Thread: Unable to update RMC1 MMI
  1. Unable to update RMC1 MMI
    Jan 2024
    Brest, France
    Hello there,
    Sorry if my english is bad im a frenchie
    So here is my problem is recently buy an audi A1 8X (2011) for my wife and she love'd it but the old owner tries to update the RMC and broke it
    and now i cant even see witch version is install on and i cant update it it allways tells me that version is for RMC2 instead of RMC1 but its the good files
    i run a vcds scan that show me 5F unable to communicate
    so if u know a way to fix it that would be amazing
    thanks agains for your replie
    in the replie u'll find the vcds scan thanks again
  2. Re: Unable to update RMC1 MMI
    Jan 2024
    Brest, France
    Here is the vcds scan thanks
    Code:
    Mercredi,03,Janvier,2024,17:47:59:00001VCDS -- Logiciel d'émulation de VAG/VAS sous Windows(R)
    Version VCDS: FRM 14.10.0.0
    Version données: 20141103
    VIN: WAUZZZ8X7BB031740
    Plaque d'immat.: AUDI A1
    Kilometrage: 202870km
    Ordre réparation::
    Type chassis: 8X (8X0)
    Scanner: 01 03 08 09 15 16 17 19 25 42 44 46 52
    01-Moteur -- Etat: OK 0000
    03-Freins ABS -- Etat: Défaut 0010
    04-Angle de direction -- Etat: OK 0000
    08-Climatronic -- Etat: OK 0000
    09-Centrale Elec. -- Etat: OK 0000
    15-Airbags -- Etat: OK 0000
    16-Volant multifonct. -- Etat: OK 0000
    17-Instruments -- Etat: OK 0000
    19-Gateway CAN -- Etat: OK 0000
    25-Anti-démarrage -- Etat: OK 0000
    42-Porte conducteur -- Etat: OK 0000
    44-Direction assistée -- Etat: OK 0000
    46-Module confort -- Etat: OK 0000
    52-Porte passager -- Etat: OK 0000
    56-Radio -- Etat: Défaut 0010
    Adresse 01: Moteur (J623-CBZA)       Labels: 03F-906-070-CBZ.clb
       No. pièce Log: 03F 906 070 CA    Mat: 03F 906 070 CA
       Pièce: SIMOS10.24H01 9873
       Révision: --H01---    No. de série:
       Codage: 00110096232401080000
       No. Atelier: WSC 00046 790 00000
       Jeu de données ASAM: EV_ECM12TFS02103F906070CA 004010
       ROD: EV_ECM12TFS02103F906070CA.rod
       VCID: 63CE07606A55B939129-8036
    Aucun code défaut trouvé.
    Tests passés: 0110 0101
    Adresse 03: Freins ABS (J104)       Labels: 6R0-907-37x-ESP82.clb
       No. pièce Log: 6R0 907 379 AH    Mat: 6R0 907 379 AH
       Pièce: ESP8.2i front H07 0004
       Révision: --------
       Codage: 310428E9217000B38C2C14E684D100540E00
       No. Atelier: WSC 00046 000 00000
       VCID: 040C24FC831B1E014B3-8051
    3 Codes défaut trouvés:
    02214 - Alerte pression de gonflage pneus
                002 - Limite inférieure non atteinte - Intermittent
                 Capture:
                        Etat du défaut: 00100010
                        Priorité du défaut: 0
                        Fréquence du défaut: 27
                        Compteur de RAZ: 169
                        Kilometrage: 202693 km
                        Heure: 0
                        Date: 2023.11.08
                        Temps: 08:11:58
                 Capture:
                        Valeur hex: 0x0000
                        Valeur hex: 0x0000
                        Valeur hex: 0x1203
                        Valeur hex: 0x2BBA
                        Valeur hex: 0x1980
                        Valeur hex: 0x7F7C
                        Valeur hex: 0x80F8
    00532 - Tension d´alimentation
