Thread: Major electrical issue
Results 1 to 8 of 8
  1. Major electrical issue
    Dec 2023
    France
    Dear all,
    I'm coming here because I'm facing to a big isue on my A6 C7 bi-tdi (2015).
    I try to do a summary:
    - March 2022 = I see some default on VCDS scan, mainly on seat memory
    - June 2022 = I start to have short message (less than 2sec) about parking brake and light assistant default, also the reverse camera cut 1-2 sec and come back
    - During 2022 summer the default frequency increase
    - September 2022 = change of the battery + coding, the default frequency decrease but not dissappear
    - June 2023 = high increase of default frequency, I clean the ground connector below the windshield, big drop of default frequency
    - From 2 months the frenquency of default increase a lot and from Tuesday some defaults stay = from driver door I have no control to the seat memory, to the passenger window and also parking brake + airbag lights stay on
    I attach the last scan, as you can see 2 calculators cannot be reached.
    Any idea of what I can do ? I'm really worry to go to the dealer with this type of defaults...
    Thanks a lot.
  2. Re: Major electrical issue
    Dec 2023
    France
    Code:
    Tuesday,28,November,2023,18:13:28:00009
    VCDS Version: 20.4.2.0
    Data version: 20200730 DS317.0
    Ross-Tech: Home
    VIN: WAUZZZ4G0GN085215   License Plate:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53
              55 5F 62 6C 6D 72 85 88 89 8F 90 A9 AC C0
    VIN: WAUZZZ4G0GN085215   Mileage: 179296km-111409miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: Malfunction 0010
    30-Special Function II -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: Malfunction 0010
    3B-Sensor Elect. -- Status: OK 0000
    42-Door Elect, Driver -- Status: Cannot be reached 0100
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Cannot be reached 0100
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: Malfunction 0010
    85-On Board Cam. -- Status: OK 0000
    88-Multicont. Seat Driver -- Status: Cannot be reached 0100
    89-Multicont. Seat Pass. -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    AC-Reductant Control -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0008
       Revision: 54H23---
       Coding: 122A4032252603030800
       Shop #: WSC 30173 003 1048576
       ASAM Dataset: EV_ECM30BTD0114G0907589F 001008
       ROD: EV_ECM30BTD0114G0907589F.rod
       VCID: 377D9EDB8E4D8D3EE2-8062
    7 Faults Found:
    9803 - No Communications with Parking Assist Control Module A
              U0159 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179245 km
                        Date: 2023.11.28
                        Time: 13:10:47
                        Engine speed: 1752.50 /min
                        Normed load value: 86.7 %
                        Vehicle speed: 35 km/h
                        Coolant temperature: 38 °C
                        Intake air temperature: 8 °C
                        Ambient air pressure: 980 mbar
                        Voltage terminal 30: 13.660 V
                        Unlearning counter according OBD: 40
                        Limitation: accelerator pedal: 244.7 Nm
                        CAN status - engine control module-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        CAN status - transmission control module-Bits 0-7: 0
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
                        selected gear-Bits 0-7: 4
    12909 - Databus
              U1121 00 [032] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179005 km
                        Date: 2023.11.24
                        Time: 08:19:01
                        Engine speed: 1397.00 /min
                        Vehicle speed: 87 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 10 °C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 14.580 V
                        Unlearning counter according OBD: 36
                        Limitation: accelerator pedal: 0.0 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 104
                        selected gear-Bits 0-7: 7
    10585 - Door Control Module - Passenger's Door
              U0200 00 [032] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:57
                        Engine speed: 1067.00 /min
                        Normed load value: 38.8 %
                        Vehicle speed: 66 km/h
                        Coolant temperature: 74 °C
                        Intake air temperature: 7 °C
                        Voltage terminal 30: 14.560 V
                        Unlearning counter according OBD: 39
                        Limitation: accelerator pedal: 50.8 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 40
    5615 - Door Control Module - Driver's Door
              U0199 00 [047] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:01
                        Engine speed: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 12 °C
                        Voltage terminal 30: 11.240 V
                        Cruise Control System (CCS): status-Bits 0-7: 47
                        selected gear-Bits 0-7: 0
    10586 - Door Control Module - Rear Left
              U0201 00 [047] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:01
    10587 - Door Control Module - Rear Right
              U0202 00 [032] - No Communications
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:57
                        Engine speed: 1067.50 /min
                        Voltage terminal 30: 14.600 V
    4717 - Body Control Module (Central Electric)
              U0140 00 [032] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:10
                        Engine speed: 778.50 /min
                        Normed load value: 16.9 %
                        Coolant temperature: 90 °C
                        Ambient air pressure: 1000 mbar
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRDW H19 1015
       Revision: --H19---
       Coding: 000001
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 77FD5EDBCECD4D3E22-8022
    No fault code found.
