Thread: Cruise control acting up
  1. Cruise control acting up
    Sep 2023
    GB
    Hi all
    Have a funny control control issue. The on, cancel, off lever on the arm beside the steering wheel allows me to turn the cruise control on and off but doesn't let me set or reset the speed.
    I know it is on because the indicator comes up on the dash, but stays this way regardless of the buttons I press such as set and reset. When I switch the cruise control off it just goes back to the mileage reading.
    Checked on VCDS/odb eleven but there is no faults codes showing and it is enabled as far as I can see.
    Is it as simple as the buttons not working or is there something more I can check to get it working?
    Sent from my SM-S911B using Tapatalk
  2. Re: Cruise control acting up
    Sep 2023
    GB
    Just a wee update on this. Tried on my way to work to set the cruise control and surprisingly it set. In all gears selected except 6th.
    Has anyone come across this before? Is there something I can change with VCDS to get it to work in all gears?
  3. Re: Cruise control acting up
    134 Post(s)
    2007 Post(s)
    Start with a code read.
  4. Re: Cruise control acting up
    Sep 2023
    GB
    Hi Crasher I'm not sure how to do it with ODBeleven.
    I have found out yesterday after a bit more probing that it only happens when the gear indicator switches off. The gear indicator when I go into 6th gear is on for about a second then turns off and disables the cruise control with it.
    I have read on other forums for other vehicles it could be that the gear ratios for 6th has changed and the ECU doesn't recognise the gear, is this the case? Is there anything I can try to run this out or confirm it?
  5. Re: Cruise control acting up
    134 Post(s)
    2007 Post(s)
    What is the vIN?
  6. Re: Cruise control acting up
    Sep 2023
    GB
    What is the vIN?
    Just sent it Crasher. Thanks
  7. Re: Cruise control acting up
    134 Post(s)
    2007 Post(s)
    I don't know how with OBD11 but I would check the clutch and brake pedal hall sender signals and monitor them whilst driving to see if they triggered when the shouldn't but also if you can scan the steering column controller it may show the column stalk is defective.
  1. Replies: 9
    Last Post: 17-02-2016, 06:59 PM
  2. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  3. Question Cruise control button but no Cruise control
    By ludikris in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-09-2010, 10:34 AM
  4. Instalation of cruise control-does existing control modul support it?
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2009, 09:42 PM
  5. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