                 Capture:
                        Fréquence du défaut: 1
                        Compteur de RAZ: 168
                        Kilometrage: 202694 km
                        Heure: 0
                        Date: 2023.11.08
                        Temps: 09:45:05
                 Capture:
                        Valeur hex: 0x4007
                        Valeur hex: 0x0003
                        Valeur hex: 0x1024
                        Valeur hex: 0x035F
                        Valeur hex: 0x007F
                        Valeur hex: 0x7F80
                        Valeur hex: 0x7D40
    03234 - Fonctionnement limité car état critique du réseau de bord
                000 - -
                 Capture:
                        Etat du défaut: 01100000
                        Compteur de RAZ: 132
                        Kilometrage: 202780 km
                        Heure: 0
                        Date: 2023.11.21
                        Temps: 10:42:26
                 Capture:
                        Valeur hex: 0x0007
                        Valeur hex: 0x0000
                        Valeur hex: 0x3250
                        Valeur hex: 0x379B
                        Valeur hex: 0x007A
                        Valeur hex: 0x7F7F
                        Valeur hex: 0x7FF8
    Adresse 08: Climatronic        Labels: Aucun
       No. pièce Log: 8X0 820 045     Mat: 8X0 820 045
       Pièce: J255 Klima Manuell  0140
       Révision: 0000707S    No. de série: 03030002950774
       VCID: 73EE772012B529B9629-8026
    Adresse 09: Centrale Elec. (J519)       Labels: 8X0-907-063.clb
       No. pièce Log: 8X0 907 063 G    Mat: 8X0 907 063 D
       Pièce: BCM PQ35  M   108 0655
       Révision: 00108 AB
       Codage: 06000A2CA8051A00201840E000000154438B6C0A00CF4922DC0087830041
       No. Atelier: WSC 02051 995 100431
       VCID: 4084E8ECD383C2212FB-8015
    Adresse 15: Airbags (J234)       Labels: 8X0-959-655.clb
       No. pièce Log: 8X0 959 655     Mat: 8X0 959 655
       Pièce: Airbag10.41   H03 0007
       Révision: --------    No. de série: 003DM000WHGH
       Codage: 30314539303330303134554A304C38583053
       Jeu de données ASAM: EV_Airba1041BPAAU210 001012
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 071633F0BE2D35192E1-8052
       Capteur de collision du sac gonflable latéral; côté conducteur:
       No. de série: 3554VRB405V6VQ8CJ0Q$
       Capteur de collision de sac gonflable latéral; côté passager:
       No. de série: 3575HRB405100BSOD8GD
       Capteur de collision du sac gonflable frontal; côté conducteur:
       No. de série: 3585HRB405J00TMO914L
       Capteur de collision par l'arrière:
       No. de série: 3515ZRB405902CBC41CU
    Adresse 16: Volant multifonct. (J527)       Labels: 8X0-953-569.clb
       No. pièce Log: 8X0 953 501 E    Mat: 5K0 953 569 H
       Pièce: LENKS.MODUL   009 0136
       Révision: FF010015    No. de série: 20101019100979
       Codage: 5180204000
       Jeu de données ASAM: EV_VW360SteerWheelUDS A03004
       ROD: EV_VW360SteerWheelUDS.rod
       VCID: 3C7C9C1CB76BA6C1733-8069
    Adresse 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
       No. pièce Log: 8X0 920 930     Mat: 8X0 920 930
       Pièce: KOMBI         H07 0124
       No. de série: 00000000000000
       Codage: 11DE00
       Jeu de données ASAM: EV_Kombi_UDS_VDD_AU10 A04086
       ROD: EV_Kombi_UDS_VDD_AU10.rod
