Thread: 22mpg from a 2.0 engine???
Results 1 to 10 of 14
  1. 22mpg from a 2.0 engine???
    hey guys, need a hand cos my car is costing me a fortune.
    Its an audi a4 2.0 and i'm finding the car is averaging 22mpg, i doubt this is normal! most of my driving is around town and dual carrageway, i don't rag the life out of it. vag-com comes up with nothing at all, thinking the air flow meter is probably on its last leg or something. Is there anyway i can find out if the car is running rich apart from an mot centre.
    anyhelp would be great guys
  2. Re: 22mpg from a 2.0 engine???
    Ran a 2.0 20v petrol from 98,000 to 137,000 in a year. It averaged 34-35 mpg on mixed driving.
  3. Re: 22mpg from a 2.0 engine???
    132 Post(s)
    1980 Post(s)
    What year and engine code is it?
  4. Re: 22mpg from a 2.0 engine???
    Sep 2007
    Se London
    Myne is the exactly the same, 22mpg is what i usually end up with.
    Oil pump was clogged up in myne last week and still not got it back but i doubt this is a result. Oil light came on while oil was full, engine started making a terrible knocking noise from the top end. Audi said needs a replacement oil pump which will take 7 days to come in, £900.
    Will update you if it improves the fuel consumption when i get it back, though i doubt it?
  5. Re: 22mpg from a 2.0 engine???
    2001/51 2.0 20v petrol ALT.
  6. Re: 22mpg from a 2.0 engine???
    132 Post(s)
    1980 Post(s)
    Actually I meant Mr T, are you having a problem as well?
  7. Re: 22mpg from a 2.0 engine???
    Dec 2006
    if you have access to VAG-COm read the engines codes...
    if you have the below..
    1 Fault Found:
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 -- 002 -- Lower Limit Exceeded
    Go into the "Measuring Blocks", and check the lambda sensor reading... this should be around 2% @ 90'c... if its up at 8-9% the lambda is at fault, which makes the car run rich and drink a little extra fuel..
    i also have this issue, HOWEVER my MPG is not affected as i tend t odo loads of miles..
    Around town it will drink...
    if i used Supermarket fuel or NORMAL unleaded 95 i will only pull 26-27 MPG.. if i use 97-98 Shell or Super i pull 32MPG..
    These engines seem to prefer the higher RON fuel..
    If you are still having issues, also check the MAF readings in VAG-com.. You could always disconnect the MAF to see if you get better MPG to check if the MAF is at fault.
    also ensure the air filter is clean... even if you don't want to change it... whip the cover off and give it a shake/ bang on the floor to get the dust and dirt out of it..
    Rick
  8. Re: 22mpg from a 2.0 engine???
    Sep 2007
    Se London
    Edit : nevermind.
  9. Re: 22mpg from a 2.0 engine???
    Funnily enough, my 2.0 is exactly the same! On a long run without traffic its fine, but in town it drinks like an alcoholic!
    Y Reg (2001) 2.0 A4 SE (B6)
  10. Thumbs up Re: 22mpg from a 2.0 engine???
    Oct 2006
    bedfordshire
    HI ALL
    I have a 1.8t getting around 30 mpg down the motorway not bad but as petrol
    is now around £1.05 I am going to get it converted to LPG at around £0.50
    looking at lpg details I should end up at around 50 to 55 mpg.
  1. Engine Fans Start Up after Engine is Switched off??
    By batman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2009, 02:15 PM
  2. A4 Engine support to replace engine mounts
    By JScribner in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2007, 03:57 AM
  3. engine drop - engine mountng bolts sheer
    By shazzander in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-04-2007, 03:29 PM
