Thread: Heavy fuel consumption Golf GTI Mk4 1.8T
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #21
    Nope - don't think I can do private messages. I'd really appreciate your feedback anyway, before I go back to the place I've been taking it to before.
    Anytime on Saturday is fine - do you want to send me address info?
  2. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #22
    Just to confirm what the others have said re fuel economy. I have had 5 Turbos and all did 25 odd in town and 35 odd on motorway. Less if a drove them fast.
    Only time it was bad was when a lambda probe went but your engine managemnet light should come on if that happens.
  3. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #23
    Thanks for your feedback Nick - I'm beginning to feel like my Golf used to be hydro-power or something! I swear that when I got it in May I was getting 37/38 mpg when doing 80/85 on the motorway and no less than 30/32 around town? Maybe I'm imagining things - however its giving a fault code still? very confusing and frustrating.
  4. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #24
    Hi guys,
    Im also havin Very Low fuel consumption, 18-23mpg around town. its due a service which is booked in for 18th dec but been told the it wont make too much diff but a little none the less. I only got the car two weeks ago but its been mentioned abt the cat convertor might need replacing, will this make any diff??
    Thanks in advance
    ps my car is a gti 2.0 115 bhp.
  5. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #25
    131 Post(s)
    1979 Post(s)
    Cats on the 2.0L only fail due to other common problems on that engine such as air leaks, AMM, leads, plugs, coil pack and lambda sensor.
  6. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #26
    Crasher, I've done this not - had the diverter value replaced with a VAG one as per the code you gave me but theres still no improvement, I did ask them to clean the throttle body as you said but looking at what they charged me £50 inc VAT) I dare say they didn't.
    Any more ideas? - still the same problem, heavy on fuel and just a bit lacking on power. Also, can I just ask, at what RPM in the turbo supposed to start? I'm sure i can hear/feel mine at around 1500 rpm?
  7. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #27
    131 Post(s)
    1979 Post(s)
    OK, let’s start at the beginning as this thread is jumping around a bit. What year and engine code and are there any fault codes stored? Has it been re-mapped? £50 is a little cheap for a throttle body clean and reset but only by a few pounds.
  8. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #28
    Its a 51 plate 1.8T Standard 150bhp - engine code is AUM. It was coming up with a fault code of "P1200 - Exhaust supercharger air circulation valve" - which you said sounded like either the throttle body or the diverter valve. I've changed the diverter valve - I gave them the code for that (06A 145 710 A) which you gave me and told them to clean the throttle body but like I said - £50 inc VAT for a new diverter valve fitted and a throttle body clean is too cheap isn't it?
    Whats your take on the Turbo kick in question? I'm sure it starts at 1500rpm - is that right? I thought it should be 2000rpm when the turbo starts?
    Thanks for your help by the way
  9. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #29
    131 Post(s)
    1979 Post(s)
    OK, £50 all in is way too cheap, I charge £60 to remove and clean the TB with a reset after, never mind the valve at £25 plus clips and fitting. I messed up the part number for the valve it should be 06A 145 710 N but as 06A 145 710 A doesn’t exit, I imagine they fitted the right part. The turbo starting to spool up at 1500rpm sounds rather low and leads me to suspect a device known as the N75 valve which may be jammed closed and this would lead to over boost. Mine jammed open and under boosted. I feel that the TB will still need to be removed, cleaned and reset; I bet they didn’t appreciate how important the cleaning procedure is and just gave it a quick wipe out whilst still fitted and probably didn’t re-adapt it. Have you a decent VW specialist near you? If not, you may have to take it to VW for this.
  10. Re: Heavy fuel consumption Golf GTI Mk4 1.8T
    #30
    Right, well i thought I had a good independent specialist near me (they've worked on a few of my friends Golfs/A3's but after spending £150 in diagnostics and £160 changing the Air Temp Sensor and AMM I'm starting to think that they're not as clue up as I thought. The Diverter Value and supposed clean of the TB was just done by a local guy who I know through my Dad, so that leads me to think he just wiped it as you said. Another question, sorry! Once he'd fitted the new Diverter Value - did he need to reset/readapt anything or is it just a case of stick it on and away you go?
  1. golf mk gti turbo fuel consumption question
    By jimmyb323 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2007, 07:14 PM
  2. Golf Mk4 150 TDi fuel consumption
    By Karlos_Fandango in forum Chat - Anything with wheels
    Last Post: 27-08-2007, 02:15 AM
  3. 98' golf gti turbo excessive fuel consumption
    By Sandz in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-05-2007, 09:34 AM
  4. Fuel consumption- Golf GTTDi PDI
    By MoVW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-03-2007, 12:03 AM
  5. Engine oil / heavy fuel consumption
    By Brianm in forum Passat - Archive Topics
    Last Post: 04-12-2006, 10:45 AM