       VCID: 77F64330CECD45995E1-8022
    Adresse 19: Gateway CAN (J533)       Labels: 8X0-907-468.clb
       No. pièce Log: 8X0 907 468     Mat: 8X0 907 468
       Pièce: GAT 5CAN 1LIN H04 0083
       Révision: 1D080023    No. de série: 2341D1092880D3
       Codage: FBCF0A64000100010053
       VCID: 020022E49D0F103179F-8057
       Sous-système 1 - No. pièce Log: 6R0 915 181 B    Mat: 6R0 915 181
       Pièce: J367-BDM  H07 0150
       Sous-système 2 - No. pièce Log: 8K0 959 663     Mat: 8K0 959 663
       Pièce: J532_DCDCStab  H17 0042
    Adresse 25: Anti-démarrage (J334)       Labels: 5K0-920-xxx-25.clb
       Pièce: IMMO          H07 0124
       No. de série:
       Codage: 000002
       Jeu de données ASAM: EV_Immo_UDS_VDD_AU10 A04008
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Adresse 42: Porte conducteur (J386)       Labels: 8X0-959-793.clb
       No. pièce Log: 8X0 959 793 B    Mat: 8X0 959 793 B
       Pièce: TSG FA        H09 0409
       Révision: --------    No. de série: --------------
       Codage: 011802200100120102
       VCID: 4C9CCCDCEFCB1641C33-8019
    Adresse 44: Direction assistée        Labels: 6Q0-423-156.clb
       No. pièce: 6R0 423 156 B
       Pièce: LenkhilfeTRW        V277
       Codage: 11251
       VCID: 2F66BB50EA1D4D59C61-807A
    Adresse 52: Porte passager (J387)       Labels: 8X0-959-792.clb
       No. pièce Log: 8X0 959 792 B    Mat: 8X0 959 792 B
       Pièce: TSG BF        H09 0409
       Codage: 011002200100120102
       VCID: 4B9ECFC0EAC51179CA9-801E
    Adresse 56: Radio (R)       Labels: Aucun
       No. pièce Log: 8X0 035 180 A    Mat: 8X0 035 180
       Pièce: RMC           H45 0530
       No. de série: AUZ4Z1K1131713
       Codage: 01000000000051070002000003010000010000
       VCID: 3260B2246D2F60B1A9F-8067
       Sous-système 1 - No. pièce Log: 8X0 919 603     Mat: 8X0 919 603
       Pièce: DU6 Basic  H42 0084
    00417 - Haut-parleur de médiums et de graves AV G (R101)
                011 - Coupure
                 Capture:
                        Etat du défaut: 01101011
                        Priorité du défaut: 4
                        Compteur de RAZ: 140
                        Kilometrage: 202873 km
                        Heure: 0
                        Date: 2024.01.04
                        Temps: 15:58:44
                 Capture:
                        Tension: 12.10 V
    00418 - Haut-parleur de médiums et de graves AV D (R102)
                011 - Coupure
                 Capture:
                        Heure: 0
                        Date: 2024.01.04
                        Temps: 15:58:44
                 Capture:
                        Tension: 12.10 V
    00821 - Antenne 2 pour autoradio (R93)
                007 - c.c. à la masse
                 Capture:
                        Etat du défaut: 01100111
                        Heure: 0
                        Date: 2024.01.04
                        Temps: 17:42:00
                 Capture:
                        Tension: 12.20 V
    Fin-------------------------(Temps écoulé: 01:56)--------------------------
  3. Re: Unable to update RMC1 MMI
    Jan 2024
    Brest, France
    hi
    how can i unstalled him ? i try so many version but allway ended up by an error conflict version
  4. Re: Unable to update RMC1 MMI
    132 Post(s)
    1979 Post(s)
    Please do a scan in English.
