Thread: Audi Q7 2017 Trailer Assist fault
  1. Audi Q7 2017 Trailer Assist fault
    Mar 2007
    Devon
    When I try to use trailer assist it says 'Trailer Assist is currently unavailable'. I've run a scan and got this code but can't find anything online or these codes on the Ross Tech Wiki. Can anyone give me any advice? It would be really appreciated.
    Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
    Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
    Component: Anhaenger H20 0216
    Revision: 9A001003 Serial number: 0445005759 Dataset Number: 4M0909527B 0020
    Coding: 0110000202010000
    Shop #: WSC 10756 002 1048576
    ASAM Dataset: EV_TrailFunctGener2Hella 001008
    ROD: EV_TrailFunctGener2Hella_VW26.rod
    VCID: 333874A93BC87A32C29-8166
    1 Fault Found:
    428804 - Pitch Angle Sensor
    U115A 00 [009] - No Communications
    [Pivot angle sensor - no signal/communication]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 137221 km
    Date: 2023.09.01
    Time: 15:41:16
  2. Re: Audi Q7 2017 Trailer Assist fault
    134 Post(s)
    2018 Post(s)
    Please post a full car VCDS scan and include the VIN.
  3. Re: Audi Q7 2017 Trailer Assist fault
    Mar 2007
    Devon
    Thanks, here it is:
    Code:
    Tuesday,10,October,2023,20:41:37:53546
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
    VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
    Data version: 20230421 DS346.2
    Ross-Tech: Home
    VIN: WAUZZZ4M9JD001573   License Plate:
    Chassis Type: 4M-AU73 (8W5)
    Scan: 01 02 03 06 08 09 15 16 17 19 28 29 2B 36 39 42 44 46 50 52
              5F 69 6D 81 82 A5 AC BB BC D6 D7
    VIN: WAUZZZ4M9JD001573   Mileage: 140755km-87461miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    29-Left Light -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    39-Right Light -- Status: OK 0000
    50-Seat Adj. 3rd row -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    69-Trailer -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: OK 0000
    81-Gear Shift -- Status: OK 0000
    82-Head Up Display -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    AC-Reductant Control -- Status: OK 0000
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3.0TDI EDC17  X46 0009
       Revision: 91X46---    CVN: 67AC37D885D7D21E755A2113
       Coding: 2A2A40320336050335080000000000000000000000000000
       Shop #: WSC 06894 002 1048576
       ASAM Dataset: EV_ECM30TDI0114M0907401 001013
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 669EDDFD389ADF9A957-8132
       VINID: 9D196AAAA11D25A5000011470C312D9890
    1 Fault Found:
    17324 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [032] - -
              Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H05 1016
       Revision: --H05---    CVN: D4683A9B
       Coding: 100000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011_AU49.rod
       VCID: 3B285C891398B2721A9-816E
    1 Fault Found:
    27485 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
       Component: ESP9 Premium  H09 0657
       Dataset Number: 4M0909504M  0003 CVN: ACFBEF4F
       Coding: 249830B230A20A97D1A358980080529AE6A6D2240C0C508B1A004A5967654B
       ASAM Dataset: EV_ESP9BOSCHAU536K 012013
       ROD: EV_ESP9BOSCHAU536K.rod
       VCID: 45DC3A71655CF4827CD-8110
    4 Faults Found:
    420096 - TPMS Warning; Rear Left Tire
              C1058 00 [040] - Pressure too Low
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 138111 km
                        Date: 2023.09.20
                        Time: 06:39:33
                        93 00 80 3D 88 24 00 00 40 70
    419584 - TPMS Warning; Rear Left Tire
              C1059 00 [040] - Flat
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 4
                        Mileage: 137381 km
                        Date: 2023.09.04
                        Time: 06:35:55
                        84 00 80 29 89 24 00 00 40 60
    325376 - Databus
              U1123 00 [032] - Received Error Message
              [Signal_ESP_Off_Taster_error_(3)]
    343808 - Databus
              [Signal_HDC_Taster_error_(3)]
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
       Component: MEM-BFS       008 0031
       Serial number: 00000258129122 Dataset Number: 4M0909866C  0016
       Coding: 003010000000B0410000010101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
    No fault code found.