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V2.clb
       Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
       Component: ESP9 Premium  H01 0530
       Revision: --------    Serial number: --------------
       Coding: 49A79E4192E579829B00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESP9BOSCHAU57X 004018
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 4189F003D089C38E5C-8014
    5 Faults Found:
    199936 - Function Restricted due to Missing Message(s)
              U1111 00 [040] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179249 km
                        Date: 2023.11.28
                        Time: 17:08:17
                        VzRef: 4D
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        Uz: BB
    124416 - Function Restriction due to Faults in Other Modules
              U1113 00 [040] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 1F
                        Uz: BD
                        Unlearning counter according OBD: 35
    122368 - Function Restricted due to Missing Message(s)
              U1111 00 [040] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179077 km
                        Date: 2023.11.24
                        Time: 17:44:57
                        VzRef: 2B
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        Uz: BE
    122624 - Function Restricted due to Missing Message(s)
              U1111 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:01
                        VzRef: 00
                        Bit Info 1: C0
                        Bit Info 2: 0F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        Uz: 92
    200192 - Function Restriction due to Implausible Message(s)
              U1112 00 [032] - -
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
       Component: BCM2 2.0      H37 0572
       Revision: 00002001
       Coding: 05A96F0E000000000000
       VCID: 7DF14CF3E4F1676E78-8028
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 39
                        Reset counter: 189
                        Time Indication: 0
    Address 06: Seat Mem. Pass (J521)       Labels: None
       Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
       Component: MEM-BFS       H04 0157
       Revision: AA000000    Serial number: 00000152607594
       Coding: 0018320000006201000001010101112030303333283333
       VCID: 397998E3B0599B4E14-806C
    2 Faults Found:
    01320 - Control Module for Climatronic (J255)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 6
                        Fault Frequency: 13
                        Reset counter: 231
                        Mileage: 178927 km
                        Time Indication: 0
                        Date: 2023.11.23
                        Time: 08:33:17
    01332 - Door Control Module; Passenger Side (J387)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179212 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 08:12:57
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 17091500040888
       Coding: 36021178250000
       ASAM Dataset: EV_AirCondiComfoUDS 003008
       ROD: EV_AirCondiComfoUDS_003.rod
       VCID: 63C51A8B6A55B19E6E-8036
    8 Faults Found:
    0242 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:10
                        Voltage terminal 30: 14.37 V
                        Outside air temperature: 7.0 °C
                        Engine speed: 780 /min
    0244 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179282 km
                        Date: 2023.11.28
                        Time: 17:33:50
                        Voltage terminal 30: 14.36 V
                        Outside air temperature: 4.0 °C
                        Interior temperature: 21.39 °C
    0248 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 190
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:04
                        Terminal 15 status: Terminal 15 on
    0249 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 230
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:57
    0291 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179295 km
                        Date: 2023.11.28
                        Time: 17:59:06
                        Voltage terminal 30: 14.39 V
    0315 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179263 km
                        Date: 2023.11.28
                        Time: 17:18:30
                        Voltage terminal 30: 14.32 V
                        Outside air temperature: 3.5 °C
                        Engine speed: 1652 /min
    0318 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 190
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:04
                        Voltage terminal 30: 11.58 V
                        Outside air temperature: 6.5 °C
                        Engine speed: 1010 /min
    0319 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 230
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:57
                        Engine speed: 1070 /min
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0311
       Revision: 15020001    Serial number: 00001167872902
       Coding: 0105001440349FE0C10140C780001800CF9CC70A2E08020180000894E101130200400034030000
       VCID: 71E960C3A8A9130EEC-8024
       Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119   Labels: 1KX-955-119.CLB
       Component: WWS57X 150804  H38 0080
       Serial number:         150827122837
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Component: G397_RLFS  H06 0004
       Serial number: 20660130
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 22 09 2015  00000875
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA121533000015505811
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H03 0003
