Thread: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
  1. Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2023
    South wales
    I was driving on the motorway today and all of a sudden the power wasn’t there to accelerate quickly, possibly from the turbo? Not sure. It still builds up speed but lacking the initial power. No white smoke, no whistling from the turbo. Engine still revs to over 4000rpm. Any suggestions would be appreciated.
  2. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2018
    York
    9 Post(s)
    Quote Originally Posted by Kevjon View Post
    Any symptoms of clutch slip?
    Check the colour of the diesel in the fuel filter: if it's black, it may be contaminated with oil, indicating that the gasket on the tandem pump has failed.
  3. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2023
    South wales
    Thank you for your response, No clutch slip, neither any mix in the filter. I have put an OBD II scanner on and it’s come up with a few fault codes: 16618 turbo/supercharger overboost condition, 19557 intake flap motor open circuit/short circuit to ground, 19558 intake flap Moyer no signal, 17056/7/8 cylinder 2,3 and 4 flow plug circuit. 16955 cruise/break switch (a) circ malfunction. So now I don’t know where to start first. Any advice would be appreciated. Thank you
  4. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Feb 2020
    Bradford
    41 Post(s)
    Overboost fault code would suggest turbo is stuck/gummed up but if it doesn't have control of the intake valve that restriction in flow could also cause overboost! I think if the overboost fault is always present with the intake valve fault I would be inclined towards treating the valve first
  5. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2023
    South wales
    Thanks you for your advice, I will look at the intake flap and fuses. Hopefully will have some joy.I did drive it earlier, and there was no power loss but the fault codes did appear.
  6. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    135 Post(s)
    2033 Post(s)
    With a BKD engine overboost in nearly always a carbon fouled up boost control system, standard job, turbo off and rebuilt and circa £1k including oil and filter.
  7. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2012
    Ireland
    " 19557 intake flap motor open circuit/short circuit to ground, 19558 intake flap Moyer no signal,"
    Are these couple of fault codes above relating to a wiring issue?
  8. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    Oct 2018
    York
    9 Post(s)
    Quote Originally Posted by tdiblacky View Post
    Could be burnt out motor for the flap
  9. Re: Mk 5 Golf 2006 GT TDI 140 turbo? Power issues? Any help
    135 Post(s)
    2033 Post(s)
    Failure of the V157 in the closed position means the engine cannot run, failure in the open position reduces the ability of the ECU to control EGR flow, makes the engine shudder on shut down and leaves the engine unable to be shut down in the event of runaway.
  1. 2006 Audi A6 2.7TDI Turbo Issues
    By chilledgibbo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-09-2018, 07:06 PM
  2. Please Help Audi A4 B6 1.9TDI Turbo/Power Issues (NEED YOU HELP!)
    By SDavies246 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-02-2016, 10:50 PM
  3. 2006 golf gt tdi dpf issues and warning lights please help!
    By golf170dpf in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2013, 12:15 AM
  4. Question 2006 audi A3 2.0 tdi sport power issues (Help)
    By CHAMBO25 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2011, 09:24 AM
  5. Please Help 2006 - 140 Sport Estate Turbo issues
    By housley1979 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2010, 03:53 PM
