Thread: Battery Adaptation
  1. Battery Adaptation
    May 2017
    Dublin
    I have an Audi A6 C6 2.0 TDI 2010 facelift without start-stop function. I will try to be direct and clear.
    Q1 - Do I need an AGM battery OR the regular lead acid would be fine?
    Q2 - Can I code a random battery BEM (but valid) and things would be fine? I only need to provide the BEM code for adaptation. My battery module does not ask about Ah or volts or maker etc. I am planing to put in a new 95Ah 850 CCA lead acid battery. The car currently has 92Ah with 850 CCA
    Thanks!
  2. Re: Battery Adaptation
    May 2017
    Dublin
    Bump
  1. Dpf adaptation Middlesbrough
    By nathanmac90 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 16-09-2019, 07:29 PM
  2. Please Help Trouble code 00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    By FrenchAudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-04-2018, 12:43 PM
  3. 2.0 ALT PCV adaptation
    By Firkin L in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-04-2013, 05:55 PM
  4. Quick Adaptation - anyone Please?
    By HalD in forum VCDS - Help Requests
    Last Post: 12-09-2012, 06:21 PM
  5. A6 Tiptronic adaptation?
    By eestimaa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-05-2011, 09:09 AM