       Serial number: 1639C8C7000000000001
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 228
                        Mileage: 179131 km
                        Time Indication: 0
                        Date: 2023.11.27
                        Time: 08:24:34
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1006G22C
       Coding: 30333130313730323731554A304C34473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 3B7582EBB265A95E06-806E
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB405B3KB90B99
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB405H3KGI29OAW
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB40613I0ASIP5H
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB405T3I0AS61DH
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB401A535LQH9AP
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB4014535LQD298
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
       Component: Lenks.Modul   H06 0005
       Revision: C0068538    Serial number: 90862OIK000J4
       Coding: 000035
       VCID: 3B7582EBBA65A95E06-806E
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0010
       Serial number: 14 08 2015  F0043117
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 229
                        Mileage: 179209 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 08:10:00
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
       Component: TDieRdw       H11 0104
       Revision: 07001088    Serial number: 658150915596019
       Coding: 13AF12000B410008030000
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K_AU57.rod
       VCID: 326BAFCF652F6816D5-8066
    1 Fault Found:
    16776970 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179249 km
                        Date: 2023.11.28
                        Time: 17:08:17
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001986513
       Coding: C0CD078118
       ASAM Dataset: EV_GatewPkoUDS 001028
       ROD: EV_GatewPkoUDS_001_AU57.rod
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
       Component: J367-BDMHella  H03 8041
       Serial number: 4112157903
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663 F
       Component: J532_DCDCStab  H23 0022
       Serial number: 1507170000000000023A
    12 Faults Found:
    5057 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:10
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.5 V
                        Control Module temperature: 27 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: standstill detected
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 0
    5505 - Body Control Module (Central Electric 2)
              U0141 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179282 km
                        Date: 2023.11.28
                        Time: 17:33:49
                        Control Module temperature: 18 °C
                        IN ESP_standstill flag: no standstill detected
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5072 - Door Control Module - Driver's Door
              U0199 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 189
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:57:50
                        Voltage terminal 30: 12.1 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 7 °C
                        System status: Awake_Timer_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status via CAN: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
    5073 - Door Control Module - Passenger's Door
              U0200 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:56
                        Voltage terminal 30: 14.6 V
                        Control Module temperature: 15 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5074 - Door Control Module - Rear Left
              U0201 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 189
                        Mileage: 178887 km
                        Date: 2023.11.23
                        Time: 07:58:03
                        Control Module temperature: 6 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    5075 - Door Control Module - Rear Right
              U0202 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179212 km
                        Date: 2023.11.28
                        Time: 08:12:56
                        Control Module temperature: 14 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5268 - Vehicle Positioning System Interface Control Module
              U106F 00 [008] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 226
                        Mileage: 179005 km
                        Date: 2023.11.24
                        Time: 08:19:00
                        Control Module temperature: 20 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5506 - Control Module for Rear Lid Electronics
              U1047 00 [008] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:05
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5274 - Seat/Mirror Postion Control Module - Driver
              U0208 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 230
                        Mileage: 179235 km
                        Date: 2023.11.28
                        Time: 08:30:32
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5046 - Control Module for Multi-Contour Seat; Driver Side
              U1083 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 221
                        Reset counter: 191
                        Mileage: 178887 km
                        Date: 2023.11.22
                        Time: 18:52:28
                        Voltage terminal 30: 14.4 V
                        Voltage terminal 15: 14.3 V
                        Control Module temperature: 31 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5047 - Control Module for Multi-Contour Seat; Passenger Side
