Thread: Front Upper Control arms
  1. Front Upper Control arms
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I need to purchase 4 upper front control arms for an A5 coupe 2009 3.0Tdi. Audi want circa £160 each. I would like to get a cheaper aftermarket brand but which ones are good and is there a best place to order them from.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Front Upper Control arms
    134 Post(s)
    2009 Post(s)
    HUGE choice. For me FEBI if I had overnight or off the shelf, TRW, Lemforder, Meyle, Optimal, Dayco, Borg and Beck, Delphi and FAG are all top end. Remember EVERY single nut and bolt is one time only and it is almost guaranteed that you will not be able to remove the top bolt without some deep heat (Oxycet or induction) or even cut the upper arms off and take the upright to a competent engineer who can drill out a 100mm long bolt without damaging the upright. If you apply heat, take great care as the upright is aluminium and the material can change state and crack during reassembly.
  3. Re: Front Upper Control arms
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thank you Crasher. Nice to know that there are so many brands able to produce good quality parts.
  4. Re: Front Upper Control arms
    134 Post(s)
    2009 Post(s)
    There are far more that produce Chinese Replacement Auto Parts
  1. Please Help Front upper control arms
    By Veeb2k in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-10-2021, 07:29 PM
  2. Upper Control Arms - Any Advice?
    By Andydote in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2017, 11:39 PM
  3. Upper Control Arms ?
    By Lewis-Oddie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-05-2014, 02:53 PM
  4. Upper Control Arms - Spacing
    By danoid in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-05-2014, 12:15 PM
  5. upper front control arms
    By DGT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-08-2010, 07:52 PM
