Thread: 2.0 Turbo replacement CRLB
Results 1 to 8 of 8
  1. 2.0 Turbo replacement CRLB
    Aug 2012
    merseyside
    Hi all
    I am after some advice on easiest/best way to remove the turbo and refit a new one please on a CRLB 2.0 engine. I have the use of a ramp if its easier.
    Thanks in advance
  2. Re: 2.0 Turbo replacement CRLB
    131 Post(s)
    1976 Post(s)
    You nearly always have to remove the right driveshaft. Disconnect the DPF to silencer sleeve, have a new sleeve ready for reassembly. Disconnect the DPF from the turbo, move it to the right. Most work is done from below, all the fasters are hard to get at, some more than others. At least it is easier than the T5 twin turbo we did today.
  3. Re: 2.0 Turbo replacement CRLB
    Aug 2012
    merseyside
    Thank you for the reply, I will try and order a new sleeve today, I believe there might possibly be a few different diameters though......... Hopefully not lol.
  4. Re: 2.0 Turbo replacement CRLB
    Aug 2012
    merseyside
    Crasher could I ask if you know which the part number is for the sleeve, and any other clamps you think I would need please.
    I found this on another post on here..
    04L 253 725 B turbo to cat clamp 1pcs
    04L 253 115 A turbo to cat seal 1pcs
    1K0 253 725 dpf to downpipe clamp 1pcs
    1K0 253 115 AE dpf to downpipe seal 1pcs
    04L 131 455 A EGR cooler To DPF clamp 1pcs
    04L 131 547 EGR Cooler to DPF seal 1pcs
    1k0 253 141 S exhaust clamp 55x88 1pcs
    Thanks again for your advice
  5. Re: 2.0 Turbo replacement CRLB
    131 Post(s)
    1976 Post(s)
    What is the VIN?
  6. Re: 2.0 Turbo replacement CRLB
    Aug 2012
    merseyside
    What is the VIN?
    WVWZZZ3CZFE484113 I'm changing the turbo and manifold as a block so would probably need the gasket for this also if you could help with that part number too please. Many thanks
  7. Re: 2.0 Turbo replacement CRLB
    131 Post(s)
    1976 Post(s)
    Manifold gasket 04L 253 039 B
    Nut x 10 N 908 946 01
    Ring x 2 N 013 813 3
    Ring WHT 007 702
    Seal 04B 145 757
    Clamp 04L 253 725 B
    Seal 04L 253 115 A
    Dual clip (sleeve) 1K0 253 141 S
  8. Re: 2.0 Turbo replacement CRLB
    Aug 2012
    merseyside
    Ring WHT 007 702
    Seal 04B 145 757
    Clamp 04L 253 725 B
    Seal 04L 253 115 A
    Crasher, wow, and thank you for all the advice and help with getting the part numbers.
  1. Question Ea288 2.0tdi crlb dpf system non adblue
    By N871BUD in forum 2.0TDi - Engine
    Last Post: 15-12-2023, 05:22 PM
  2. Question 1.9 BLS Turbo Replacement
    By stefan7n in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-09-2018, 06:18 AM
  3. turbo replacement
    By ladya3 in forum Site Sponsors - Request A Deal
    Last Post: 16-08-2013, 08:19 PM
  4. Question Turbo replacement
    By mage in forum A8 - S8 - V8
    Last Post: 06-04-2012, 02:58 PM
  5. Question 2.0 Tdi BKD Turbo Replacement
    By gib786 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-08-2010, 01:59 PM
