Thread: B6 Passat 09g to manual swap
  1. B6 Passat 09g to manual swap
    Oct 2023
    Canada
    I just wrecked the front end of my 2006 2.0t fsi FWD Passat and it looks like I can rebuild it.
    Always wanted to do a manual and now I have a donor car to rebuild my car with, and the donor car just happens to be a manual, so it seems to me that stars are aligning,
    I plan on starting this weekend…
    Does anyone have ANY info on this? Is it possible? Will I need to do ECU/TCM or other computer work?
    Will any holes need to be cut or is structurallly everything ready to swap over?
    Will I need any parts my donor car doesent have? Is it as simple as moving it all over? The donor is a 2010 manual 2.0t anyone know what the name/code of the tranny is in a 2010 manual?
    Thank you! ALL help is v much appreciated as I wanna tackle this right away and anywhere you can point me as well!
  2. Re: B6 Passat 09g to manual swap
    134 Post(s)
    2024 Post(s)
    Yes you can do it but it will be a huge job. As for the ECU, I would stick with the original and change the coding to manual.
  3. Re: B6 Passat 09g to manual swap
    Oct 2023
    Canada
    So what makes you say it would be a huge job? If I have all the parts on my donor shouldn’t it be as easy as taking them all off and moving them over?
    I’ve removed my 09G tranny 4-5 times before, so i am familiar with that, and I figure mounting and dismounting it is the hardest part, since it should all bolt up? And I know someone who can help me code the manual transmission into the car with VCDS which I am pretty good with already, so I feel like I should be good the .
    We’re you thinking there would be even more than that that is alarming?
    Like I think with two people I can do it this weekend it sounds like…
  1. Auto swap to manual
    By philmax in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-01-2012, 06:13 PM
  2. Please Help Passat Headlight swap, is it posible to swap early / late over?
    By scotlandstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 11:26 AM
  3. Passat seat swap
    By D_I_A_B_L_O in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2009, 03:33 PM
  4. Passat Tdi130 Sport Swap Manual For Auto?
    By TDIPD130 in forum Passat - Archive Topics
    Last Post: 28-04-2007, 07:04 PM
  5. Passat td head swap?
    By cj1978 in forum Chat - Completely Off Topic
    Last Post: 20-01-2007, 04:34 PM
