Thread: Engine light on dash, P164E00 and P067200 fault codes
  1. Question Engine light on dash, P164E00 and P067200 fault codes
    Sheffield, UK
    Afternoon, typically just 2 weeks out of warranty I've had an engine light appear on the dash. I've driven 15 miles to work this morning with no issues, I didn't even notice the light until about 10 mins in to the journey.
    I had my obdeleven in the car so I plugged it in when I got to work, it's come up with the following.
    Oil Pressure Regulation Valve (electrical error)
    Fault Code: P164E00
    Status: Static
    Cylinder 2 Glow Plug Circuit
    Fault Code: P067200
    Status: Static
    I've cleared the errors and the dashboard light has gone off, I restarted it a couple of times afterwards and it's remained off. I know it's likely to come back on, is it just a case of replacing the glow plugs and the oil pressure regulation valve? Is anyone able to point me in the direction of the correct parts and possibly a guide on how to fix it myself (assuming I can :-)).
    Vehicle Identification Number WVGZZZ5NZHW823949
    Many thanks,
    Nick.
    Volkswagen Tiguan 2.0 TDI SE NAV DSG 4motion 195bhp (Stage 1 remap)
    Sheffield, UK
  2. Re: Engine light on dash, P164E00 and P067200 fault codes
    Sheffield, UK
    I had all the plugs changed rather than just the 1 showing the fault, all good.
    I also had 2 sensors / regulation valves changed (genuine VW parts) but it's still showing the fault, any suggestions on what else to check?
    Fault Code: P164E00
    Status: Static
    Sheffield, UK
  3. Re: Engine light on dash, P164E00 and P067200 fault codes
    2007 Post(s)
    We have seen this a lot and cured the fault by fitting the revised part number valve 04L 906 455 B which costs £132.54 from VW.
  4. Re: Engine light on dash, P164E00 and P067200 fault codes
    Sheffield, UK
    Hi Crasher, thank you as always.
    I was going to see an Auto Electrician after Christmas but might give this a go first.
    Many thanks,
    Nick.
    Sheffield, UK
  1. Engine Management Light On , 6 Fault Codes
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 16-12-2021, 02:38 PM
  2. Engine management light and glow plug light errors/fault codes
    By zhussain087 in forum Golf MK6 - 2009 - 2013
    Last Post: 26-06-2020, 03:32 PM
  3. Fault codes p0322 and p0321 engine idle high, cutting out Eml light and epc light on
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2018, 10:58 AM
  4. Engine Light & Fault Codes
    By Boat_face in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-08-2010, 12:10 AM
  5. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
