harness, put everything back together and.... I got the same result! Nothing working from the driver door switch. Quite disheartening as it took a while to do.
    I never did end up getting the needle nose probes suggested to test the green/red and the brown cables in the harness. So guess I should order a pair, also I may look out for a multimeter that "beeps" lol if you guys have any recommendations for one, I'm open to suggestions.
    The wiring loom I took out, that I bought from eBay to replace my original one doesn't appear to have any damaged cables, for as far as I can pull the rubber grommet/cover down whilst out of the door.
    Previously I replaced the driver door module with a second hand unit. I also checked the fuses by the drivers door which seemed okay from memory.
    What are other likely things that it could be? I think I'm going to check the fuses again, get the needle probes to check the power of the red/yellow and brown cables. I was thinking it could possibly be the plug in the car that the main wiring loom connector goes into or possibly the actual door switch (that controls the windows/mirrors) Any of these I can rule out based on the information provided?
    Any other suggestions welcome. Thanks.
  6. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #26
    116 Post(s)
    1879 Post(s)
    Are the codes still the same?
  7. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #27
    Sep 2023
    I'm not too sure, think I'll need to dig out my laptop and VCDS to give the car a scan.
  8. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #28
    Sep 2023
    Here's a new scan, taken today of what looks like the issue parts. I've also ordered a pair of needle probes from Amazon that are due to arrive later today. I didn't clear the codes, so I'll do that and scan again.
    Saturday,08,June,2024,13:20:23:26151
    VCDS Version: 24.5.0.0 (x64)
    Data version:
    Ross-Tech: Home
    Repair Order: 2024 08 June Scan1
    Chassis Type: 8P-AU35 (1K0)
    56-Radio -- Status: Malfunction 0010
    Revision: 00H45001
    VCID: -8054
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 238
    Reset counter: 242
    Mileage: 144962 km
    Time Indication: 0
    Date: 2024.02.05
    Time: 08:35:32
    Freeze Frame:
    Count: 0
    Count: 32768
    Count: 12800
    Count: 147
    Count: 52270
    Count: 0
    Count: 0
    Count: 0
    Revision: 000397 Serial number: 8P0820043BG
    VCID: -8026
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 23
    Reset counter: 71
    Mileage: 144789 km
    Time Indication: 0
    Date: 2024.01.23
    Time: 17:09:14
    Freeze Frame:
    ON
    Revision: 00H54000 Serial number: 00000008700068
    VCID: 801C
    Coding: 00056595
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 202
    Mileage: 144960 km
    Time Indication: 0
    Date: 2024.02.04
    Time: 20:57:00
    Freeze Frame:
    ON
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    Revision: H16 Serial number: 2700K087150898
    VCID: -8060
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 194
    Mileage: 144960 km
    Time Indication: 0
    Date: 2024.02.04
    Time: 20:59:20
    Cannot be reached
    VCID: 4385A38B02F3FF8E1E-8016
    2 Faults Found:
    00956 - Key 2
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Coding: 0000564
    VCID: -8010
    4 Faults Found:
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
    Component: R Concert2+ H02 0270
    Revision: 00H02000 Serial number: AUZ1Z3H8938668
    Coding: 0330211
    VCID: 806A
    2 Faults Found:
    00871 - Bass Speaker Front Right (R23)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 242
    Mileage: 147302 km
    Time Indication: 0
    Date: 2024.04.30
    Time: 18:14:58
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 8
    Reset counter: 223
    Mileage: 147231 km
    Time Indication: 0
    Date: 2024.04.26
    Time: 17:00:27
    End-------------------------(Elapsed Time: 02:14)--------------------------
  9. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #29
    Sep 2023
    Here's a scan after clearing the codes.
    Revision: 00H45001
    VCID: -8054
    No fault code found.
    VCID: -8026
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 23
    Reset counter: 71
    Mileage: 144789 km
    Time Indication: 0
    Date: 2024.01.23
    Time: 17:09:14
    Freeze Frame:
    ON
    VCID: 801C
    Coding: 00056595
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 202
    Mileage: 148058 km
    Time Indication: 0
    Date: 2024.06.08
    Time: 14:00:00
    Freeze Frame:
    ON
    Voltage: 12.15 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000 Dataset Number: 8P0909602L 0001
    Coding: 303142413039303030384A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4_AU35.rod
    VCID: -801C
    Crash sensor for side airbag: driver side:
    Serial number: 34928RB400003E9B452U
    Front Passenger's Side Airbag Crash Sensor:
    Serial number: 35028RB400003EB0497M
    Rear Side Airbag Crash Sensor (on driver's side):
    Serial number: 35128RB400003E9A961R
    Passenger side rear thorax airbag crash sensor:
    Serial number: 35228RB400003EB0568N
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB400003E5BE9C5
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB400003E5C0E3W
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0012112
    VCID: 4189A98318EFED9E0C-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    VCID: -8060
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 202
    Mileage: 148058 km
    Time Indication: 0
    Date: 2024.06.08
    Time: 14:01:11
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
    Component: KOMBIINSTR. VDO H15 0830
    Revision: D0H15005 Serial number: AUX7Z0H6FNI0I8
    VCID: -806E
    Cannot be reached
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 234 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 807E
    VCID: 8016
    1 Fault Found:
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
    Component: AB2 SUBWOOFERBOXH30 0160
    Revision: 00006 Serial number: 30659850212944
    VCID: -8060
    Coding: 0000564
    VCID: -8010
    2 Faults Found:
    Coding: 0330211
    VCID: 806A
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 202
    Mileage: 148058 km
    Time Indication: 0
    Date: 2024.06.08
    Time: 14:05:01
    End-------------------------(Elapsed Time: 01:57)--------------------------
  10. Re: Audi A3 8P Drivers window not winding down and central locking issues.
    #30
    Sep 2023
    Checked all the fuses by the steering wheel and under the bonnet. They all had readings, so, it doesn't look like one of the fuses. I see the door control module mentioned a few times in the scan. Is there any way to test the windows, mirrors with the door card off? I read some people got lucky unconnecting / reconnecting the connector.
    The door control module I have in the door at the moment I got second hand from a part place. I still have the old one, not sure if I replaced it before or after I got the second hand wiring loom.
  1. Please Help Audi A3 Tdi 2003 - central locking and power window dead after window smash - why?
    By leyper in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 19-04-2017, 04:48 PM
  2. Please Help Central locking help drivers rear and electric window not working
    By sluggs1 in forum Golf Plus
    Last Post: 23-04-2016, 06:25 PM
  3. Please Help Central locking help drivers rear and electric window not working
    By sluggs1 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-04-2016, 06:22 PM
  4. Replies: 2
    Last Post: 12-06-2015, 08:42 PM
  5. Help with central locking and drivers window 2001 Polo
    By Aldo in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2013, 08:15 PM