  5. Re: Unable to update RMC1 MMI
    Jan 2024
    Brest, France
    Sure here it is sry for late aswer had to find an english version of vcds
    Saturday,06,January,2024,20:29:12:00009
    VCDS Version: 19.6.1.0 (x64)
    Data version: 20190529 DS308.0
    Ross-Tech: Home
    VIN: WAUZZZ8X7BB031740 License Plate: AUDI A1 EG
    Mileage: 202930km-126094mi Repair Order:
    Chassis Type: 8X-AU21 (8X0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WAUZZZ8X7BB031740 Mileage: 202930km-126094miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CBZA) Labels:. 03F-906-070-CBZ.clb
    Part No SW: 03F 906 070 CA HW: 03F 906 070 CA
    Component: SIMOS10.24H01 9873
    Revision: --H01--- Serial number:
    Coding: 00110096232401080000
    Shop #: WSC 00046 790 00000
    ASAM Dataset: EV_ECM12TFS02103F906070CA 004010
    ROD: EV_ECM12TFS021.rod
    VCID: 63CFF24E6A55B157E4-8036
    No fault code found.
    Readiness: 0010 0101
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 AH HW: 6R0 907 379 AH
    Component: ESP8.2i front H07 0004
    Revision: --------
    Coding: 310428E9217000B38C2C14E684D100540E00
    Shop #: WSC 00046 000 00000
    VCID: 040DD1D2831B166FBD-8050
    3 Faults Found:
    02214 - Tire Pressure Warning
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 27
    Reset counter: 169
    Mileage: 202693 km
    Time Indication: 0
    Date: 2023.11.08
    Time: 08:11:58
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0000
    Hex Value: 0x1203
    Hex Value: 0x2BBA
    Hex Value: 0x1980
    Hex Value: 0x7F7C
    Hex Value: 0x80F8
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 202694 km
    Time Indication: 0
    Date: 2023.11.08
    Time: 09:45:05
    Freeze Frame:
    Hex Value: 0x4007
    Hex Value: 0x0003
    Hex Value: 0x1024
    Hex Value: 0x035F
    Hex Value: 0x007F
    Hex Value: 0x7F80
    Hex Value: 0x7D40
    03234 - Functionality Limited due to Critical Electrical Condition
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 202780 km
    Time Indication: 0
    Date: 2023.11.21
    Time: 10:42:26
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0000
    Hex Value: 0x3250
    Hex Value: 0x379B
    Hex Value: 0x007A
    Hex Value: 0x7F7F
    Hex Value: 0x7FF8
    Address 08: Auto HVAC Labels: None
    Part No SW: 8X0 820 045 HW: 8X0 820 045
    Component: J255 Klima Manuell 0140
    Revision: 0000707S Serial number: 03030002950774
    VCID: 73EF820E12B521D794-8026
    Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
    Part No SW: 8X0 907 063 G HW: 8X0 907 063 D
    Component: BCM PQ35 M 108 0655
    Revision: 00108 AB
    Coding: 06000A2CA8051A00201840E000000154438B6C0A00CF4922DC 0087830041
    Shop #: WSC 02051 995 100431
    VCID: 40851DC2D383CA4FD9-8014
    Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
    Part No SW: 8X0 959 655 HW: 8X0 959 655
    Component: Airbag10.41 H03 0007
    Revision: -------- Serial number: 003DM000WHGH
    Coding: 30314539303330303134554A304C38583053
    ASAM Dataset: EV_Airba1041BPAAU210 001012
    VCID: 0717C6DEBE2D3D77D8-8052
    Crash sensor for side airbag: driver side:
    Serial number: 3554VRB405V6VQ8CJ0Q$
    Crash sensor for side airbag: front passenger side:
    Serial number: 3575HRB405100BSOD8GD
    Crash sensor for front airbag: driver side:
    Serial number: 3585HRB405J00TMO914L
    Rear Impact Crash Sensor:
    Serial number: 3515ZRB405902CBC41CU
    Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
    Part No SW: 8X0 953 501 E HW: 5K0 953 569 H
    Component: LENKS.MODUL 009 0136
    Revision: FF010015 Serial number: 20101019100979
    Coding: 5180204000
    ASAM Dataset: EV_VW360SteerWheelUDS A03004
    VCID: 3C7D6932B76BAEAF85-8068
    Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
    Part No SW: 8X0 920 930 HW: 8X0 920 930
    Component: KOMBI H07 0124