    Address 08: Auto HVAC (E87)       Labels:* None
       Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
       Component: Klima Zone 4  H52 0093
       Coding: 6618003D5544451102220280800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 6780D0F93F90C692AE1-8132
       Fresh air blower control module (front):
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J216 FLuftV  H08 0003
       Serial number: 00000000000001544048
       Humidity sensor: exterior:
       Subsystem 2 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 8EE05CA880PAG0MUFU02
    Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Dataset Number: 4M0909514S  0053
       Coding: 07501943E17900CD050D57185BBF80F9130331009000000000000000A0001A810A450122125601
       ASAM Dataset: EV_BCM1BOSCHAU736 018006
       ROD: EV_BCM1BOSCHAU736_018_AU49.rod
       VCID: 0256E16D34F203BA19F-8156
       Wiper motor control module:
       Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 170315  044 0893
       Serial number: 90125300401707400109
       Coding: 1BC7F7
       Rain/Light Recognition Sensor:
       Subsystem 2 - Part No SW: 81A 955 547 A    HW: 81A 955 547
       Component: G397_RLFS  H06 0002
       Serial number: 20261095X81A955547A0
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
       Component: E1 - LDS  H06 0008
       Serial number: 21 04 2017  00915095
       Automatic dimming interior mirror:
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Component: Y7_Innenspieg  H09 0002
       Serial number: GX1CE117021723611150
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 CB    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00289699
       Control head for driving and comfort functions:
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
       Component: Airbag10.44   H01 0106
       Serial number: 003UL000XLAW Dataset Number: 4M0909602AH 0003
       Coding: AACCF0D80C80000058F650F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006015
       ROD: EV_AirbaAU10BPAAU736_006.rod
       VCID: 3D2C52910D8CBC4224D-8168
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: -----------    HW: 442 062 604 17
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00AB234EB21C4CD
       Coding: 2D2D2D
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 2 - Part No SW: -----------    HW: 442 062 604 17
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00B1207AB44F40/
       Coding: 2D2D2D
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 3 - Part No SW: -----------    HW: 442 0B0 505 17
       Component: SideSensor_Dr  1C7 0148
       Serial number: 3517700AF25FB8D5B24
       Coding: 2D2D2D
       Passenger side rear thorax airbag crash sensor:
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 605 17
       Component: SideSensor_Pr  1C7 0148
       Serial number: 35277009F25FB8D4E35%
       Coding: 2D2D2D
       Crash sensor for front airbag: driver side:
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 705 17
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500B125FB8D4621I
       Coding: 2D2D2D
       Crash sensor for front airbag: front passenger side:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 705 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 35675009D25FB8F6D2EA
       Coding: 2D2D2D
       Center pedestrian protection crash sensor:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 305 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A32225F5062C
       Coding: 2D2D2D
       Driver's side crash data pedestrian protection 2:
       Subsystem 8 - Part No SW: -----------    HW: 442 421 904 17
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00B72246102042X
       Coding: 2D2D2D
       Passenger's side crash data pedestrian protection 2:
       Subsystem 9 - Part No SW: -----------    HW: 442 421 904 17
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00B52246102503Y
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels: 4M0-907-129.clb
       Part No SW: 4M0 907 129 HD    HW: 4M0 907 129 HD
       Component: Lenks.Modul   H11 0009
       ASAM Dataset: EV_SMLSKLOAU736 006008
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 79A4868159244062485-812C
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790 C    HW: 4M0 920 790 C
       Component: FBenRDW       H18 0370
       Coding: 25A400D0288006000123E9603000200000000000
       ASAM Dataset: EV_DashBoardAU736 001027
       ROD: EV_DashBoardAU736_AU73.rod
       VCID: 2F3078D9D7E05ED2A61-817A
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 8W5 907 468 E    HW: 8W5 907 468 E
       Component: Gateway       H42 0116
       Revision: 6A010002    Serial number: 0286A308217522 Dataset Number: 4M0909515L  0080
       Coding: 03010001000086407F07000000590032C81A0007100000000175078E10000000
       GVL: 01503C0C08040200C0BC08000000C80000082000000000000000000000000000
       ASAM Dataset: EV_CGateCONTIAU491 003092
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       VCID: 4BC80C49434802F2AA9-801E
       Multifunction steering wheel control module:
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20170518055014 00690
       Battery Monitoring Control Module:
       Subsystem 2 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Component: J367-BDMHella  H10 9070
       Serial number: 7784014004
