Thread: Tyre pressure system error
  1. Tyre pressure system error
    Mar 2021
    Ripon
    7 Post(s)
    Preview: Tyre pressure system error
    Looking for any suggestions on troubleshooting the tyre pressure monitoring system please.
    About 3 weeks ago the TPMS orange warning started flashing and an error appeared on the digital display show TPMS system error and all four wheels highlighted yellow.
    I checked the pressures and inflated them slightly and reset the system. Warning light keeps coming back after about a week and has been reset 2 more times. Tyres have not lost pressure.
    This happened once before and it sorted itself after about 4-5 resets. I have not scanned the car with OBDeleven tool for any error codes. Just want to ask on here if anyone else has had the same issues recently before I started replacing ABS sensors. Will OBDeleven indicate a faulty sensor or will I need to do a wheel speed test?
    Can you fool these passive sensors by setting them at low pressure then inflating the tyres to the correct pressure?
    Merry Xmas to all.
  2. Re: Tyre pressure system error
    133 Post(s)
    1987 Post(s)
    Is the system direct or indirect?
  3. Re: Tyre pressure system error
    Mar 2021
    Ripon
    7 Post(s)
    It is a passive or indirect system. I have scanned with OBDeleven and got the fault code C1146F0; Tyre pressure monitoring display not available.
    I also did a live data test on all four ABS sensors. They all reported the same speeds but both front sensors gave "invalid" readings for direction of rotation and air gap.
    I guess the first step is to try and remove both front ABS sensors without damaging them and give them a clean.
  4. Re: Tyre pressure system error
    Mar 2021
    Ripon
    7 Post(s)
    Indirect
  5. Re: Tyre pressure system error
    133 Post(s)
    1987 Post(s)
    Are all four tyres the same brand and all within a couple of mm of each other. Can you see the ABS ECU software verion number?
  6. Re: Tyre pressure system error
    Mar 2021
    Ripon
    7 Post(s)
    All tyres are Michelin premacy 4, same age with 3-4mm tread. Rears are starting to feather, if that makes a difference.
    Touch wood, once I cleared the codes, the warning light has not returned. Where would I find the ABS ECU software version?
  7. Re: Tyre pressure system error
    133 Post(s)
    1987 Post(s)
    If you read the ABS ECU it should have a software level number, a four numerical digit code.
  1. Error "tyre pressure monitoring system"
    By Mittens247 in forum Passat - B8 Forum - 2015 -
    Last Post: 23-04-2022, 02:46 PM
  2. Tyre Pressure System not working = new tyre
    By MrNicenice in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-01-2018, 01:55 PM
  3. Tyre pressure warning system
    By Hammer2001 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-06-2015, 10:04 PM
  4. Tyre Pressure Monitoring System
    By D4D in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 18-02-2013, 09:16 AM
  5. Tyre Pressure Monitoring System (TPMS)?
    By Bratty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-08-2010, 10:19 AM
