Thread: Stiff gas pedal or cable or carb? want to swap pls Help with what?
  1. Question Stiff gas pedal or cable or carb? want to swap pls Help with what?
    Nov 2023
    Gresham, USA
    Hi guys,
    So I have this project car that I have had for a long time and parts are sometimes difficult to get, as you know. I have tried to figure out the stiff pedal and now I am wondering if I can swap some of the problem parts out with any newer years that the car will recognize the new parts or they can be programed to be recognize? (oh and I have tried to lube the cable and I have replaced the pedal) any help would be much loved!!
    Does anyone know if another year cable can be switched?
    Or is there a newer year carb I can swap out? (maybe it will have more adjustment)
    Background, I have rebuilt the top end of this car, heads, valve job, water pump, steering rack and pinion, coil, plugs, water pump, thermostat, timing belt, cam bearings, main camshaft seal, plug wires, starter, torque converter, all vac lines, fuel pump, rebuilt the door lock pump, battery, O2 sensors, oil pump, brake system main computer, transmission module thing and plug (that was not fun), brakes, tires, headliner, I think thats about it...
    Car is a 1996 Audi A4 Quattro (B5)
    Oh and I do not understand why there is no mechanical attachment from the plastic intake in the back where it hooks to the carb, just a rubber gasket.....
  2. Re: Stiff gas pedal or cable or carb? want to swap pls Help with what?
    134 Post(s)
    2019 Post(s)
    Which engine type code?
  3. Re: Stiff gas pedal or cable or carb? want to swap pls Help with what?
    Nov 2023
    Gresham, USA
    Engine is the 2.8L V6 automatic
  1. Please Help heavy/stiff clutch pedal
    By essayeff in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2010, 09:36 PM
  2. Stiff clutch pedal
    By RDL001 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2009, 06:39 PM
  3. Please Help Stiff Accelerator pedal
    By westy123 in forum Golf MK2 - 1984 - 1992
    Last Post: 03-01-2009, 08:09 PM
  4. injection to carb swap mk2/3
    By rusthater in forum Golf MK3 - 1993 - 1999
    Last Post: 23-12-2007, 03:36 PM
  5. Stiff brake pedal in '99 A4 Avant
    By Phil101 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2007, 07:21 PM