              U1085 00 [008] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 24
                        Reset counter: 231
                        Mileage: 179013 km
                        Date: 2023.11.24
                        Time: 08:25:40
                        Control Module temperature: 21 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 2
                        Reset counter: 230
                        Mileage: 179245 km
                        Date: 2023.11.28
                        Time: 10:41:35
                        Voltage terminal 30: 12.5 V
                        Control Module temperature: 11 °C
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 16091500040353
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
       ROD: EV_ClimaContrUnitRearUDS_003.rod
       VCID: 3D718CF3AC71A76E38-8068
    1 Fault Found:
    0083 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179266 km
                        Date: 2023.11.28
                        Time: 17:20:01
                        Voltage terminal 30: 14.82 V
    Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000084617
       Coding: 01010200000000000001020202
       Shop #: WSC 58921 001 1048576
       VCID: 64C71997675BB6A697-8030
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Component: MEM-FS        H04 0157
       Revision: AA000000    Serial number: 00000151187543
       Coding: 00183B0000016201000001010101112030303333203333
    4 Faults Found:
    03657 - Control Module for Multicontour Seat; Front Passenger-Side
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 254
                        Reset counter: 231
                        Mileage: 178887 km
                        Time Indication: 0
                        Date: 2023.11.23
                        Time: 07:59:13
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 12
                        Reset counter: 231
                        Mileage: 178927 km
                        Time Indication: 0
                        Date: 2023.11.23
                        Time: 08:33:17
    01331 - Door Control Module; Driver Side (J386)
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 189
                        Mileage: 179199 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 07:57:49
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179212 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 08:12:57
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820A5UZ+
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 366393DF89477436F9-8062
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H53 0202
       Revision: 00000001    Serial number: 0000232938
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A7B87EFBD5F90561D-806E
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0381145338
       Coding: 01000E3820B93881C320090408030F470000000000000000000000000000
       Subsystem 1 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Component: GEB.F.Heckoef  H16 0811
       Serial number: 93619860
    11 Faults Found:
    03423 - Control Module for Vehicle Positioning System Interface
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 51
                        Reset counter: 231
                        Time Indication: 0
    01299 - Diagnostic Interface for Data Bus (J533)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 44
                        Reset counter: 231
                        Time Indication: 0
    00317 - Rear Lid Control Module (J605)
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 0
                        Reset counter: 0
                        Mileage: 0 km
                        Time Indication: 0
    01334 - Door Control Module; Rear Right (J389)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 50
                        Reset counter: 231
                        Time Indication: 0
    01333 - Door Control Module; Rear Left (J388)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 37
                        Reset counter: 189
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 49
                        Reset counter: 231
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 35
                        Reset counter: 189
                        Time Indication: 0
    00457 - Central Electronics Control Module / BCM (J519)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 44
                        Reset counter: 231
                        Time Indication: 0
    00466 - Control Module for Steering Column Electronics (J527)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 23
                        Reset counter: 231
                        Mileage: 178923 km
                        Time Indication: 0
                        Date: 2023.11.23
                        Time: 08:30:17
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 227
                        Mileage: 179098 km
                        Time Indication: 0
                        Date: 2023.11.25
                        Time: 11:17:28
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0511
       Coding: 011F17015E20628202080002
       VCID: 4683E31FF1A7E4B669-8012
    3 Faults Found:
    01964 - Control Module for Seat & Steering Column Memory (J136)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 227
                        Mileage: 179050 km
                        Time Indication: 0
                        Date: 2023.11.24
                        Time: 17:19:58
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 9
                        Reset counter: 191
                        Mileage: 179199 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 07:58:04
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 9
                        Reset counter: 191