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
       Component: Klima Zone 2  H52 0092
       Coding: 000000000000040100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
       VCID: 353C4AB135BC6402ECD-8160
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0024
       ASAM Dataset: EV_LCMLeftHELLAAU736 001012
       ROD: EV_LCMLeftHELLAAU736_VW48.rod
       VCID: 77A080B96F3056123E1-8122
    Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 17000073842002
       Coding: 8800000000000000
       ASAM Dataset: EV_ELVMarquMQBB 001007
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 323671ADC4D2733AC9F-8166
    Address 36: Seat Mem. Drvr (J136)       Labels:* None
       Component: MEM-FS        008 0031
       Serial number: 00000258126102 Dataset Number: 4M0909856C  0018
       Coding: 002010000000B0410000010101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       ASAM Dataset: EV_LCMRightHELLAAU736 001012
    Address 42: Door Elect, Driver (J386)       Labels:* None
       Part No SW: 4M0 959 593 H    HW: 4M0 959 593 F
       Component: TSG FS        005 0125
       Serial number: 0000258370528  Dataset Number: 4M0909872G  0031
       Coding: 001D9A005001000000003082
       ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
       ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
       VCID: 41D42E617174D8A2405-8114
    Address 44: Steering Assist (J500)       Labels:* None
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000843721 Dataset Number: 4M0909852P  0002
       Coding: 90040001000100
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 343A77B53EC67D0ADB3-8160
    Address 46: Central Conv. (J393)       Labels:* None
       Part No SW: 8W0 907 064 DD    HW: 8W0 907 064 DD
       Component: BCM2 MLBevo   019 0366
       Dataset Number: 4M0909501H  0064
       Coding: 01351E002FB100406309A0000600580203020000804306502F04000000040030001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 013013
       ROD: EV_BCM2HellaAU736_013_AU49.rod
       VCID: 0154EE6131F418A2005-8154
       Anti-theft alarm system sensor:
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0316
       Serial number: 000000000ZY1711420RT
       Alarm horn:
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Component: Sirene, DWA  005 0314
       Serial number: 00000000000069530261
    3 Faults Found:
    65634 - Control Circuit for Tank Locking Flap
              B1482 01 [008] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 164
                        Mileage: 138356 km
                        Date: 2023.09.22
                        Time: 10:07:41
                        Supply voltages-Terminal 30 power supply: 12.691 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.718 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.663 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0  C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0  C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        zv_engine_lwr_rear_wiper_freeze_frame: 11110000 00100111 00000000 00000000
    65636 - Control Circuit for Fuel Tank Flap
              B1263 01 [008] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 164
                        Mileage: 137490 km
                        Date: 2023.09.04
                        Time: 08:07:17
                        Supply voltages-Terminal 30 power supply: 12.609 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.636 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.582 V
    65907 - Alarm Horn / Siren for Anti-Theft System
              B131D 29 [008] - Signal Implausible
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 138
                        Mileage: 139180 km
                        Date: 2023.09.30
                        Time: 18:23:01
                        Supply voltages-Terminal 30 power supply: 12.555 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.582 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.528 V
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
       Component: MEM-SR3       008 0016
       Serial number: 00000258662141 Dataset Number: 4M0909467C  0015
       Coding: FF201020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
    Address 52: Door Elect, Pass. (J387)       Labels:* None
       Part No SW: 4M0 959 592 H    HW: 4M0 959 592 F
       Component: TSG BFS       005 0125
       Serial number: 0000258436855  Dataset Number: 4M0909873G  0031
       Coding: 001D9A005C01000000003080
       ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
       ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
       VCID: 40D22B657A7ED1AA4FB-8114
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M1 035 035 A    HW: 4M1 035 035
       Component: MU-P-LND-EU   034 1117
       Serial number: A641E0HB013958 Dataset Number: 4M0909545K  0042
       Coding: 01370601FF0A000053111101000A00332F001BE701700100DE
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 231884E98B28EAB2329-8176
       Data carrier:
       Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
       Component: ECE 2020  --- 0184
       Serial number: --------------------
       Multimedia System 1:
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9HJ404EKJ
       Multimedia system control head:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 17051700000000001045
