Thread: Fan belt wont loosen enough. 2.0tdi
  1. Fan belt wont loosen enough. 2.0tdi
    Sep 2022
    corby
    My BRE 2.0tdi Fan belt wont loosen enough to remove it.
    I have tried the 14mm bolt on the tensioner, which moves some way, to a stop, but the serpentine belt is still too tight to remove.
    I have removed/replaced it before, so I know it should become looser
    Is there something else I have missed, or could try, other than brute force?
  2. Re: Fan belt wont loosen enough. 2.0tdi
    Oct 2012
    Ireland
    Cut it off
    Has the tensioner failed or something and is restricting it's full movement or does it look to be in the correct range of movement?
    Is it much off, maybe try turning a pulley with the belt and try to work it off? Or remove an idler pulley first and then the belt.
  3. Re: Fan belt wont loosen enough. 2.0tdi
    Sep 2022
    corby
    it feels right, not far off.Tensioner is free, but still i cant take it off
  1. 3.0tdi quattro wont start
    By bluecamp30908 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-05-2018, 09:45 AM
  2. Seized rear wiper... how to loosen?
    By Grubscrew in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-08-2013, 06:40 PM
  3. Please Help 2.0TDI - wont start
    By brummieboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-06-2013, 10:21 PM
  4. How hard should it be to loosen glow plugs
    By exup in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 28-08-2012, 08:37 PM
  5. oil filter housing loosen tool
    By AAGT150 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2009, 08:32 PM