                        Mileage: 179199 km
                        Time Indication: 0
                        Date: 2023.11.28
                        Time: 07:58:04
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
       Component: EPB-4         H04 0015
       Revision: --------    Serial number: 00000001600869
       ASAM Dataset: EV_ParkiBrake 001028
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D51BCB37C1137EE88-8078
    3 Faults Found:
    463104 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:09
                        Voltage terminal 30: 14.8 V
                        Internal Fault ID: 153
                        Network management state: normal
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
    467968 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 189
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:01
                        Voltage terminal 30: 11.3 V
                        Internal Fault ID: 208
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    335360 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179282 km
                        Date: 2023.11.28
                        Time: 17:33:48
                        Internal Fault ID: 209
                        Vehicle speed: 48 km/h
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Internal Parking Brake state: Dynamic
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
       Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0100
       Coding: 04FA02202A130200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
       ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
       VCID: 3467A9D79F3B6626C7-8060
       Led Headlamp Powermodule Left:
       Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7560
       Coding: E01F00
       Led Headlamp Powermodule Right:
       Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7560
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
    5 Faults Found:
    13706045 - Databus
              U1121 00 [008] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179249 km
                        Date: 2023.11.28
                        Time: 17:08:18
    13705736 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 229
                        Mileage: 179194 km
                        Date: 2023.11.27
                        Time: 18:01:57
    13705481 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 11
                        Reset counter: 229
                        Mileage: 179077 km
                        Date: 2023.11.24
                        Time: 17:44:46
    13705482 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 228
                        Mileage: 179077 km
                        Date: 2023.11.24
                        Time: 17:44:55
    5353456 - Fog mode active
              C118E 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 5
                        Reset counter: 40
                        Mileage: 178951 km
                        Date: 2023.11.23
                        Time: 17:21:25
    Address 5F: Information Electr. (J794)       Labels:* None
       Part No SW: 4G1 035 044 R    HW: 4G1 035 044
       Component: MU-H-LN-EU    042 0335
       Serial number: A589I0F7538611
       Coding: 01750201FF0A000013110001000A00102F0006E5F1700100DF
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
       VCID: 2E53BBBF71174CF6B1-807A
       Data medium:
       Subsystem 1 - Part No SW: V03 959 801 F    HW: -----------
       Component: ECE 2015/2016  --- 0122
       Serial number: --------------------
       Display unit 1 for multimedia system:
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Component: DU8 C7 SV  H63 0006
       Serial number: AUZ8Z9FY802KQA
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
       Component: E380 BDT C7  H20 0250
       Serial number: 90349OIG000MY
       Compact Disc Database:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote  --- 1010
    8 Faults Found:
    6920 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 179246 km
                        Date: 2023.11.28
                        Time: 13:14:09
                        Voltage terminal 30: 14.9 V
    6921 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 231
                        Mileage: 179071 km
                        Date: 2023.11.24
                        Time: 17:38:25
                        Voltage terminal 30: 15.0 V
    6922 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 231
                        Mileage: 178927 km
                        Date: 2023.11.23
                        Time: 08:33:33
    6924 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179261 km
                        Date: 2023.11.28
                        Time: 17:16:31
    6935 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 231
                        Mileage: 179122 km
                        Date: 2023.11.27
                        Time: 08:16:46
    7177 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 231
                        Mileage: 179027 km
                        Date: 2023.11.24
                        Time: 08:35:02
                        BAP-BAP_Function_ID: 01
    7180 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 226
                        Mileage: 178994 km
                        Date: 2023.11.24
                        Time: 08:09:35
    7181 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 229
                        Mileage: 179180 km
                        Date: 2023.11.27
                        Time: 17:48:00
    Address 62: Door, Rear Left
    Cannot be reached
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 0275000102002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001.rod
