Thread: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
  1. Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    Aug 2015
    Cambridgeshire
    Hi all,
    Can anyone help with an issue that has me a little perplexed.
    The owner says the bulb light came on after the battery was replaced but none of the bulbs are out.
    I have scanned the car and it has returned two codes:
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
    Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
    Component: ESP9.0i front H03 0003
    Serial number: --------------
    Coding: 23DD2485212600C2C4172471845200800905
    Shop #: WSC 31414 790 50316
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
    VCID: 0F7BBCE437DDBCA2869-805A
    1 Fault Found:
    C1076 29 [008] - Signal Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 12
    Mileage: 120340 km
    Date: 2023.09.13
    Time: 10:36:58
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 P HW: 6R0 937 087
    Component: BCM PQ25 H+4 H34 0411
    Revision: BF034001 Serial number: 0581 263131037
    Coding: 24B42B3F08E12400923008002D2B0CD000C0410F6006000020 0020000000
    Shop #: WSC 31414 790 31414
    VCID: 4ACD6DF00CBFD98A917-801E
    Subsystem 1 - Part No SW: 6R0 959 802 AT HW: 6R0 959 802 AT Labels: 6R0-959-802.CLB
    Component: J386__TSG_FT 003 8611
    Serial number: KU0KU023091300014553
    Coding: 1000A0
    Subsystem 2 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB Labels: 6R0-959-801.CLB
    Component: J387__TSG_BT 003 8611
    Serial number: KU0KU020091300015249
    Coding: 0000A0
    Subsystem 3 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 00 001 0103
    Coding: 000000
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    Subsystem 5 - Part No: 1K8 951 171 A
    Coding: 000000
    Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
    Component: J388__TSG_HL 003 8610
    Serial number: KU0KU007101300011104
    Coding: 0000A0
    Subsystem 7 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
    Component: J389__TSG_HR 003 8610
    Serial number: KU0KU023091300011897
    Coding: 1000A0
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 41
    Time Indication: 0
    I can clear them both which turns the dash bulb warning light off, but the ABS one comes back.
    Any suggestions as to where to look would be much appreciated.
  2. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    2005 Post(s)
    I haven't seen that ABS code before so I would put it on ODIS under Guided Fault Finding but not many indi's have ODIS.
  3. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    Aug 2015
    Cambridgeshire
    Thanks Crasher
    Oddly, the code has cleared itself
  4. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    2005 Post(s)
    I hate it when I they do that, I want to know why!
  5. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    Aug 2015
    Cambridgeshire
    I had the car back this weekend to do an oil and filter change....and guess what, the fault light returned as I was reversing the car off my drive. This time I took a photo of it.
    The car was switch off and parked up for a few minutes while I went to grab my VCDS. I opened the bonnet just to check I hadn't done something silly during the oil change, and closed it again. Scanned the car, but not error code this time, so I decided to test drive it again but the light had disappeared.
    The only thing that has happened both times, that the owner has not done, is open the bonnet.......could be a coincidence. Here's a photo of the light.
    The last time this happened I mentioned it to someone who suggested it isn't necessarily an ABS issue and could be caused by a faulty wire in the door loom. He could be right but it's the bonnet in this case. I didn't care to look as I needed to return the car, but no doubt there may be a further update if it returns.
  6. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    2005 Post(s)
    I suspect you have a poor connection in a bulb holder and shutting the bonnet gives it a good rattle.
  7. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    Aug 2015
    Cambridgeshire
    I think you could be right.......will see what happens if I ever do any work on it again
  8. Re: Polo 2013 - Bulb Light on Dash with Fault Code 1006 - Door Contact Switch
    Apr 2024
    Poland
    check the stop/reverse light + additionally check whether you have not installed some led bulbs that draw too little current, which causes the burnt bulb error.
  1. 2002. POLO 1.9TDI. Alternator Fault and no battery light on dash.
    By prestigej in forum Polo - Derby - Lupo - Fox
    Last Post: 08-06-2021, 08:11 AM
  2. door contact switch
    By abby1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-10-2011, 05:41 PM
  3. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  4. Polo Match courtesy light door switch
    By coopern in forum Polo - Derby - Lupo - Fox
    Last Post: 22-08-2010, 12:53 PM
