Thread: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
  1. A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    I had a 1.6 CAYB A3 towed in last week non runner, plugged in VCDS no faults except a gear change selector sensor, i tried to start it and it indeed would not start, however on the 3rd attempt it fired into life but wouldnt rev and would stall, it restarted though, i have not had any 1.6 CR TDi’s in previously and hear there a pig for injectors so i checked the deviation, number 2 injector was way out -1.5 deviation number 1 was 0.2-0.3 as is number 3 and number 4 was 0.5-0.7
    so i purchased a new injector from Diesel Bob £375 delivered, fitted it yesterday and coded it, now number 2 is -2.5 deviation and number 4 is also pretty much the same, looking on google it suggests there is an injector deviation adaption in basic settings but this didnt work, and others are saying it isnt for CAYB engines, so anyone else had this issue? There is a bit of diesel knock when you blip the throttle, i also read there was something in ODIS but i couldnt find anything in ODIS Service.
    If anyone is able to assist, or do i need to replace number 4 too?
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Feb 2020
    Bradford
    40 Post(s)
    On the 1.6tdi cayc the high pressure fuel pump can fail if run dry. Worth checking for swarf in the fuel filter housing. If I remember correctly from a few years back the vehicle starts at around 4200psi and then settles back to around 3300psi fuel pressure at idle
    Also new injector sealing copper washers as well as new clamping bolts for refitting are essential
  3. Re: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Dec 2007
    44 Post(s)
    Hi, yes the owner confirmed it has not run out of fuel and there was half a tank on delivery to me.
    I fitted a new filter before the injector was swapped no sign of swarf,
    I always fit a new stretch bolt and the new injectors come with new copper washer n seal.
    The injector seats were also spotless before refitting.
  4. Re: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Feb 2020
    Bradford
    40 Post(s)
    I follow CAY issues quiet closely. The vcds adaption feature is prone to not working right. I don't know if vcds completed its adaption for you or not. In the case of it didn't operate properly, which is quiet common, this tech has a great guide on how to make it work
    VW 1.6TDI Injector Quantity Adaptation IDE06141 CAYC engine - YouTube
  5. Re: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Dec 2007
    44 Post(s)
    Thats what it is now, number 2 is new
  6. Re: A3 CAYB Injector swap has increased the Injection deviation on 2 cylinders
    Dec 2007
    44 Post(s)
    Quote Originally Posted by Roverfan View Post
    Yeah thats what i watched last night, a lot of comments say that doesn’t work on CAYB.
  1. Injector Deviation Readings - 1.6 TDi CAYC
    By Overdose in forum Fabia
    Last Post: 23-03-2023, 01:53 PM
  2. Question A6 Allroad Injection pump swap
    By Ross Cottey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-08-2016, 11:00 PM
  3. 17656 injection start regulation control deviation
    By abenga in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 15-05-2009, 01:07 PM
  4. 17656 injection start regulation control deviation
    Last Post: 07-05-2009, 01:41 PM
  5. injection to carb swap mk2/3
    By rusthater in forum Golf MK3 - 1993 - 1999
    Last Post: 23-12-2007, 03:36 PM
