Re: Audi A6 / C6 - 2007 Avant - 2.0 TDI - BRE Engine - Turbo failure? –
19-10-2023,02:49 PM
Originally Posted by
rjsdavis
Hello to all
I've got a problem with my car. It's presently smoking (a bit, and enough so that it should have failed it's MOT), but in the last few days has developed an additional problem in that it appears to go into "limp home" mode when attempting to reach and cruise at motorway speed (circa 70mph) when the engine is not fully upto working temperature.
About five weeks ago, I had the dreaded oil pressure warning light come on. I had thought that I had been lucky, in that it occurred within a couple of minutes of leaving my house, so I gently drove her back and back to my home, parking up - never starting her again. My local specialists thought it was likely that the hex drive on the pump had rounded off and we were hopeful that this was all that was going to be required. It was. New shaft in. Car seemed to driving perfectly again.
It was MOT'd a couple of days later, and it should have failed. I've experienced the smoke ever since, and have been pouring in injector cleaner and emissions reducer to help reduce the smoking. It hasn't really worked, and might (I guess?) have ended up exacerbating the situation?
Anywho... I've been thinking about this, and the only logical conclusion that I can come up with, is that the very short drive home with the oil pressure problem has managed to damage the turbo, which would explain the smoking, and also the power failure/limp mode issue whilst the engine is working upto temperature?
I live relatively near a dual carriageway, and what I'm finding is that when I leave my village, get straight onto the dual carriageway, the engine temp is only about half-way to the 1/4 mark on the gauge. It goes into limp mode where it will struggle to crawl along at 50mph, so I come off the next junction, pull up, stop, fully reset the car and start off again. The engine has had time to get to working temp by the time I get off at the next junction, so that after the car reset, it then drives perfectly for the rest of the day (albeit with some smoking!).
I just wanted to check my logic before I track down a new turbo, have it fitted and go to the expense of it all... my local specialists also thought it was the turbo, but I just wanted to be belt and braces about it!
Many thanks for any replies...
Are there any codes stored, and does the EML light come on when the car goes into "limp mode", or is it just lots of smoke and loss of power with no other symptoms?
The reason I ask is that my old A6 with BRE engine had a similar issue - no EML and no codes. It turned out to be a broken EGR valve. Something to check, maybe, before you spend lots on a new turbo?
Cheers!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
