Thread: Parking brake and central locking faults
  1. Parking brake and central locking faults
    Oct 2019
    Chippenham
    I have experienced some problems with Parking brake fault and central locking faults coming on together each morning. Each morning this week I have had both of these messages that come on and stay on the whole journey to work, about 10 miles and then when I leave to go home neither message.
    Not sure how they are connected but now four times they have come on together. any ideas how they can be connected?
  2. Re: Parking brake and central locking faults
    Jul 2023
    uk
    How cold was it in the morning when you set off? Could be linked to a slightly low battery voltage as it cranks when cold, a bit warmer at night and it turns over easier, voltage doesnt drop so much, no error messages.
    I used to get occasional ABS faults on my last A4 B6 when I started it and it was below freezing, the colder the morning the more likely it was to appear. VCDS scans showed no faults.
    Forecast for next week is considerably warmer, it'll be interesting to see if the issue goes away.
  3. Re: Parking brake and central locking faults
    2007 Post(s)
    Could be that the factory fitted AGM battery is on its way out, they last approx 5 years.
  1. Question A6 C6 central locking and indicator faults after heavy rain
    By willbowlinguk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-03-2023, 11:54 PM
  2. Question Parking Brake Switch Faults
    By Oobals in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-10-2021, 06:49 PM
  3. RE passat b6 + parking brake + esp + abs faults
    By jeepster1961 in forum VCDS - General Questions
    Last Post: 10-10-2013, 02:31 PM
  4. 2008 A6 MMI and Parking Brake Faults
    By MClarke in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2008, 12:25 AM
  5. Touran central locking/water ingress faults
    By bigwull in forum Touran - Sharan - Caravelle
    Last Post: 23-12-2007, 05:59 PM
