Thread: Tailgate wiring plug
  1. Tailgate wiring plug
    Sep 2009
    Lincoln, England
    6 Post(s)
    I need to change the tailgate rubber gaiter on the offside. When the cars are made, would it be reasonable to assume the tailgates are pre wired then fitted to the car? If that's the case how far in the car is the connection point? I can't seem to get any pictures via Google or any search results
    Darren
  2. Re: Tailgate wiring plug
    131 Post(s)
    1976 Post(s)
    The grommet as VW call it and conduit as I call it is part number 5G6 971 829 B and £15.18 but the left is a PITA to change as the harness is inserted through it before the plugs are fitted so you have to de-pin the 8 pin black plug inside the C pillar (or more on certain versions) and then re-pin after fitting the new conduit so we only do it by fitting a new harness section, is this left or right and what is the VIN?
  3. Re: Tailgate wiring plug
    Sep 2009
    Lincoln, England
    6 Post(s)
    I have the part. It is the driver's side that has broken. I don't mind unpicking the plug if that's what's required. I'll pm you the vin
    Darren
  4. Re: Tailgate wiring plug
    131 Post(s)
    1976 Post(s)
    I think that is just the washer tube, can’t see from home.
  5. Re: Tailgate wiring plug
    Sep 2009
    Lincoln, England
    6 Post(s)
    I'll investigate tomorrow. We have the prospect of dry weather, so I'll have a good look around
  1. Please Help Tailgate switch wiring
    By LightTrees in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-12-2021, 07:17 PM
  2. C6 Avant Tailgate wiring loom broken?
    By petrolhead63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-08-2016, 10:58 PM
  3. Wiring Tailgate latch microswitch
    By spike47 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2012, 08:20 PM
  4. Question Audi 80 Avant Tailgate hinge wiring ???
    By Timk in forum 80 - 90
    Last Post: 07-05-2012, 10:07 AM
  5. Tailgate Wiring Diagram A6 Avant 1.9TDi
    By EricDude in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-08-2010, 03:03 PM
