Thread: MK5 Golf 170 BHP, INJECTOR PROBLEM
  1. MK5 Golf 170 BHP, INJECTOR PROBLEM
    Jan 2024
    Essex
    I’ve got a mk5 golf 170bhp BMN ENGINE diesel DSG.
    I have a problem that I can not seem to get solved.
    The car starts when I unplug no.4 injector, soon as I plug it back in…the car will not start. If I unplug any of the other injectors it does not start, only no.4 unplugged?
    I went to the local scrap yard and brought 3 injectors, that all have the same part number. I have tried them all in no.4 and it does the same with all of them. I have to have it unplugged for the car to run.
    I have tried the wiring harness under the rocker cover.
    I have also checked continuity, from the injector harness plug to the ECU there seems to be no broken wires.
    Any help would be much appreciated.
    thanks I’m advance.
  2. Re: MK5 Golf 170 BHP, INJECTOR PROBLEM
    Mar 2010
    Derry ireland
    63 Post(s)
    check the insulation on the no 4 plug with ign 0ff
  3. Re: MK5 Golf 170 BHP, INJECTOR PROBLEM
    131 Post(s)
    1973 Post(s)
    This was actually the cause of a recall with the BMN injectors and new ones are now impossible to find, even recon are scarce… I think Bosch and VAG want the BMN engines out of circulation.
  4. Re: MK5 Golf 170 BHP, INJECTOR PROBLEM
    Oct 2017
    London
    12 Post(s)
    Why did you buy 3 injectors when you only need 1? Did you try switching (ignoring the scrapyard ones) injector 3 (which you know is good and works) into number 4? If 3 worked fine before but not in 4 then that would rule out injector problem as your issue. Did you drive long on a bad injector? Ive seen people damage heads driving on bad injectors for too long. Did you get any injector readings from vcds etc to see what they are doing?
  1. Question A4 2.0 TDI injector problem
    By peely880 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-01-2017, 12:42 PM
  2. Injector problem - please Help
    By lee wales in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-02-2009, 08:31 PM
  3. Injector problem?
    By whitey_250 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-11-2008, 09:42 PM
