Thread: Pollen Filter Housing Gasket
  1. Pollen Filter Housing Gasket
    Nov 2023
    Torquay
    I have a problem, (apparently fairly common) of water coming into the drivers side footwell in my Mk4 1.9 TDI, 2003 reg.
    My first stop in trying to cure this problem is checking the pollen filter housing gasket. I did and it’s in a bit of a state, so will need to be replaced. This is where I’ve hit a bit of a brick wall, I can’t seem to find anyone selling replacement gaskets.
    can any forum members help by providing a link or phone number? TIA.
  2. Re: Pollen Filter Housing Gasket
    131 Post(s)
    1974 Post(s)
    Water into the drivers side can’t be the pollen filter gasket which is still listed by VW under part number 1H0 819 165 which means it is the Golf 3 part carried over and costs £9.60 but it is useless at stopping water so we use a none setting Butyl rubber sealing cord and you can get a roll which will last a lifetime from Amazon.
  1. Leak with a twist - it's not the battery drain or pollen filter housing.
    By Riknos in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2017, 09:12 PM
  2. Question Pollen Filter Housing Removal
    By hudsonm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 02:41 PM
  3. Pollen Filter Gasket
    By Brookhammer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-02-2009, 02:17 PM
  4. How to remove pollen filter housing?
    By wilharper2000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-01-2009, 09:05 PM
  5. Pollen Filter housing removal
    By mgarner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2007, 09:30 AM
