Thread: fuel pressure regulation P1065
  1. fuel pressure regulation P1065
    Dec 2023
    ireland
    my 2.0TDI 170bhp passat cc shows up fault code P1065 on VCDS. My symptoms are;
    - rough idling with a tapping sound under the bonnet
    completely fine once moving, quite rough in first gear and reverse too.
    - doesnt want to start unless accelorator pedal is pushed while starting with clutch
    clutch will push itself out rapidly then, like its stuck
    - fuel light came on for a split second while starting once, even though 3/4 tank in it
    im thinking it could be faulty high pressure fuel pump or injectors, maybe both?
    any help in this matter would be greatly appreciated.
  2. Re: fuel pressure regulation P1065
    134 Post(s)
    2009 Post(s)
    P1065 - Fuel Pressure Regulation: Regulation Discrepancy
    Has any work been done recently to the fuel system? Do you use a good brand of fuel?
  1. 1.8T ---> Boost Pressure Regulation issue... ?
    By 2stroke in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2023, 05:40 PM
  2. Please Help Boost Pressure Regulation
    By Mischiu in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2016, 12:41 PM
  3. Replies: 8
    Last Post: 18-01-2013, 05:00 PM
  4. Boost Pressure Regulation
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-05-2009, 02:03 PM
  5. Boost pressure regulation!
    By s_line_junkie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-05-2009, 10:18 AM
