Thread: 2006 1.9 tdi dsg engine stops after 2-3 min when drive
  1. 2006 1.9 tdi dsg engine stops after 2-3 min when drive
    Oct 2023
    Uk
    I had some fuel leak with full tank so took it to a garage to fix it. They had to drop the tank and replace the seal over the fuel pump. Next morning my car didnÂ’t started. They came and helped to start with a spray into the engine and said it was because the fuel was low (they didinÂ’t tell me I should refuel straight away canÂ’t wait till morning (it was above the red line with 1 more line so not empty). Used it all day, without any problem. On the next day when the engine was hot, sometimes started really hard (just like when my fuel pump was dying in the past - though that time it was constant no it was occasionally). Took it back to the garage and they checked next morning when it was spot on. During that day the start was sometimes good but a few times bad again. The next day on after my third stop the engine didnÂ’t started just like the first day but with half a tank. Asked a nearby garage to spray it and drove it to a VW specialist. He said, if it is not doing when the computer is on, he canÂ’t do anything. Drove off the garage, 3 mins later when I slow down at a roundabaut, the engine just stopped, and wasnÂ’t able to start again. Ever since it need the spray to start, and after 2-3 mins it stops when I slow down.
    Here is the list what the mechanist changed/tried:
    Change fuel pump
    Took off EGR
    Took of the sensor for the airflow
    Replace relay to the pump/injectors
    Readjusted injectors back to standard
    I know it was long, thank you if you read until this point.
    If anyone has any idea what can cause it, please help.
  2. Re: 2006 1.9 tdi dsg engine stops after 2-3 min when drive
    134 Post(s)
    2007 Post(s)
    Check the arrows on the pipes on the fuel tank top, feed black, return blue
    This is an R32 but it is the same
  3. Re: 2006 1.9 tdi dsg engine stops after 2-3 min when drive
    Oct 2023
    Uk
    Next week we will definitely try, thanks for it.
  1. Question engine stops a6 c7 allroad
    By chris.d in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-01-2020, 09:57 AM
  2. Engine Fan stays on when car stops.
    By Audi head in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-01-2015, 08:45 PM
  3. 2006 Passat starts then stops, Help!
    By fabusy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2011, 08:25 PM
  4. Golf GT Tdi engine stutters and stops HELP
    By hoovers dad in forum Golf MK4 - 1999 - 2004
    Last Post: 19-09-2010, 10:56 AM
  5. Question Engine stops while driving
    By Bigone2006 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-01-2009, 12:22 PM