       VCID: 78FF5DE7C3D342462B-802C
    2 Faults Found:
    13705506 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 231
                        Mileage: 179282 km
                        Date: 2023.11.28
                        Time: 17:33:50
                        CAN communication
    13705511 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 231
                        Mileage: 179245 km
                        Date: 2023.11.28
                        Time: 13:10:47
                        passive
    Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number: 251500180
       Coding: 093205C030
       ASAM Dataset: EV_HDSGAu5 001022
       ROD: N/A
    No ASAM data for: "EV_HDSGAu5" (AU57)
    1 Fault Found:
    0048 - ROD - Unknown Error Code
              - 00 [137]
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 189
                        Mileage: 179199 km
                        Date: 2023.11.28
                        Time: 07:58:02
    Address 72: Door, Rear Right (J389)       Labels: 4H0-959-795.clb
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HR        H03 0511
       VCID: 4999E823E0B90BCE84-FFFE
    No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
    Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Revision: --------    Serial number: 262130025421000
       Coding: 60140000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C57B1B7470B3EE69F-8078
    Address 88: Multicont. Seat Driver
    Cannot be reached
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Part No SW: 4G8 881 073     HW: 4G8 881 073
       Component: P2G           H02 0032
       Serial number: 0F7H1VL
       Coding: 262FF0
       ASAM Dataset: EV_P2GPasseSideFrnt 001006
       ROD: EV_P2GPasseSideFrnt.rod
       VCID: 6ED37BBFB1970CF6F1-803A
       Valve Block 1 In Passenger Side Front Seat:
       Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
       Component: PSLª  H02 0023
       Serial number: 00000000000000F8V2M6
    Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
       Component: RGS-VL        H14 0080
       Coding: 00060000031F030000030801424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 3169A0C36029530EAC-8064
    1 Fault Found:
    12583700 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:09
    Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
       Component: RGS-VR        H14 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
    1 Fault Found:
              U1111 00 [008] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 227
                        Mileage: 179078 km
                        Date: 2023.11.24
                        Time: 17:46:09
    Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
       Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0007
       Serial number: 150908201762
       ASAM Dataset: EV_SoundActuaGen2AU64X 003010
       ROD: EV_SoundActuaGen2AU64X.rod
    Address AC: Reductant Control (J880)       Labels: 4G0-907-355.clb
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 152160412
       ASAM Dataset: EV_RDCMA00100 008040
       ROD: EV_RDCMA00100.rod
       VCID: 2F6DA6BB761D45FEBA-807A
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0011
       Serial number: 150904200104
       ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
       ROD: EV_ActuaForExterNoiseUDS.rod
       VCID: 275D4E9B5EED1DBE72-8072
    End-------------------------(Elapsed Time: 06:19)--------------------------
  3. Re: Major electrical issue
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    hello,
    you need to check all fuses in all areas. Check fuses for corrosion on contacts even though they might not be blown. Check ground connections under carpet area along inner sills for corrosion. There are fuses behind the lower a pillar kick panels.
    Looks like you have a connection issue thats causing these faults. Worse case.. it could be a bad joint within the loom due to corrosion.
    Do you have a sunroof?
  4. Re: Major electrical issue
    131 Post(s)
    1973 Post(s)
    Your old out of date (possible clone) interface is letting you down there.
  5. Re: Major electrical issue
    Feb 2020
    Bradford
    40 Post(s)
    Unplug drivers side Control Module for Multi-Contour seat if you can, to see if it is bringing down the network causing the no comms.
  6. Re: Major electrical issue
    131 Post(s)
    1973 Post(s)
    Interesting, based on experience? I have had ABS pumps pull the drivetrain data bus down so that would be the convenience bus.
  7. Re: Major electrical issue
    Feb 2020
    Bradford
    40 Post(s)
    Just a rough guess for a method of elimination progress.
  8. Re: Major electrical issue
    Dec 2023
    France
    Hello,
    Thanks for your answers. I come back 1 year later, sorry for that.
    I have checked the fuses, and I see the issue is coming from the fuse box on driver side. The majority of the fuses are lightly melted... Others fuse boxes are ok.
    Is there an explanation ? I think I need to change the fuse box, but before I would like to understand the heating ?
    Thanks for your help.
  1. Question Major electrical problems - Help please
    By Adrianl in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-09-2015, 12:05 PM
  2. major electrical failure while driving
    By shergill_007 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-01-2010, 12:47 AM
  3. Major Electrical Fault Golf MK4 2003
    By vanrudi in forum Golf MK4 - 1999 - 2004
    Last Post: 16-11-2007, 02:11 PM
  4. Major Electrical Problems!!
    By kriskros in forum Passat - Archive Topics
    Last Post: 15-12-2006, 09:19 PM
  5. Major Electrical Problems - Advice needed?
    By Shaz12 in forum Passat - Archive Topics
    Last Post: 30-11-2006, 12:37 AM
