Thread: Brake Stop! fluid loss but where?
Results 1 to 10 of 13
  1. Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    Car is 02 Passat 1.9TDI estate. Have had brake fluid loss and dash warning but clutch and brakes operate perfectly as normal. Brake fluid leaking onto hot exhaust smell but cannot see where it's coming from. No obvious leaks around callipers or master cylinder but how could it be the slave cylinder as there are no symptoms or pedal to the floor etc?. Any pointers would be appreciated.
  2. Re: Brake Stop! fluid loss but where?
    Jul 2008
    Lisburn
    15 Post(s)
    does your car share a brake and clutch reservoir? if so it could be the pipe work for the clutch around the bulk head?
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  3. Re: Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    Yes, the brake and clutch share the same master cylinder with the clutch operating off the slave cylinder.
  4. Re: Brake Stop! fluid loss but where?
    111 Post(s)
    1858 Post(s)
    Nearly all of the parts are in the plenum, except the clutch pressure pipe which exits through the grommet (if it is there) and then passes over the exhaust and box. Just about all the parts are obsolete, what is the VIN?
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  5. Re: Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    VIN is WVWZZZ3BZ3E150016
  6. Re: Brake Stop! fluid loss but where?
    111 Post(s)
    1858 Post(s)
    My suspicion would be the clutch pressure hose 8E2 721 465 AM but this went obsolete mainstream over three years ago.
  7. Re: Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    Is that the hose in the plenum that's connected to the master cylinder?.
  8. Re: Brake Stop! fluid loss but where?
    111 Post(s)
    1858 Post(s)
    Yes, then it comes out of the plenum, across the bulkhead to the slave cylinder.
  9. Re: Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    Thanks Crasher. Where do these lines normally fail; at the end where it presses into the slave?.
  10. Re: Brake Stop! fluid loss but where?
    Jun 2006
    6 Post(s)
    Actually turned out to be a tiny leak from rear caliper only visible when the car was parked on a dry concrete surface where the drip from a leak behind the parking brake actuation arm.
  1. Question Brake fluid, coolant, powers steering fluid.... advise please
    By IlovemyVW in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2013, 07:43 PM
  2. brake fluid loss any ideas welcome
    By bigtruck in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2012, 12:07 PM
  3. Brake fluid loss
    By joeynicholls in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-04-2011, 05:57 PM
  4. Brake fluid loss!
    By Rogg2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2010, 11:04 AM
  5. Loss of brake fluid
    By Berksplat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-01-2010, 01:25 PM
