Thread: airbag falty on dashboard
  1. airbag falty on dashboard
    Sep 2023
    Bristol
    Hi
    As part of trying to find door locking problem I took out glove compartment which required to disconnect the airbag cables. At that point I started getting 'airbag faulty' on my dashboard. When put back all the compartment I reconnected the cables back. However, the fault message still remained on the dashboard. So, I decided to use an ODBII adapter and car scanner app to clear airbag error code. However, the message still is coming up but ODBII adapter is not reading any airbag faulty codes no matter how many times I tried to rescan. I am lost.
  2. Re: airbag falty on dashboard
    Feb 2020
    Bradford
    40 Post(s)
    OBDll deals with the emissions, it was a legal requirement for the manufacturers to make this accessible with standard protocol. For other electrical functions each manufacturer generally has their own protocols for communication. You'll need a different tool, one able to access vw specific modules, to clear the fault.
  3. Re: airbag falty on dashboard
    131 Post(s)
    1973 Post(s)
    You need something like VCDS, not a toy code reader.
  1. Replies: 0
    Last Post: 15-01-2018, 10:49 PM
  2. Please Help Battery Replaced, Now Airbag and Traction Control Light On Dashboard
    By chesterman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2017, 12:19 AM
  3. Replies: 1
    Last Post: 17-06-2014, 02:54 PM
  4. Airbag Fault after trying to switch back on Passenger Airbag
    By platty25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-08-2011, 10:47 AM
  5. Seats - Airbag sensor (Subframe with Airbag Resistor)
    By greg_gorr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2008, 08:43 AM