       Compact disc data bank:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1016
    2 Faults Found:
    0013 - Antenna Amplifier 1 for Digital Radio
              B1270 13 [009] - Open Circuit
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 20
                        Reset counter: 154
                        Mileage: 138535 km
                        Date: 2023.09.23
                        Time: 20:26:11
                        Voltage terminal 30: 13.1 V
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
    3086 - Antenna for Telephone Mount
              B1564 01 [009] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 28
                        Reset counter: 153
                        Mileage: 139147 km
                        Date: 2023.09.30
                        Time: 10:55:45
                        Voltage terminal 30: 15.4 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 104
                        Mileage: 137221 km
                        Date: 2023.09.01
                        Time: 15:41:16
    Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31377920800000 Dataset Number: 4M0909541G  0025
       Coding: 0090
       ASAM Dataset: EV_DeckLidCONTIAU736 001014
       ROD: EV_DeckLidCONTIAU736_AU37.rod
       VCID: 48C23345524EE9EA87B-811C
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M2 713 041 E    HW: 4M2 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 20170428000538
       ASAM Dataset: EV_GSMWaehlZFAU736 001017
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 280293C5F20E09EA67B-817C
    Address 82: Head Up Display (J898)       Labels:* None
       Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
       Component: HeadUpDisplay H29 1640
       Coding: 2A01C0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736_AU73.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H14 0042
       Dataset Number: 4M0909466L  0042
       Coding: 0407030600000401024023A1A50000B400F0C020C020
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
    2 Faults Found:
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 23
                        Reset counter: 191
                        Mileage: 137276 km
                        Date: 2023.09.02
                        Time: 10:51:26
                        Control Module temperature: 33  C
                        Voltage terminal 15: 13.30 V
    1123601 - predictive route data
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 16
                        Reset counter: 192
                        Mileage: 137275 km
                        Date: 2023.09.02
                        Time: 10:51:01
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       Dataset Number: 4M0909571H  0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
       VCID: 30327BA5CADE412ABFB-8164
    Address BB: Door Rear Drv (J388)       Labels:* None
       Part No SW: 4M0 959 595 H    HW: 4M0 959 595 F
       Component: TSG HFS       005 0125
       Serial number: 0000259491034  Dataset Number: 4M0909897G  0030
       Coding: 000D98000001000000003080
       ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
       ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
       VCID: 43D824696B68CAB2529-8116
    Address BC: Door Rear Pass (J389)       Labels:* None
       Component: TSG HBFS      005 0125
       Serial number: 0000259491033  Dataset Number: 4M0909896G  0030
       ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
       ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       Dataset Number: 4M0909471D  0012
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
       ROD: EV_LEDModLeftMELCOAU736_AU73.rod
       VCID: 167EAD3D487A8F1AC57-8142
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
       Component: LED1R         H09 0003
       Dataset Number: 4M0909472D  0012
       ASAM Dataset: EV_LEDModRightMELCOAU736 001004
    End----------(Elapsed Time: 02:31, VBatt start/end: 12.1V/12.2V)-----------
  4. Re: Audi Q7 2017 Trailer Assist fault
    134 Post(s)
    2018 Post(s)
    Trailer assist or retractable tow bar were not factory fitted so the coding would need checking with Software Version Management on ODIS. The proper name for the part is "G820 Trailer articulation angle sensor". This is inside the swivelling tow bar unit and there are eight versions. The Pr code is 1D9 and the part number varies by date so with yours being built 03.06.2017 it would take 4M0 803 881 E for cars made 21.11.2016>05.06.2017 but this was revised to 4M0 803 881 J which is £3568.80
  5. Re: Audi Q7 2017 Trailer Assist fault
    Mar 2007
    Devon
    Thanks for the advice. Don't think there's anything I can do myself. Better look up an audi specialist in my area.
  1. Replies: 28
    Last Post: 05-07-2021, 01:44 PM
  2. Trailer assist coding
    By paulrstaylor in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-11-2020, 07:29 PM
  3. Please Help 2017 Audi S1 high beam assist memory/always on?
    By S1_LS70 in forum VCDS - Help Requests
    Last Post: 24-03-2020, 10:17 PM
  4. Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    By Igloo in forum Q7 - 4M Forum - 2016 -
    Last Post: 10-05-2019, 02:00 PM
  5. Trailer assist TTA on A4 model
    By french_audi in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 24-01-2018, 06:08 PM