    Serial number: 00000000000000
    Coding: 11DE00
    ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
    VCID: 77F7B61ECECD4DF7A8-8022
    Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
    Part No SW: 8X0 907 468 HW: 8X0 907 468
    Component: GAT 5CAN 1LIN H04 0083
    Revision: 1D080023 Serial number: 2341D1092880D3
    Coding: FBCF0A64000100010053
    VCID: 0201D7CA9D0F185F8F-8056
    Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
    Component: J367-BDM H07 0150
    Serial number: 00000000009370155819
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    Serial number: 10293000941021200181
    2 Faults Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 12
    Reset counter: 180
    Mileage: 202873 km
    Time Indication: 0
    Date: 2024.01.04
    Time: 18:02:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.00 V
    Count: 18
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 182
    Mileage: 202934 km
    Time Indication: 0
    Date: 2024.01.07
    Time: 17:17:00
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 4.80 V
    Count: 0
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Component: IMMO H07 0124
    Serial number:
    Coding: 000002
    ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
    Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
    Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
    Component: TSG FA H09 0409
    Revision: -------- Serial number: --------------
    Coding: 011802200100120102
    VCID: 4C9D39F2EFCB1E2F35-8018
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11251
    Shop #: WSC 00046
    VCID: 2F674E7EEA1D453730-807A
    Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
    Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
    Component: TSG BF H09 0409
    Coding: 011002200100120102
    VCID: 4B9F3AEEEAC519173C-801E
    Address 56: Radio (R) Labels: None
    Part No SW: 8X0 035 180 A HW: 8X0 035 180
    Component: RMC H45 0530
    Serial number: AUZ4Z1K1131713
    Coding: 01000000000051070002000003010000010000
    VCID: 3261470A6D2F68DF5F-8066
    Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
    Component: DU6 Basic H42 0084
    Serial number: 9462JK0A0031180
    4 Faults Found:
    00417 - Left Front DSP Mid-Bass Speaker (R101)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 140
    Mileage: 202873 km
    Time Indication: 0
    Date: 2024.01.04
    Time: 15:58:44
    Freeze Frame:
    Voltage: 12.10 V
    00418 - Front Right DSP Mid-Bass Speaker (R102)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 140
    Mileage: 202873 km
    Time Indication: 0
    Date: 2024.01.04
    Time: 15:58:44
    Freeze Frame:
    Voltage: 12.10 V
    00821 - Antenna 2 for Radio (R93)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 140
    Mileage: 202873 km
    Time Indication: 0
    Date: 2024.01.04
    Time: 17:42:00
    Freeze Frame:
    Voltage: 12.20 V
    02444 - Disk Drive Load / Eject Malfunction
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 180
    Mileage: 202873 km
    Time Indication: 0
    Date: 2024.01.04
    Time: 18:57:41
    Freeze Frame:
    ON Time: 0 h
    End-------------------------(Elapsed Time: 02:04)-----------------
  6. Re: Unable to update RMC1 MMI
    Jan 2024
    Brest, France
    Hi !
    No bodys got idea ?
  1. Replies: 1
    Last Post: 01-10-2020, 05:01 PM
  2. Unable to register
    By SirAchie in forum Forum support and issues
    Last Post: 11-10-2017, 07:00 PM
  3. Question Unable to Update MMI 2G HIGH Maps
    By Jimbob21 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-07-2017, 06:23 PM
  4. Question 2.0 TDI unable to connect through OBD
    By OFI in forum Golf MK6 - 2009 - 2013
    Last Post: 10-03-2016, 01:31 AM
  5. Unable to re-start when car is hot.
    By nobby999 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-12-2009, 01:39 PM
